It is currently Sun Jul 13, 2025 5:50 am
 Post subject: Saddle Slot Angle
PostPosted: Fri Oct 04, 2024 2:05 pm
Last Name: Ensor
City: Springfield
State: Missouri
How do you prefer to set the angle of your saddle slot? Do you calculate the angle? Measure the slope over a certain distance (1/8" over 3" per Cumpiano)? Or some other method?
http://elevatelutherie.com
http://ensorguitars.com
These users thanked the author Chris Ensor for the post: Kbore (Fri Oct 04, 2024 3:31 pm)
 Post subject: Re: Saddle Slot Angle
PostPosted: Fri Oct 04, 2024 2:25 pm
Martin uses a 3 degree angle gibson used under 4 over 3 I find the 3 degree angle with a .1 saddle slot will afford you ample adjustment for intonation compensation I have actually set guitar bridges unslotted and with a drill blank set the strings for the best intonation , that is were I found the slightly wider saddle on a 3 degree angle works pretty well.
I also use .1 compensation length based off the first string and 2.25 on the the bass . So in a nutshell the bass is 1/8 inch longer than the treble.
These users thanked the author bluescreek for the post (total 2): Pat Foster (Fri Oct 04, 2024 9:50 pm) • Kbore (Fri Oct 04, 2024 3:32 pm)
PostPosted: Fri Oct 04, 2024 3:31 pm
Mine is a 4mm offset measured at the e strings…
PostPosted: Fri Oct 04, 2024 6:07 pm
First name: R.M.
Last Name: Mottola
I never actually made use of an angle for positioning the bridge slots of steel string acoustic guitars (there seem to be a lot of different conventions used), relying on the compensation calculations from the Fretted Instrument Bridge Saddle Compensation Calculator https://www.liutaiomottola.com/formulae/compensation.htm on my website, or the plan detail as generated by "G" Thang https://www.liutaiomottola.com/formulae/gthang.htm. So I was curious about this as well. Looking at the output of those tools for a conventional steel string acoustic guitar with typical action and string set, the angle comes in at exactly 3 degrees.
R.M. Mottola
LiutaioMottola.com
Author of the books Building the Steel String Acoustic Guitar, Practical Design of the Acoustic Guitar and Similar Instruments, and Mottola's Cyclopedic Dictionary of Lutherie Terms.
I don't check in here very often. If you need to contact me the best bet is via email through the contact page on my site.
These users thanked the author rmmottola for the post (total 2): Kbore (Sun Oct 06, 2024 2:33 pm) • Pat Foster (Fri Oct 04, 2024 9:50 pm)
PostPosted: Fri Oct 04, 2024 6:36 pm
Always a 1/8” drop back over three inches. With a 1/8” saddle I have never had problems getting good intonation points.
I’ll have to measure the angle.
PostPosted: Fri Oct 04, 2024 8:30 pm
numbers....
1/8" tilt divided by spacing of let's say 2 1/4" = .055555556
take the arc tangent of that and the angle = 3.18*
2 5/16" spacing gives 3.09*
hey, just call it a nice even 3* ;)
over a 3" run you get 2.39*
These users thanked the author Mike_P for the post: Kbore (Tue Oct 08, 2024 9:45 am)
PostPosted: Sat Oct 05, 2024 2:29 am
3 degrees.
These users thanked the author Hesh for the post: Kbore (Sun Oct 06, 2024 2:34 pm)
Users browsing this forum: Ken Lewis and 19 guests
