It is currently Fri Jul 18, 2025 5:41 pm
 Post subject: Neck dimensions.
PostPosted: Fri Oct 04, 2024 10:40 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
I started making the neck for guitar number 2. I don't care for the wide neck i built for #2, so I'd like to change that here. I don't have a modern D28 to measure, and my 1937 plans used a wider neck. Could one of you share the dimensions for nut width and neck at body width?
Sent from my SM-A546V using Tapatalk
Hutch
 Post subject: Re: Neck dimensions.
PostPosted: Fri Oct 04, 2024 11:57 am
First name: Richard
City: Warwick
State: RI
Found it
The Martin D 28 acoustic guitar is made of solid wood, with East Indian rosewood back and sides, and a Sitka spruce top with 5/16” straight (non-scalloped) braces. It has a mahogany low profile neck with a 1-11/16” width at the nut and 2-1/8” at the 12th fret. The guitar has an ebony fingerboard and bridge, and a bone saddle and nut with 2-1/8” string spacing. It has a scale length of 25.4 inches, which is the standard for dreadnought acoustic guitars.
Hutch
These users thanked the author banjopicks for the post: Kbore (Sat Oct 05, 2024 12:43 pm)
PostPosted: Fri Oct 04, 2024 5:22 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I think the specs you found are dated. Martin changed the neck/fingerboard dimensions on dreadnoughts some years ago. Just check the Martin website if you’re looking for the modern (in my mind much improved) specs.
These users thanked the author Tim Mullin for the post: banjopicks (Fri Oct 04, 2024 5:35 pm)
PostPosted: Fri Oct 04, 2024 5:42 pm
First name: Richard
City: Warwick
State: RI
All I can get is the nut width on their site.
Hutch
PostPosted: Fri Oct 04, 2024 8:00 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
I researched neck shapes for months and have an excell spreadsheet with every dimensional detail of every neck that I could find reliable information on. I also bought Martin 000 and D necks from a guy I know that worked at Martin and had cosmetic rejects (knots and deep tool marks).
2006 Martin HD-28 Neck thickness (no fingerboard)
1st Fret: 10th Fret FB Thickness
0.590" 0.626" 0.240" Width of last Fret 2.30
Martin D-28
1st Fret: 10th Fret" FB Thickness
0.580 0.667 .249 FB
Neck Shape: Modified Low Oval; FB @ Nut: 1 3/4''; 2 1/8 @ 12 Fret; Bridge Spacing: 2 5/32"
I posted a pdf of neck shapes a while back. You can cut and paste the profile you want to a pdf file (I attached a 1:1 scale from my printer scaloed at 96%). I printed the Modified Oval file at 96% for it to come out to scale. I glued the paper profiles to a piece of SQUARE plywood for a template and used the osc spindle sander to sand to the middle of the line.
If you scale and print, the profiles have measurements you can verify with a precision scale and, in my case, an optivisor. Modified low oval is the Shape I used. If its not to scale, calculate how far its off and use the print to scale function to scale it 1:1 . THats how I did it.
KEY:
H1 and H2 are called-out/ illustrated on the ..." Technical..." file, attached.
Happy Carving,
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: bcombs510 (Fri Oct 04, 2024 11:04 pm)
PostPosted: Fri Oct 04, 2024 8:04 pm
First name: Karl
Last Name: Borum
More neck information from Martin that is not enough to carve a neck, but good to build a database with:
https://www.martinguitar.com/blog-categ ... apers.html
Measure Twice,
Karl Borum
PostPosted: Sat Oct 05, 2024 5:09 am
martin has about 27 different neck shapes
here is what you need to know to get into the game.
A nut width
standards for martin are 1 3/4 1 11/16
B they measure the taper at the 12th fret
usually
1 3/4 nut 12th fret can be 2 1/4 modern 2 1/8
1 11/16 nut 2 1/8 at the 12 th fret
I like this profile
thickness at the 1st fret with fret board .800
thickness at the 10 th fret .900
I shape the neck with my fretting hand , after all that is the hand that uses the neck
PostPosted: Sat Oct 05, 2024 12:08 pm
First name: Richard
City: Warwick
State: RI
The dimensions you guys are giving me, are not adding up. If I use the 2 1/8 bridge pin spacing and 2 1/8 width at the 12th fret, I end up wit a fretboard that moves away from the string as you get to the end. My hand drawing and Sketchup drawings tell me I need 2" width at the 12th fret and 2 1/8 at the end of the fretboard.
Hutch
PostPosted: Sat Oct 05, 2024 12:49 pm
First name: Richard
City: Warwick
State: RI
These are some dimensions i found, plus the ones my brother measured on his Martin.
Martin neck
Nut 1-3/4
12 fret 2-1/8
Bridge 2-1/8
Gary's neck
Nut 1-5/8
12th fret 2-1/16
Bridge 2-5/32
I haven't tried drawing the Martin dimensions yet. I'm not sure if i want to make as tight of a neck as Gary has on his Model special edition SPDC – 16 R.
Hutch
PostPosted: Sat Oct 05, 2024 1:06 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Load the page for the current model you’re interested in. Go to specs at the bottom of the page. Note the “Load more” button below that to expand the specs. Everything you’ve asked for really is there.
These users thanked the author Tim Mullin for the post: banjopicks (Sun Oct 06, 2024 6:07 am)
PostPosted: Sun Oct 06, 2024 6:07 am
First name: Richard
City: Warwick
State: RI
I've been thinking about this a lot now. I've decided not to copy the SP neck. My thinking is, i like the added space at the nut for clarity. I find i can't get a clean c chord. You know how the first finger wants to mute either the g or e when doing a slow rake.
Im going to follow the modern D28 specs, which maintain the nut spacing I like while reducing the width up the neck compared to the 1937 version that I made.
On to making a fretboard with this in mind.
The other change for this one will be a slotted peghead. I always thought they were more ergonomic and cool looking.
Hutch
PostPosted: Sun Oct 06, 2024 6:08 am
First name: Richard
City: Warwick
State: RI
Got it. Thanks
Hutch
PostPosted: Sun Oct 06, 2024 7:19 am
First name: Richard
City: Warwick
State: RI
OK, I'm satisfied with this now that I've drawn out the modern fretboard.
Hutch
These users thanked the author banjopicks for the post: bcombs510 (Tue Oct 08, 2024 2:16 pm)
PostPosted: Sun Oct 06, 2024 8:32 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Just to clarify: For some designs, having the strings move a bit “inbound” from the edge of the fingerboard as you go up the neck is a feature, not a bug. But you should obviously design it the way you want to. I’ve done it both ways, and both are fine, but it is good to be deliberate about that choice. Some folks get surprised when the spacing in the finished guitar is not what they expected.
These users thanked the author doncaparker for the post: banjopicks (Sun Oct 06, 2024 9:13 am)
PostPosted: Sun Oct 06, 2024 9:16 am
First name: Richard
City: Warwick
State: RI
Don, getting surprised is why I removed the first bridge and plugged the holes on my #1 guitar.. That'll never happen again. I get to use that bridge on this one, though. Yay, a win.
Hutch
PostPosted: Sun Oct 06, 2024 1:34 pm
Back in 2004 at the Fox course we were taught that the spacing at the bridge pins should equal the width at 12. That’s what I have always done.
These users thanked the author Terence Kennedy for the post (total 2): bcombs510 (Sun Oct 06, 2024 2:57 pm) • Kbore (Sun Oct 06, 2024 2:30 pm)
PostPosted: Sun Oct 06, 2024 1:43 pm
Terence Kennedy wrote:
... spacing at the bridge pins should equal the width at 12. That’s what I have always done.
Yep, me too.
These users thanked the author SteveSmith for the post (total 2): bcombs510 (Sun Oct 06, 2024 2:57 pm) • Kbore (Sun Oct 06, 2024 2:30 pm)
PostPosted: Sun Oct 06, 2024 1:50 pm
First name: Richard
City: Warwick
State: RI
Well, im with you fellers.
Hutch
These users thanked the author banjopicks for the post: SteveSmith (Sun Oct 06, 2024 2:14 pm)
PostPosted: Sun Oct 06, 2024 2:30 pm
First name: Karl
Last Name: Borum
banjopicks, I know exactly where you're coming from. I've had a bunch of surprises preparing for my current build.
I've spared everyone the full page journey-for-precision I just wrote in reply, but I saved it in case you run into what I did... :)
Measure Twice,
Karl Borum
PostPosted: Tue Oct 08, 2024 11:59 am
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
After much experimentation this was the best neck we derived when producing many.
Hope this helps.
Blessings,
kw
These users thanked the author Kevin Waldron for the post (total 3): Kbore (Tue Oct 08, 2024 11:57 pm) • bcombs510 (Tue Oct 08, 2024 2:15 pm) • SteveSmith (Tue Oct 08, 2024 2:06 pm)
PostPosted: Tue Oct 08, 2024 3:45 pm
First name: Brad
Last Name: Combs
Looks like you got it sorted. FWIW, I'm using these dims for the dreds in progress:
I'm using the bridge spacing for D28 of 2 5/32" however my FB is a little wider at 2 1/4" rather than 2 1/8" - https://www.martinguitar.com/guitars/st ... SATIN.html
These users thanked the author bcombs510 for the post: Kbore (Wed Oct 09, 2024 12:00 am)
PostPosted: Fri Oct 11, 2024 5:45 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I also follow the rule that the neck width at the 12th fret = the string spacing at the bridge. I find this works well for me, but it is true that this results in the strings being non-parallel with the edge of the fretboard. The “extra” board space outside the strings gets slightly greater as you go up the board, or putting it the other way the strings are further from the edge as you go up. I know some very well reputed and experienced builders use a neck dimension where the 12 fret width is a few millimeters (I guess a 16th of an inch) narrower than the spacing at the bridge.
Users browsing this forum: Bing [Bot], J De Rocher, Ken Lewis and 9 guests
