It is currently Wed Jul 09, 2025 4:55 pm
 Post subject: Side crack mid build
PostPosted: Fri Jun 20, 2025 9:09 am
First name: Carlos
Last Name: Abadie
Hi
I was wondering how you folks would approach this situation. I’ve sprayed the final coats of nitro and noticed there was a crack that developed recently. Should I apply ca glue and touch up with nitro or should I approach it differently? How does lacquer react when applying ca glue?
Any help is appreciated
Carlos
 Post subject: Re: Side crack mid build
PostPosted: Fri Jun 20, 2025 9:13 am
First name: Brad
Last Name: Combs
Wait for others to answer about nitro, I have no idea about it. But….
The crack looks like it’s cross grain? Are you sure it’s a crack all the way through? Maybe stick your phone in the sound hole and take a pic of that area of the side while dumping Naptha on the crack area to see if it wicks through?
I wouldn’t expect a surprise crack that is cross grain.
If you do go CA I would use GluBoost thin.
Brad
PostPosted: Fri Jun 20, 2025 9:27 am
Same disclaimer as Brad as to nitro. But...
Are you sure that's not a scratch in the finish rather than a crack in the wood? It does not follow a grain line at all. Are your linings that depth that it might be running along the bottom of a lining?
Looks more like a stray grit got dragged across the surface once and dropped off at the end of the swipe.
Same advice as to napha and photo. a little sharper focus or higher resolution on a picture would be great also.
PostPosted: Fri Jun 20, 2025 10:40 am
First name: Carlos
Last Name: Abadie
Unfortunately it is a side crack. I can feel it on the inside and when I put pressure I can feel it separating slightly. It’s a hairline crack that the nitro covered until I put pressure on it and then it became visible.
These users thanked the author Deegz for the post: bcombs510 (Fri Jun 20, 2025 11:47 am)
PostPosted: Fri Jun 20, 2025 11:49 am
First name: Brad
Last Name: Combs
Sorry that happened.
Others will for sure chime in on what to do. My guess is depending how far along you are toward leveling and buffing you can either take a step back and spray more coats or fix it with GluBoost post mortem.
Good luck!!
PostPosted: Fri Jun 20, 2025 12:00 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
My opinion on repairs is to fix a problem as soon as I find it, and that includes backing up until going forward involves no compromises and workarounds. Do what ya gotta do, today, so tomorrow doesn't see a problem. With good fortune in a perfect world, no one will ever see that there once was a problem. What the builder will remember is the huge investment in time and care, and maybe materials, involved in making a problem disappear.
Peter Havriluk
These users thanked the author phavriluk for the post (total 2): bcombs510 (Fri Jun 20, 2025 2:16 pm) • rbuddy (Fri Jun 20, 2025 12:28 pm)
PostPosted: Fri Jun 20, 2025 4:19 pm
Last Name: Ionta
City: Hopkinton
State: Massachusetts
Zip/Postal Code: 01748
Can you work CA glue into the crack from the inside?
PostPosted: Fri Jun 20, 2025 9:28 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
CA will significantly disfigure nitro, even the fumes can cause a "discontinuity" on a smooth lacquer surface.
If you wick CA in from the inside, and let it do what it's going to do, you could likely recover nicely with a normal-ish finish repair, if one is even required.
I've never wicked CA in from the inside with a nitro finish on the outside. If you hit the fresh CA with accelerator, any potential lacquer damage might be minimized. I think a medium CA would stabilize the crack and reduce the likelihood of excess CA wicking under the lacquer on outside. THats the approach I would consider: Medium CA, promptly followed with a shot of accelerator, well rehearsed in advance.
Then there is the after-CA repair thing...easy enough.
Does your body have side reinforcement strips?
Measure Twice,
Karl Borum
PostPosted: Sat Jun 21, 2025 8:35 am
Another option is to use thinned Titebond and use a suction cup or some other method to force the glue through the crack then put a clamp across the side. After it dries I would add a cleat in there. You can get a bag full of suction cups from Amazon for a few bucks.
These users thanked the author stevensmith for the post: Kbore (Sat Jun 21, 2025 10:32 am)
PostPosted: Sat Jun 21, 2025 9:04 am
I’d vote for the thinned tightbond and suction cup from the inside, spool clamped, followed by a cleat. You could even use Tightbond Dark which would hide any glue in the crack
Any irregularities on the outside could be handled by gluboost.
These users thanked the author Terence Kennedy for the post: Kbore (Sat Jun 21, 2025 10:32 am)
PostPosted: Sat Jun 21, 2025 3:21 pm
First name: Carlos
Last Name: Abadie
Thanks for the tips. I ended up applying ca glue from the inside and the crack stabilized. My plan is to spray 2 or 3 coats of nitro. I’ll let you folks know how it turns out.
These users thanked the author Deegz for the post (total 2): Kbore (Sat Jun 21, 2025 4:31 pm) • stevensmith (Sat Jun 21, 2025 3:41 pm)
PostPosted: Tue Jun 24, 2025 9:45 am
First name: peter
Last Name: havriluk
City: granby
State: ct
I think that crack is evidence that there was a weakness in the wood's grain structure. I'd be thinking of an internal patch (cloth?) to support the crack in all directions. But this problem isn't, literally, in my hands.
Guitar sides are bookmatched. What's the other side look like?
Peter Havriluk
These users thanked the author phavriluk for the post: Hesh (Tue Jun 24, 2025 11:45 am)
PostPosted: Tue Jun 24, 2025 11:53 am
I was going to stay out of this one but I wanted to let Peter know he's exactly right we would be reinforcing the inside too.
Instead of cloth though we might use BJR (back joint reinforcement) strips that are very nicely beveled at the edges and extra material was removed. It's a cleat but in the form of a light weight, spruce strip. What's important for structural integrity is the clean, patch, etc. is cross grain.
It will show if someone peers into the inside of the instrument maybe with a flashlight but if the crack comes back open again it will show much worse....
Good job Peter.
These users thanked the author Hesh for the post (total 2): phavriluk (Thu Jul 03, 2025 10:24 pm) • Kbore (Mon Jun 30, 2025 10:07 am)
Users browsing this forum: ChuckB and 34 guests
