It is currently Thu Jul 03, 2025 8:34 pm
 Post subject: Upper transverse bracing
PostPosted: Mon Apr 11, 2016 11:17 am
First name: Brad
Last Name: Combs
Hello,
I'm building a tenor uke, the first one from scratch for me. I've built a couple of the SM uke kits.
I searched here and it seems about 50 / 50 in favor or radius the top or flat. I put a 30' radius on the rims and glued the waist and fan braces on after radiused to 30'. I glued them up in a radius dish / go bar just like I use on guitar.
Question: When building a guitar I've put the upper transverse brace on flat to try to avoid a gap at the fretboard extension. Do the same for the Uke? It seems like it would be the same, but I'm curious if others do the same?
Thanks!
Brad
PostPosted: Mon Apr 11, 2016 12:08 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I use an upper transverse brace on my ukes. I make it the same size as the lower transverse
These users thanked the author Quine for the post: bcombs510 (Mon Apr 11, 2016 12:30 pm)
PostPosted: Mon Apr 11, 2016 12:30 pm
First name: Brad
Last Name: Combs
Does that mean radiused the same as well? :)
PostPosted: Mon Apr 11, 2016 5:10 pm
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
I radius mine to 30 ft also. The Uke is so small you can barely see the radius, I do not remember any problem fitting the neck/FB. May be a little sanding to get the area under the FB flat. Assuming you extend the FB to the sound hole.
These users thanked the author Alain Lambert for the post: bcombs510 (Tue Apr 12, 2016 1:07 pm)
PostPosted: Tue Apr 12, 2016 1:07 pm
First name: Brad
Last Name: Combs
Thanks. I went ahead and glued it on flat for this one, let's see how it goes. :)
Thanks!
Brad
