It is currently Fri Jul 18, 2025 8:49 am
 Post subject: kerfing cllips
PostPosted: Wed Dec 18, 2019 5:19 pm
https://3hangersupply.com/skirt-clips
Per a note in GAL p. 65 from Gregg Miller, the above clips work well for kerfing installation. $10 for 500.
 Post subject: Re: kerfing cllips
PostPosted: Wed Dec 18, 2019 5:35 pm
That's quite a deal. Have you used them before?
These users thanked the author meddlingfool for the post: wbergman (Wed Dec 18, 2019 6:24 pm)
PostPosted: Wed Dec 18, 2019 6:25 pm
I have not used them. They look a bit flimsy, but I think with a flexible enough kerfing they should be OK. After all, when you glue individual blocks, you do not use any clamp.
PostPosted: Thu Dec 19, 2019 6:52 am
I am a spring clamp user.
https://www.amazon.com/Online-Best-Serv ... 173&sr=8-7
These users thanked the author bluescreek for the post: wbergman (Thu Dec 19, 2019 10:58 am)
PostPosted: Thu Dec 19, 2019 7:15 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Do they have a version to clip unkerfings? Asking for a friend.
- Beth Brower
These users thanked the author Woodie G for the post (total 2): Pmaj7 (Thu Dec 19, 2019 3:31 pm) • wbergman (Thu Dec 19, 2019 10:58 am)
PostPosted: Thu Dec 19, 2019 9:31 am
First name: George
City: Seattle
I've always felt that kerfing should be free.
George :-)
These users thanked the author George L for the post (total 3): Ernie Kleinman (Fri Dec 20, 2019 10:28 am) • Pmaj7 (Thu Dec 19, 2019 3:25 pm) • wbergman (Thu Dec 19, 2019 10:58 am)
PostPosted: Thu Dec 19, 2019 10:02 am
I've used the same rubber banded cloths pins since circa 1990 on a bit more then 65 guitars. But those spring clamps John posted look tempting. I'd like to hear from anyone that used those skirt clips though. So how do they work? They look like they have a little hook lock or something? So you squeeze it and it locks in place?
These users thanked the author jfmckenna for the post: wbergman (Thu Dec 19, 2019 10:59 am)
PostPosted: Thu Dec 19, 2019 10:16 am
Last Name: Colbert
City: Anacortes
bluescreek wrote:
+1
.17ยข a piece.
PostPosted: Thu Dec 19, 2019 11:00 am
Yes, you squeeze it and the little teeth grab each other.
These users thanked the author wbergman for the post: jfmckenna (Thu Dec 19, 2019 12:20 pm)
PostPosted: Thu Dec 19, 2019 11:02 am
Are the spring clamps in your link metal? I had a plastic one from freight explode, as did other who posted.
PostPosted: Thu Dec 19, 2019 11:22 am
those are little metal one
These users thanked the author bluescreek for the post: wbergman (Thu Dec 19, 2019 6:06 pm)
PostPosted: Thu Dec 19, 2019 1:49 pm
I've used these for over 10 years and they work well. Unfortunately they are not as cheap as they used to be.
https://www.leevalley.com/en-us/shop/tools/hand-tools/clamps/41712-plastic-spring-clamps
These users thanked the author SteveSmith for the post: wbergman (Thu Dec 19, 2019 6:06 pm)
PostPosted: Thu Dec 19, 2019 2:05 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I have over 100 of those little ones that John linked. Bought them at different times, from different sources. I use them all the time for linings. If I do both sides of a violin I can use all of them. I didn't even have enough to glue the linings on one side of the guitar. 17 cents each is pretty cheap.
Not a fan of the plastic ones, the tips move around. Maybe that works for some things, but in a hurry with HHG is not one of those times. The only problem with the metal ones is that the plastic protectors fall off some times. I thought about using that plastic dip stuff. It should work.
Why be normal?
These users thanked the author Ken Nagy for the post: wbergman (Thu Dec 19, 2019 6:05 pm)
PostPosted: Thu Dec 19, 2019 2:20 pm
Interesting, the rotating tips on the plastic clamps is why I like them, they self level, so to speak, and don't mar anything. The only thing I use them for is gluing linings.
These users thanked the author SteveSmith for the post: wbergman (Thu Dec 19, 2019 6:05 pm)
PostPosted: Thu Dec 19, 2019 7:00 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Yep, and the HF ones can make the job quite colorful. They're so cheap that if they break, you can toss them or keep them for repair parts. When I've glued purfling to binding I've opened up the foot and it wraps around the edge and doesn't slip off
