It is currently Sat May 03, 2025 5:44 pm
PostPosted: Mon Dec 07, 2020 3:21 pm
Anyone know the proper side sit pattern for this kind of board?Image
PostPosted: Mon Dec 07, 2020 4:07 pm
Last Name: Ball
I've done some boards like that and use single side dots except at 12. Same thing with boards with trees of life/vines, fancy banjo style inlay or whatever. I only use double dots at 12 on the side. Don't know whether or not that is proper, but it's what I've always done.
These users thanked the author ballbanjos for the post: meddlingfool (Mon Dec 07, 2020 5:37 pm)
PostPosted: Mon Dec 07, 2020 5:55 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Martins that have that inlay pattern do double side dots at the 12th and single dots for all the other positions. So if Martins are considered proper,....
Edit: Oops, correction: I checked my HD-28VR which has that same fretboard marker inlay pattern. Double side dots at the 12th and single side dots at 3, 5, 7, 9, 15, & 17.
PostPosted: Mon Dec 07, 2020 6:08 pm
That is a typical pattern for a guitar, with some also having a dot at the third fret. I follow the "dots" on the board. On some guitars I have only done side dots, but again that is the pattern I follow - (3),5,7,9,12,15,(17)
PostPosted: Mon Dec 07, 2020 7:29 pm
Last Name: Kincheloe
I do 3,5,7,9,12,15,17,19, with 7 and 12 being double dots.
PostPosted: Mon Dec 07, 2020 8:56 pm
Why use double dots anywhere on the side?
PostPosted: Mon Dec 07, 2020 9:05 pm
First name: Jay
City: Bothell
State: Washington
Same reason that the 12th fret fretboard markers are typically distinct from the other fret markers. To give a clear visual landmark. At least that's how I've always looked at it.
PostPosted: Mon Dec 07, 2020 9:28 pm
First name: Brad
Last Name: Combs
I have a Martin 000 with that layout and like others have said it’s only double side dots at the 12th.
Brad
PostPosted: Mon Dec 07, 2020 9:56 pm
That’s pretty much my default fretboard decor. I do single dots at all locations including 12.
I justify it by figuring that any player that hangs out in that territory on a 14 fret neck shouldn’t need two dots to know where they are and it looks classy. Real reason? It’s easier. :)
PostPosted: Mon Dec 07, 2020 9:58 pm
Thanks...
PostPosted: Mon Dec 07, 2020 10:01 pm
J De Rocher wrote:
I've always used one dot at the 12 also. I figure the two frets away from the rest is a clear enough indicator.
PostPosted: Mon Dec 07, 2020 10:35 pm
First name: Jay
City: Bothell
State: Washington
Pmaj7 wrote:
J De Rocher wrote:
Yes, but having two dots is even clearer. And, I can fall back on the "it's tradition" rationale. All the guitars I've owned that had side markers had two dots at the 12th fret.
Then there's that time I put three dots at the 12th fret. I was installing the side dots on a guitar which was the first one on which I had used a fancy fret marker set that started at the first fret. I drilled the holes for the side markers starting from the first fret and working my way up with the neck. I drilled the two holes as usual at the 12th fret with it's double fret marker inlay only to realize that I had drilled them at the 9th fret (#$%@ fancy inlay). Since the fretboard binding was curly koa, there was no way to fill the holes invisibly. Solution? Three dots at the 12th fret. Overkill, yes, but the simplest option. No excuse for not knowing which fret you are on with that guitar.
These users thanked the author J De Rocher for the post: Pmaj7 (Mon Dec 07, 2020 11:05 pm)
Users browsing this forum: No registered users and 42 guests
