It is currently Fri Jul 18, 2025 8:16 pm
 Post subject: Re: First Sunburst
PostPosted: Tue Jun 10, 2025 8:16 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
My experience has been to just built the coats to reach the number you want, 3 per day. Nitro melts in each day. Then flatten after it cures for a while (a week +). Worked for me.
PostPosted: Tue Jun 10, 2025 8:29 pm
First name: Brad
Last Name: Combs
That turned out great!
These users thanked the author bcombs510 for the post: Kbore (Sun Jun 15, 2025 4:02 pm)
PostPosted: Fri Jun 13, 2025 5:15 pm
First name: Carlos
Last Name: Abadie
Thanks! The burst turned out exactly as I was hoping in terms of colour. With low light the burst looks very dark but una a well lite room you can see the reddish brown and amber colour just melting together.
Update- I’ve sprayed a total of 8 coats of nitro and and I might spray 2 more coats or let it dry for a couple of weeks then start wet sanding and buffing.
Question: how many coats of nitro do you folks typically spray and what grit sandpaper do you start the wet sanding process with? I was thinking of leaving it at 8 coats of nitro and starting with a P1000 wet/dry sandpaper and moving up to 3000 before using the buffing wheel. Also wondering if I should worry about the specs of dust and boogers I got when spraying. I didn’t spray in a booth so it got quite a few “boogers”.
Any help is appreciated!
Carlos
These users thanked the author Deegz for the post: Kbore (Sun Jun 15, 2025 4:03 pm)
PostPosted: Sun Jun 15, 2025 3:52 pm
Carlos
Looks great!
8 coats should be enough as long as it wasn't thinned down too much-You do not want to cut through the lacquer into the color coats-so better safe than sorry....
I would start sanding with 600-with the 1000 you will be there forever.I actually don't go any finer than 600 before buffing
These users thanked the author Brad Goodman for the post (total 2): Deegz (Mon Jun 16, 2025 11:34 am) • Kbore (Sun Jun 15, 2025 4:03 pm)
PostPosted: Mon Jun 16, 2025 11:34 am
First name: Carlos
Last Name: Abadie
Thanks Brad. I didn’t thin the lacquer at all actually and I ended up using the entire quart. I was reading the Mohawk pds sheet and it says I can start wet sanding after 2-3 days. In your experience should I wait for the 3-4 weeks that is usually recommended or can I start wet sanding after a few days?
These users thanked the author Deegz for the post: Kbore (Tue Jun 17, 2025 12:25 pm)
PostPosted: Fri Jun 20, 2025 9:38 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
If you don't wait, the lacquer will continue to shrink back, and any pores or grain, filled by the top coat, may telegraph through the shrunken lacquer. I let my last finish hang for 6 weeks on the advice of Jeff Jewitt.
Measure Twice,
Karl Borum
Users browsing this forum: dofthesea, J De Rocher and 22 guests
