It is currently Fri Nov 29, 2024 12:21 am
 Post subject: 142" resaw blade
PostPosted: Wed Mar 31, 2021 11:30 am
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Hey everyone, I accidentally bought a 142" 3/4" resaw blade from highland woodworking only to realize it was the wrong size for my saw while attempting to install it (my saw requires 143"). I don't think I can return it now that I've discarded the packaging so if anyone would have any use for this please let me know! Only asking for shipping costs to you!
 Post subject: Re: 142" resaw blade
PostPosted: Wed Mar 31, 2021 11:51 am
First name: Big
Last Name: Jim
That blade should work. :?: You should have well more than 1/4" of play , OR your blades are being ordered on the short side of your play length in the first place :?: Or is that 142 x 3/4 instead of 142-3/4" :?:
PostPosted: Wed Mar 31, 2021 11:58 am
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
it should fit according to the manufacturer but it very much does not :(
https://www.grizzly.com/products/grizzl ... vAQAvD_BwE
PostPosted: Wed Mar 31, 2021 12:07 pm
First name: Big
Last Name: Jim
Are u getting the full drop on the top wheel when u loosen it , mine (diff saw) sticks some times and i have to tap it with rubber hammer to get it to go down all the way .. Just a thunk ?
PostPosted: Wed Mar 31, 2021 12:13 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Not stuck, unfortunately
These users thanked the author oval soundhole for the post: WudWerkr (Wed Mar 31, 2021 12:17 pm)
PostPosted: Wed Mar 31, 2021 1:15 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I own the same Taiwanese-made saw, sold under the Australian Carbatec brand. You should be able to shorten the blade length requirement by turning the tension adjustment wheel. If that doesn’t give you enough, try measuring the blade to confirm the length they claim is incorrect.
PostPosted: Wed Mar 31, 2021 1:53 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I've just measured the blade and it is in fact 142".
The tension wheel is as loose as it will go (with the quick tension lever set to loose) and it will not fit. Strange
PostPosted: Wed Mar 31, 2021 2:11 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
So yours is not 142.75” but rather 142.0” . The saw is designed for 143”. I think you’ll have to eat it and reorder the correct length.
PostPosted: Wed Mar 31, 2021 2:37 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I did, that's why I'm offering this blade to anyone who could get some use out of it [:Y:]
also the 3/4" was in reference to the width of the blade
These users thanked the author oval soundhole for the post: WudWerkr (Wed Mar 31, 2021 3:33 pm)
PostPosted: Tue Apr 20, 2021 2:39 pm
OLF Sponsor
OLF Sponsor
First name: Brent
Last Name: Cole Sr
City: Craig
State: Alaska
Zip/Postal Code: 99921
Country: USofA
If you don't find a new home for the saw, You should be able to load that saw onto your wheels. Maybe by not the detention wheel as you have most likely tried, but you can use your tracking adjustment and tilt the top wheel out and down, like your adjusting the tracking out and that should give you the little bit you need to get the saw on the wheels.
We have done this when loading 22' 6" saws made for the 42" New London Machine on to our 42" Industrial saw machines that use a 22' 8" saw.
PostPosted: Tue Apr 20, 2021 7:05 pm
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
Hi Brian, If you can't use it I can, if the shipping 's not too outrageous. I'll just cut it, repair it and use it on my 20" saw. Send me a pm
Users browsing this forum: bftobin and 60 guests
