It is currently Fri Aug 22, 2025 10:47 pm
 Post subject: Hashimoto neck issue?
PostPosted: Sun Jun 08, 2025 11:59 pm
First name: Carlos
Last Name: Abadie
Hello
I picked up a 70’s Japanese acoustic the other day with quite an issue. It seems to be pulling apart at the heel of the neck joint where the back meets the sides. When you start putting tension on the strings the heel starts to separate near the back. I’ve attached a photo. Anyone come across an issue similar to this or might have an idea of what the issue might be?
All the best
PostPosted: Mon Jun 09, 2025 8:11 am
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
I don't see the heel separating from the sides in that picture. Instead I see the heel and sides moving together - probably causing the crack in the side just above the binding, and the binding separation you can see.
I'd guess (all one can do from a picture) that the neck block has separated from the back, so the whole neck/blick/sides assembly is rotating upwards. The fix would be to reglue the block to the back, making sure to restore the body/neck geometry correctly.
PostPosted: Mon Jun 09, 2025 2:51 pm
I don't know what the neck joint is on these. They were well made Japanese instruments in the 70's and they have a following. There is a Facebook page for them too if you want to check that out. I've worked on them before but it's been maybe 5 years since I had one on my bench.
There were a number of high-end Japanese Martin clones and some used "pinned" aka "dowelled" neck joints. The Hashimotos were solid wood IIRC.
What's interesting to me is one way to reset these if this is not a dovetail and if it needs a neck reset is to slip the neck block intentionally. It's called in Michigan a California neck reset. In California they call it a Michigan neck reset.
No one wants to own the practice because it's a poor practice that often damages the instrument and caused permanent distortion of the guitars geometry.
I have to wonder is this is damage and if it's actual damage it's a very odd way for a guitar to be damaged. Or, conversely if it needed a neck reset, and it likely would and someone tried to do a California (no offense intended to my California friends ;) ) neck rest by slipping the neck block at the back and things did not result as intended.....
Would love to have a view of what's happening on the inside.
As for restoring the body/neck geometry as Chris suggested that may not be possible if my hunch, that it needs a neck reset is correct. If so it would need the neck removed, refitted, perhaps converted to a butt joint if it was pinned/doweled and then the geometry can be restored correctly. Big job and stuff tends to happen along the way.
It was also sadly finished with the neck on so there will be extensive touch up required as the finish will have to be cut through to remove the neck.
PostPosted: Wed Jun 25, 2025 6:01 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Deegz wrote:
Hello
All the best
Look inside and see what the neck block is up to.
Peter Havriluk
