It is currently Sun Aug 03, 2025 12:35 pm
 Post subject: Quandary
PostPosted: Thu Aug 09, 2018 11:14 am
Last Name: Blower
City: Keighley
State: West Yorkshire
Country: UK
For reasons I won’t bore you with, I have acquired a fair quantity of .8mm wood veneer. About half of it is rosewood, the rest is other dark wood, species uncertain.
It’s in five foot by one foot sheets.
Has anyone made use of such materials? Any suggestions?
 Post subject: Re: Quandary
PostPosted: Thu Aug 09, 2018 11:48 am
Neck laminations, purfling (and shims)
PostPosted: Thu Aug 09, 2018 11:54 am
First name: Danny
Last Name: Vincent
Arm bevels if you can find a matching binding.
PostPosted: Thu Aug 09, 2018 12:23 pm
Laminated purflings...
PostPosted: Thu Aug 09, 2018 12:47 pm
laminated guitar bodies
PostPosted: Thu Aug 09, 2018 1:58 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Its crap, please forward to me so it can be disposed of in a proper manner.
B
PostPosted: Thu Aug 09, 2018 2:30 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Bri beat me to it :)
Several good uses have already been given but I'm sure if you just keep it around, more uses will hit you and you'll be glad you have it.
Bryan Bear PMoMC
PostPosted: Thu Aug 09, 2018 11:50 pm
Last Name: Blower
City: Keighley
Country: UK
Thanks for the suggestions, chaps.
My first thought was to try a 3 piece laminated back and sides (maybe headstock veneers) but gluing up veneers successfully seems like it will need a vacuum bag setup which I don’t have. Maybe it’s time I made one.
I was also worried about bending laminated boards and the effect on the glue.
Some of the sheets are so pretty I’d be loathe to use them for purfling or shims, but the arm bevel cap is a nice suggestion.
PostPosted: Fri Aug 10, 2018 6:49 am
First name: Victor
Last Name: Seal
City: Osseo
Zip/Postal Code: 49266
Sounds like another one of those things that you don't need until you have it. I suspect that in a couple years, you will be searching for some more.
PostPosted: Fri Aug 10, 2018 9:43 am
I would definitely do laminate sides with it and try to find solid backs that match. Nothing wrong with lam backs too I guess. Anyway it sounds like a problem that is worth having ;)
PostPosted: Fri Aug 10, 2018 9:46 am
I don't use vacuum bags for laminating veneers. I laminate between two pieces of smooth melamine coated particle board (and waxed paper) and use a bunch of clamps. The boards only have to be about 9 inches wide to do back sets. I laminate sides over a bending form with cauls and clamps and use formica scraps to provide a smooth surface to laminate against. I use clear epoxy (west system 105 /207 hardener). Once the glue sets the sides will hold their shape for years.
As I have mentioned many times before - heating and drying the veneer just before laminating with epoxy I have found to give the most stabile laminations.
These users thanked the author Clay S. for the post: CraigG (Sun Aug 12, 2018 9:21 am)
PostPosted: Fri Aug 10, 2018 3:49 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
And cinder blocks will stand in for clamps in Clay's scenario
Ed
PostPosted: Mon Aug 13, 2018 5:26 pm
Why not resaw it?
PostPosted: Mon Aug 13, 2018 5:37 pm
"Why not resaw it?"
You need an awful good set up and a mighty thin blade to resaw .8mm veneer. pizza
PostPosted: Tue Aug 14, 2018 7:04 am
Whoops, I didn't see the "."! Is it Brazilian?
