It is currently Fri Sep 19, 2025 2:43 am
PostPosted: Sun Apr 28, 2024 4:31 pm
I'm having a tough time setting the blade on a small finger plane that uses a wooden wedge to hold the blade.
I'm either too deep or too shallow.
How do you do it?
Formerly know as Mandodiddle.
PostPosted: Sun Apr 28, 2024 5:56 pm
Take a sheet of A4 paper and cut it in half. On a flat bench, put a piece of the paper on each side of the plane mouth. Push the blade to the table, set the wedge, boom, your blade is now set .004 out of the plane sole.
If .004 is too much, you can do the same thing with packing tape on the bench…
These users thanked the author meddlingfool for the post: pkdz (Sun Apr 28, 2024 9:57 pm)
PostPosted: Sun Apr 28, 2024 6:11 pm
First name: Ken
Last Name: Nagy
City: Goodrich
Tap on the back of the plane with a small hammer to move it in. Tap on the front of the plane to set the cut deeper. If it keeps moving in, tap the wedge tighter.
Why be normal?
PostPosted: Sun Apr 28, 2024 6:47 pm
Last Name: Holbert
City: Lyndoch
State: South Australia
Zip/Postal Code: 5351
Here's a video of the process described by Koa above. A bigger plane admittedly, but the process should work. https://www.youtube.com/watch?v=-YiV-v49UVk
Bob Holbert
Lyndoch, South Australia
