It is currently Mon Sep 15, 2025 11:53 pm
PostPosted: Wed Dec 26, 2018 8:11 pm
Last Name: Colbert
City: Anacortes
I'm pretty pleased with the results. A couple quick refinements and that'll be done.
These users thanked the author Michaeldc for the post (total 3): Jonny (Sat Dec 29, 2018 2:55 pm) • Pmaj7 (Thu Dec 27, 2018 2:49 pm) • Joe Beaver (Thu Dec 27, 2018 1:43 pm)
PostPosted: Wed Dec 26, 2018 8:14 pm
That looks great!!
PostPosted: Wed Dec 26, 2018 8:19 pm
Wonder if you could implement a rotary cutter into that
PostPosted: Thu Dec 27, 2018 10:00 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
You bet!
PostPosted: Thu Dec 27, 2018 11:13 am
First name: Danny
Last Name: Vincent
Slick my friend! Simple and effective. Thanks Michael!
Best of the Season to you both!
These users thanked the author DannyV for the post: Michaeldc (Fri Dec 28, 2018 6:28 pm)
PostPosted: Thu Dec 27, 2018 1:04 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
That's a great idea. Simple and little loss from the saw kerf. I like it
PostPosted: Thu Dec 27, 2018 1:33 pm
Last Name: Beaver
City: Lake Forest
I like it a lot. Cutting purfling has also been a pain for me.
Making one is high on my to do list. Thanks for posting
Joe Beaver
Maker of Sawdust
PostPosted: Thu Dec 27, 2018 6:47 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Steve Latta is the go-to guy for furniture stringing. He designed the stringing tools for L-N and he has some good ideas. Here is an article he did for FWW on making a slicing gauge like the one that L-N sells. Neat that it has an oval beam for easy cutting of the mortice, and that it uses a blade like an Exacto #11 which is cheap and resharpenable. You could easily simplify it by eliminating the brass wear strip:
https://www.finewoodworking.com/2006/12/15/a-shopmade-slicing-gauge
He also did a video showing the use of a simple woodworking marking gauge with a sharpened pin to repeatedly score a veneer to cut it.
The picture below shows his set up for cutting strips. Notice the thin, light colored fence that the veneer butts against. You then set the width with the slicing gauge so you can cut repeated variable widths. In the picture, he has a black/white veneer sandwich he is cutting
Ed
PostPosted: Thu Dec 27, 2018 7:23 pm
Last Name: Sollod
That’s very slick Michael!
www.swiftcreekguitars.com
PostPosted: Thu Dec 27, 2018 8:54 pm
Last Name: Howell
City: Atlanta
State: Ga
These are good ideas and I plan to use them; but till I make a few tools I am using my veneer saw. Not precise but it works fine on larger sheets, Then I cut strings 1/8" on BS with 14 tooth blade. Requires blade change and smoothing the cut edge but works till I make a new tool. This may inspire me.
PostPosted: Sat Dec 29, 2018 2:08 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Simple and elegant. Nice.
These users thanked the author JSDenvir for the post: Michaeldc (Sat Dec 29, 2018 8:21 pm)
Users browsing this forum: DennisK and 16 guests
