It is currently Sat Jul 19, 2025 3:02 am
PostPosted: Tue Jun 17, 2025 2:16 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Time to turn a drawing into wood. My current project is for a shrunken Dreadnought, 18.5" long, 14.5" lower bout.
I've already chosen to try to not overbraced this one, and I'm using 3/16" wide bracing for the top, 1/2" high for the one lateral tone bar (think Larravee) and finger braces. What about the x-brace? I originally drew the 'x' as being 9/16" high in the center (tapered), and I'm wondering if I'd be better served by this one being a half-inch high, too. The red cedar top has been tap-tuned so that's a fixed parameter.
Anybody's SWAG advice will be joyfully received!
Thanks, folks.
Peter Havriluk
PostPosted: Wed Jun 18, 2025 10:52 am
In absence of any other takers…for a guitar that size, 1/2” brace heights will probably be fine, provided there’s enough stiffness in the top, bridge, and bridge plate. TBH 3/16 brace width skeeves me out a bit…
PostPosted: Wed Jun 18, 2025 3:41 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Thanks, Ed. Gonna find out. At least now I can start to build up the top and the back.
Peter Havriluk
PostPosted: Wed Jun 18, 2025 3:42 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Peter Havriluk
PostPosted: Wed Jun 18, 2025 5:19 pm
Last Name: Kincheloe
Sounds pretty dicey to me. Stiffness is proportional to width x height³, so 3/16" width is already quite a lot more flexible than 1/4" width. It also depends on the profile. Sharp triangular is 1/3 the stiffness of rectangular, so there's a large unknown factor there for us guessers. Triangular is popular for its higher stiffness to weight ratio, but you have to increase the height to make up for the loss of stiffness due to the profile. For a triangle and rectangle of equal width, the triangle needs to be 44% taller (cube root of 3) to have equal stiffness, and will be 72% the weight.
PostPosted: Wed Jun 18, 2025 6:57 pm
I’d stick with 9/16” for the X.
