It is currently Fri Aug 01, 2025 7:26 pm
PostPosted: Mon Jun 17, 2019 11:42 am
First name: Big
Last Name: Jim
I had the guitar clamped tight and the neck fitted to a flat fit . It is both Bolted and Glued . Mainly under the fret board , however there is a couple spots on Joint as well . After fitting , gluing , clamping and Bolting . Sat 24 hrs . Cleaned up and strung up then i see this . gaah [headinwall]
I REALLY dont want to take it apart . Gap is .009
Ideas ??
PostPosted: Mon Jun 17, 2019 11:47 am
Is it possible something has got trapped in there?
PostPosted: Mon Jun 17, 2019 11:50 am
First name: Big
Last Name: Jim
I had same thought so I shined a light on opposite side with magnifiers on and cant see anything .
PostPosted: Mon Jun 17, 2019 11:59 am
Just wonderin', I had one there the tenon was just touching the base of the mortice
PostPosted: Mon Jun 17, 2019 12:08 pm
End-grain sawdust (EIR?) and TB using a syringe and needle, wipe off the excess
PostPosted: Mon Jun 17, 2019 12:18 pm
First name: Big
Last Name: Jim
Maybe . I have offically named this one bullfrog. More warts than you can count . This is one of those "nothing goes easy" Builds !
PostPosted: Mon Jun 17, 2019 12:30 pm
First name: Ken
Last Name: Nagy
City: Goodrich
If it happened after you strung it up, is it possible that the neck pulled up some?
Maybe glue small slivers of wood glued under it; with the strings still on. No one will know but you, and everyone reading this.
I don't usually see things like that until someone points them out. Between the neck and the fb is always the worst. I keep telling myself that 98% of the joint is perfect, so it doesn't matter. Delusion helps. My near vision isn't that great either, so it doesn't even bother me!
Why be normal?
PostPosted: Mon Jun 17, 2019 12:41 pm
First name: Big
Last Name: Jim
Ken Nagy wrote:
If it happened after you strung it up, is it possible that the neck pulled up some? !
That's the only thing I can think of . The actual area is just over 1/2" . I KNOW i checked it before and didn't notice it, however ............. idunno
PostPosted: Mon Jun 17, 2019 12:50 pm
I had this happen recently. The dry fit of the heel (dove tail) seemed perfect, so I glued it in. When I removed the clamps I had a similar gap that I could slide a thin piece of paper in. For some reason it did not seat properly when I glued it in. I steamed the neck off and worked on the joint some more and the new fit is really tight. I am so glad that I re-set it. In my opinion, it is the best option for you as well.
If you use a bolt, why do you need glue, other than at the FB extension?
PostPosted: Mon Jun 17, 2019 12:59 pm
First name: Big
Last Name: Jim
Suspenders and Belt Kinda Guy ! laughing6-hehe
These users thanked the author WudWerkr for the post: surveyor (Mon Jun 17, 2019 5:34 pm)
PostPosted: Mon Jun 17, 2019 3:19 pm
Color Putty.
PostPosted: Mon Jun 17, 2019 4:22 pm
Not exactly belt and suspenders. More like belt and glue. The presence of the glue makes it difficult to adjust the neck, or your pants ;-)
PostPosted: Mon Jun 17, 2019 4:35 pm
First name: Big
Last Name: Jim
laughing6-hehe laughing6-hehe laughing6-hehe laughing6-hehe
PostPosted: Mon Jun 17, 2019 5:41 pm
First name: Trevor
Last Name: Gore
City: Sydney
If you used a water based glue, the absorption into the end grain of the heel block can be enough to cause that amount of curvature and a consequential gappy fit. A good reason not to use glue at all and just use bolts!
Regarding hiding it, dark grain filler is an option, though it's probably at its least noticeable as it is. If it's bothering you enough to want to hide it, best to redo it.
http://www.goreguitars.com.au
PostPosted: Mon Jun 17, 2019 7:18 pm
I agree with Trevor, better redo that one and figure out what caused it.
That’s a pretty short heel and I assume dovetail too. Any reason you didn’t make it longer?
PostPosted: Mon Jun 17, 2019 8:44 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Leave it as is or take it apart.
Will you need to relocate the saddle after correcting the fit?
Methinks Jeff Healy wouldn’t notice.(RIP)
PostPosted: Tue Jun 18, 2019 7:24 am
If it would be difficult to remove the neck, you could put a plane shaving of the same wood under the heel cap and fill in the little bit at the sides of the heel with wood filler, and touch up the finish.
You mentioned there are warts elsewhere, so it might not be worth the effort to make it perfect. If it sounds good and plays well some warts can be forgiven. Sometimes you just have to call it "done" and move on to the next one.
PostPosted: Tue Jun 18, 2019 7:54 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
You could do what Taylor does, and make a paste using colored wood putty and linseed oil. Apply to joint with a syringe and smooth out using tissue paper. Makes the gap nearly invisible.
It will probably be alright.
PostPosted: Tue Jun 18, 2019 9:41 am
First name: Big
Last Name: Jim
I am leaning that direction , This is a beautiful sounding guitar and plays well . It has just been one of those "nothing went easy " builds
https://youtu.be/4Za52ppUlWg
PostPosted: Tue Jun 18, 2019 10:01 am
First name: Aaron
Last Name: Hix
City: Chatsworth
State: Georgia
Zip/Postal Code: 30705
Did you leave a small gap between the tenon end and the mortise base? If it touches, then the use of glue could have swelled the neck block enough that it pushes outward on the heel part of your neck tenon.
Guitar Maker and Purveyor of the World's Finest Tonewoods
http://www.aaronhixguitars.com/
http://stores.ebay.com/A-Hix-Tonewood-a ... r-Supplies
PostPosted: Tue Jun 18, 2019 11:12 am
First name: Big
Last Name: Jim
Yes there is approx .090 gap in that location .
I have just about decided to leave it alone . the actual gap is .005 .... barely fits a sheet of paper .
PostPosted: Tue Jun 18, 2019 12:31 pm
Last Name: Beaver
City: Lake Forest
You say the neck is bolted on? Assuming you considered the suggestions above, it could be that the lower bolt is bottoming out against the heel. That will hold it off. You can test it by putting a couple washers on the bolt,
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: WudWerkr (Tue Jun 18, 2019 3:38 pm)
PostPosted: Tue Jun 18, 2019 4:01 pm
One old woodworker's saying is "The enemy of Good is Better". Sometimes when you try to make something just a little better, you wind up making it worse.
These users thanked the author Clay S. for the post: WudWerkr (Tue Jun 18, 2019 4:13 pm)
Users browsing this forum: doncaparker and 36 guests
