It is currently Mon Sep 15, 2025 4:53 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2
 Post subject: Re: Homemade tools
PostPosted: Wed Sep 11, 2013 3:40 am
Don't worry, Chris, I'm about to lower the standard on display considerably!
Beth,
Sorry for the delay, here is the fret bender... Tis ugly as sin but it worked! :)
Bolts, wingnuts, washers, and these http://www.ebay.co.uk/itm/4-x-Replacement-Shower-Door-ROLLERS-Runners-Wheels-V-Grooved-19mm-Dia-LW19-/281049030019?pt=UK_Home_Garden_Bathroom_Shower_Units_PP&hash=item416fd3dd83.
(The right roller is secured in an elongated slot by a wingnut, and slides up and down to change the radius.)
Thinking about it now, maybe it's best to slide the washers up and down rather than the roller.
PostPosted: Wed Sep 11, 2013 9:07 am
Great stuff here!
Filippo, the elegance of your tools has always blown me away.
I'm putting the final touches on a table saw sled fixture for cutting neck tenons, with an adjustable angle.
I also have a simple sled for cutting the taper on fretboards and vanilla jigs for rosettes and bridge slots.
PostPosted: Wed Sep 11, 2013 10:02 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I have some...
A router sled for planing large pieces of wood (such as a table top)... Note the spiderweb because I don't actually build that many tables... the shop isn't big enough.
My new workbench. There's nothing heavy enough in Taiwan, so I made my own out of discarded floor board.
A Wells Karol jig made from plexiglass, because I can't find UMHW and nobody knows what it is. It works well enough. Also below that: a bending iron. The wells karol jig is permanently attached to a router base so all I need to do is slide the motor in.
Typhoon Guitars
PostPosted: Wed Sep 11, 2013 11:23 am
First name: Tony
Last Name: C
City: Brooklyn
That's a pretty excellent idea keeping the router base attached to the circle jig, Tai-Fu. I never thought of buying additional bases, I just bought more routers so I didn't have to attach jigs. Your way is much cheaper I would reckon.
http://www.CostaGuitars.com
PMoMC
PostPosted: Wed Sep 11, 2013 11:30 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
By the way that only works for certain models... sometimes you can't always buy bases for a given router. I use the Rexon/Jepson Taiwanese trimmers where the base sells for about 6 dollars a piece, vs. the machine itself (which is about 30 dollars), so it makes sense to dedicate bases rather than whole routers. However I do have a Dewalt Laminate trimmer that I can't find bases for... only places I found wants 50 dollars for it and I actually paid less on the laminate trimmer itself... but then again it was used/display model.
Typhoon Guitars
PostPosted: Wed Sep 11, 2013 4:14 pm
Here is the noticed straightedge I made. I use a drafting square cut down to 19" with the end removed. I leveled it with the leveling beam, cut the notches and file the smooth. It straight it's homemade and best, it was only $10.
011 by Bohdan79, on Flickr
PostPosted: Wed Sep 11, 2013 4:34 pm
Nice bench Tai !!
These users thanked the author Jeff Highland for the post: Glenn_Aycock (Thu Nov 09, 2017 8:00 am)
PostPosted: Wed Sep 11, 2013 4:54 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Really nice job on the work bench, Tai! [:Y:]
Alex
PostPosted: Wed Sep 11, 2013 6:30 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I'm glad this thread is growing. So many useful ideas already posted here. I'm looking forward to more.
PostPosted: Wed Sep 11, 2013 7:12 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Jeff Highland wrote:
Nice bench Tai !!
+1
PostPosted: Thu Sep 12, 2013 4:58 am
Filippo Morelli wrote:
Cripes that is simply brilliant. I think I own 7 laminate trimmers now. Looks like I can buy bases at 1/3 the price of the whole shebang.
$30 for a Bosch Colt base.
Filippo
I have several Bosch Colt bases mounted to various jigs, and the cutters are pretty much permanently mounted in their trimmers. Instead of switching bits for different operations, I move the trimmers around from base to base. I've thought about getting a few extra bases, but as you can get those Colts pretty inexpensively on eBay all the time, I have bought extras to give me even more options for router bits.
Actually, I wish I'd done the same thing years ago, when the PC 310 was still being produced and not too expensive. Now, of course, I'm locked into using Colts for pretty much everything (my single PC310 only gets used for pattern routing, and a few other routers for similar single service tasks). The quality of the Colt is passable, but I do wish the height adjustment was a bit more precise, and I don't think it runs as true as the PC. I understand Rigid makes a better tool in the same class, it might be a better candidate if you are going to focus on a single model of trimmers.
PostPosted: Thu Sep 12, 2013 5:36 am
First name: Christophe
Last Name: Mineau
City: Louannec
State: Brittany
Zip/Postal Code: 22700
Country: France
Hi,
Nice thread, I am a big fan of DIY, and I must admit I often build myself good ideas taken here and there.
I do not always do that for economical reasons, it's most of the time simply because I feel like doing it !
The one I am the most proud of is this one :
Do you recognize it ? :D . And very efficient indeed !
I have also this one, which is funny, thought it is not the most straight forward way to build it, but I wanted to try this "3D printer like" method :
http://www.labellenote.fr/articles.php?lng=en&pg=87
I have my thickness sander, which embeds a compilation of all the goods ideas I found + some original tricks from me :
http://www.labellenote.fr/articles.php?lng=en&pg=260
Look at the bottom the geared table lifter !
And sometimes, there is no need for high end technology to get good tools : I have my paper made personal string action gauge:
http://www.labellenote.fr/download.php?lng=en&pg=56
And some other stuff :
mm <-> inch converter : http://www.labellenote.fr/articles.php?lng=en&pg=262
Soft jaws for a metal vice : http://www.labellenote.fr/articles.php?lng=en&pg=75
And I have lots of other for wood turning, but I stop here ...
Christophe Mineau
Let's make chips ! - http://www.labellenote.fr
PostPosted: Thu Sep 12, 2013 6:14 am
That geared table lifter is brilliant! Will have to put that on mine.
PostPosted: Mon Aug 31, 2015 9:52 pm
landrover wrote:
A must see. Homemadetools.net. . Click on "new tools", and just go page by page . AWESOME!!!!!
Jon here from HomemadeTools.net.
I know this thread is an old one, but thanks for the kind words :)
To celebrate our 20,000th homemade tool, we made a new ebook featuring our top 50 homemade tools. You guys are welcome to it for free:
http://download.homemadetools.net/50MustReadTools.pdf
These users thanked the author homemadetools for the post (total 2): Bob Garrish (Thu Sep 03, 2015 11:05 am) • hermit (Mon Aug 31, 2015 10:33 pm)
PostPosted: Tue Sep 01, 2015 12:12 am
Last Name: Blower
City: Keighley
State: West Yorkshire
Country: UK
Great link, thanks.
[:Y:]
PostPosted: Tue Sep 01, 2015 6:30 am
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Thanks for making the download available, but am I correct in thinking there are only 27 tools on the PDF , not the 50 as it says in the title?
PostPosted: Tue Sep 01, 2015 6:39 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Chris Pile wrote:
Man, I trained as a tool maker and have been doing luthier stuff since the 70's. I thought I'd post some of my useful handmade tools, but I'd look like a chump. Mine function well, but they aren't beautiful like what I see here.
Right there with ya.....I was taught functional for the shop, fancy for the client. Most of my tools are highly functional but look rather crude.
Brian
PostPosted: Tue Sep 01, 2015 9:38 am
First name: Daniel
Last Name: Petrzelka
State: Washington
A couple months back I ordered some O1 tool steel, and made up a violin knife and 1/2 chisel for brace carving. I'm fortunate enough to have several old glass kilns in the shop with digital temperature controllers, making tempering and annealing at home pretty easy. Tested the tools on an old Brinell hardness tester - came pretty close to my target of 62 Rockwell - hit 61.7.
These users thanked the author dpetrzelka for the post: Glenn_Aycock (Thu Nov 09, 2017 8:05 am)
PostPosted: Thu Sep 03, 2015 11:40 pm
You're very welcome. Should be 50 tools spread out over 27 pages. Image
PostPosted: Fri Sep 04, 2015 12:01 am
Last Name: Kincheloe
Here's a quick and easy one: Take an old x-acto blade and grind it to a chisel point. The blade thickness just happens to match standard fret slot width, so it's good for cleaning dust out of them (although a vacuum is even better if you have one handy). Also good for cutting tiny grooves in things.
These users thanked the author DennisK for the post: Pmaj7 (Wed Nov 08, 2017 8:17 pm)
PostPosted: Wed Nov 08, 2017 2:53 pm
Hey guys - we have a new ebook out: How to Make a Belt Sander. 100% free of course. Click the graphic below to check it out:
These users thanked the author homemadetools for the post: RogerC108 (Wed Nov 08, 2017 5:24 pm)
PostPosted: Wed Nov 08, 2017 3:51 pm
Last Name: Cox
Very cool. I love it!
I gotta tell you though... I had to back off of making all sorts of stuff like this... It quickly morphed into a hobby of it's own.. I was spending all my free time on rehabbinh old rust and making cool luthier related jigs and tools.... And I forgot to build guitars... I lost almost 2 years of buildimg guitars before I came to my senses. ;) ;)
These users thanked the author truckjohn for the post: Bryan Bear (Wed Nov 08, 2017 4:05 pm)
PostPosted: Wed Nov 08, 2017 4:10 pm
Yup, we've definitely noticed that. All hobbies are gateway drugs to homemade tool making.
Users browsing this forum: No registered users and 65 guests
