It is currently Mon Jul 21, 2025 7:47 am
Post new topic Reply to topic  [ 1828 posts ]  Go to page Previous  1 ... 51, 52, 53, 54, 55, 56, 57 ... 74  Next
PostPosted: Sun Feb 18, 2024 1:53 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I've just completed the woodworking on the sister guitar to the Blackwood one posted above, this time in spruce and Madagascan rosewood (635mm scale also). I built this with a different strutting system based on the playing styles of the respective clients and comparing the tap tone of the two is quite interesting.
These users thanked the author oval soundhole for the post (total 6): Kbore (Mon Feb 19, 2024 7:00 pm) • Hesh (Sun Feb 18, 2024 9:01 pm) • Ken Nagy (Sun Feb 18, 2024 5:36 pm) • bcombs510 (Sun Feb 18, 2024 3:52 pm) • Pat Foster (Sun Feb 18, 2024 2:16 pm) • Chris Pile (Sun Feb 18, 2024 2:05 pm)
PostPosted: Sun Feb 18, 2024 4:02 pm
First name: Brad
Last Name: Combs
Working on the neck for the ziricote 00. If you’re into podcasts, the latest episode of Guitar for Introverts is a good one where Jamie interviews Grant Gordy.
https://youtu.be/syTLWxlytqA?si=iVlFsrIp7gGXWAlP
Brad
PostPosted: Sun Feb 18, 2024 8:13 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
oval soundhole wrote:
Besides being very expensive, African Blackwood also has the distinction of being rather unpleasant to work with. It dulls edge tools immediately, clogs sandpaper rapidly (both the thickness sander and when had sanding), it often has voids that need to be filled, warps and distorts if not aged for a considerable amount of time (even when well quarter sawn like the material I used), it weighs a ton, smells unpleasant when worked, and seems kind of brittle.
Sheesh! As a comedian once said: "But other than that, Mrs. Lincoln, how was the play?" :D
These users thanked the author doncaparker for the post: Kbore (Mon Feb 19, 2024 7:01 pm)
PostPosted: Mon Feb 19, 2024 3:45 am
Last Name: Kincheloe
I find the smell of African blackwood quite pleasant, though it may just be nostalgia. It reminds me of new tires at Western Auto as a child.
It does indeed dull most tools instantly, but I have one old block plane that can stand up to it. I wish I knew what alloy its blade is. Scrapers also work well (mine is from Lee Valley). And humidity expansion is far less than ebony, so if properly aged it is very stable. Brace in low humidity and it won't crack, and won't expand excessively in summer either. It bends easily too, although it does exude a lot of resin that has to be scraped off afterward.
These users thanked the author DennisK for the post: Kbore (Mon Feb 19, 2024 7:02 pm)
PostPosted: Mon Feb 19, 2024 11:32 am
First name: Marcus
Last Name: Bailie
City: Kirkland
Working on an arm bevel on a Maple SJ w/ euro spruce top.
Also finished binding and installing radial purf on this new Sapele OM /w torrified spruce top. Ready to fill some pores!
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
These users thanked the author Marcus for the post (total 6): Doc (Thu Feb 22, 2024 9:13 am) • Hesh (Tue Feb 20, 2024 5:29 am) • J De Rocher (Mon Feb 19, 2024 7:35 pm) • Kbore (Mon Feb 19, 2024 7:02 pm) • SteveSmith (Mon Feb 19, 2024 12:01 pm) • bcombs510 (Mon Feb 19, 2024 11:55 am)
PostPosted: Mon Feb 19, 2024 1:45 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
New tires, that's the smell! I hate it :lol:
Having to resharpen my No 8 twice while jointing the back was incredibly frustrating, especially as the LN iron normaly tends to maintain its edge for quite some time. Even my toothed iron plane needed frequent honing while thicknessing the sides, at 5mm thick I quickly gave up on the drum sander after massive clogging each pass. I have a 19th century Spiers infill plane with a rather high angle Mathieson iron that handled the Blackwood well but that's the only plane in my collection that seemed to be able to take more than 5 consecutive passes. As it's the wood of choice for most woodwinds I'm not surprised at its stability but it took many months of being stickered before I felt comfortable using it. It did bend easily, likely because of the vast amount of resin in the material, it reminded me of Bois de rose in that regard.
These users thanked the author oval soundhole for the post: Kbore (Mon Feb 19, 2024 7:04 pm)
PostPosted: Mon Feb 19, 2024 9:27 pm
Many years ago, LeeValley had a bin with miscellaneous chunks of African Blackwood. I bought a bunch of pieces for dirt cheap every time I went there and ended up with a cubic foot or so. I've made many bridges for both flat top and archtops, a couple of fretboards with the few pieces long enough, archtop end pins, headplates, heel caps, tool handles etc. and still probably have about 20 lbs of it. It turns like nothing else I've worked with on a lathe. Almost like plastic and polishes and buffs up incredibly. I've used 60 grit on my drumsander with very, very light passes for thicknessing but it's definitely a challenge with gumming up things. The smell to me is kind of like rubber and roses. :) I first saw it in Charles Shifflett's shop when he was still building. The classical commission he was doing at the time was 15k and that was over 20 years ago. It's a beautiful wood in the same class (to me) as Brazilian, both being Dalbergia, although much more difficult to work with pretty much any hand tool other than files and scrapers IME. Here's a D'Aquisto inspired bridge using it.
These users thanked the author Darrel Friesen for the post: Kbore (Thu Feb 22, 2024 2:20 pm)
PostPosted: Mon Feb 19, 2024 11:55 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
That's a nice looking bridge! Quite the score at Lee Valley too, Blackwood for pins and pegs sounds like a great idea. I bought a small board from Gilmer a while ago and have used it for head plates and miscellaneous bits and quite like the results. There seems to be a bit of variation in color in the species and the stuff I used appears visually somewhere between ebony and a more typical rosewood like Brazilian. Still a pain to work with but what's art without suffering
These users thanked the author oval soundhole for the post: Kbore (Tue Feb 20, 2024 12:47 pm)
PostPosted: Wed Feb 21, 2024 7:37 pm
First name: Brad
Last Name: Combs
I dig the Osmo oil. :)
Brad
These users thanked the author bcombs510 for the post (total 2): Kbore (Thu Feb 22, 2024 2:17 pm) • Ken Nagy (Thu Feb 22, 2024 9:06 am)
PostPosted: Thu Feb 22, 2024 9:20 am
First name: Ken
Last Name: Nagy
City: Goodrich
Ever have one of those days where things just get done?
Yesterday I finished up a mold for a larger viola to use the birds eye back I have. I don't know why the outline is wrong on the right side! It fits the template. Good thing I didn't file to that.
I got the form for the archtop smoothed out. The inside to use as the base for carving, and to mark stock for cutting out backs and bellies. The outside to hold the plates for carving, and to use to bend and glue up the sides.
I marked where the back needs to be cut, so it will fit in the form as a carving holder.
I got the belly cut to the form, and it sits both ways.
I got the outline of the cedar/mahogany viola carved about 2.5mm from the ribs, or less. It was just roughed out.
I started a tailpiece.
Every time I'd finish something, I'd say. "Wow, it's only 2,3,4, o'clock!"
Why be normal?
These users thanked the author Ken Nagy for the post (total 3): Kbore (Thu Feb 22, 2024 2:21 pm) • bcombs510 (Thu Feb 22, 2024 10:18 am) • Chris Pile (Thu Feb 22, 2024 9:41 am)
PostPosted: Thu Feb 22, 2024 9:42 am
Pretty much the story of my life (it feels like).
PostPosted: Thu Feb 22, 2024 2:20 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Brad
I had just watched your Osmo video, EDIT: https://www.youtube.com/shorts/6xRU0bm_ ... ture=share
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: bcombs510 (Thu Feb 22, 2024 3:28 pm)
PostPosted: Sat Feb 24, 2024 3:02 pm
First name: Brad
Last Name: Combs
Picked up some of the good stuff from Brad Goodman via the classified. Future me thanks current me. :D
Brad
These users thanked the author bcombs510 for the post (total 3): Kbore (Sun Feb 25, 2024 8:44 am) • Hesh (Sun Feb 25, 2024 4:43 am) • SteveSmith (Sat Feb 24, 2024 4:23 pm)
PostPosted: Wed Feb 28, 2024 11:43 pm
Okay - it's not a build, but it's an assembly for a client. He wanted something new, so I put together a Warmoth body and neck, along with some random parts. Duncan Pearly Gates in the bridge, and a Guitar Madness Firebird unit in the neck. Plays great. Al Bacon (fumblefinger) wired it up for me, and now it sounds killer. Client is picking it up in the morning. I did some fretwork on one of his Taylors, too. Glad to be at the bench again.
https://i.imgur.com/VQIN3q2.jpg
These users thanked the author Chris Pile for the post (total 5): Kbore (Tue Mar 05, 2024 11:47 am) • Robbie_McD (Thu Feb 29, 2024 12:11 pm) • Ken Nagy (Thu Feb 29, 2024 7:44 am) • Hesh (Thu Feb 29, 2024 4:48 am) • bcombs510 (Thu Feb 29, 2024 12:37 am)
PostPosted: Fri Mar 01, 2024 8:28 pm
First name: Brad
Last Name: Combs
Thanks to the fine folks here at the OLF, tuners are in! Love those custom ziricote buttons!!
Brad
These users thanked the author bcombs510 for the post (total 5): Durero (Wed Mar 06, 2024 10:52 pm) • Kbore (Tue Mar 05, 2024 11:46 am) • Chris Pile (Sat Mar 02, 2024 12:27 am) • J De Rocher (Fri Mar 01, 2024 9:08 pm) • doncaparker (Fri Mar 01, 2024 8:38 pm)
PostPosted: Mon Mar 04, 2024 5:41 pm
First name: Brad
Last Name: Combs
First one through the three wet stack schedule. Let’s see how it goes.
These users thanked the author bcombs510 for the post (total 3): Hesh (Fri Mar 08, 2024 10:19 pm) • Kbore (Tue Mar 05, 2024 11:46 am) • Chris Pile (Tue Mar 05, 2024 2:31 am)
PostPosted: Thu Mar 07, 2024 7:49 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
It's time to glue the bridge on.
These users thanked the author J De Rocher for the post (total 3): Kbore (Fri Mar 08, 2024 7:15 pm) • Chris Pile (Thu Mar 07, 2024 9:55 pm) • bcombs510 (Thu Mar 07, 2024 8:11 pm)
PostPosted: Fri Mar 08, 2024 10:40 am
First name: Josh
Last Name: French
City: Houston
Finished the woodworking on this 635mm scale Alpine spruce and African Blackwood guitar with Malagasy ebony appointments and Brazilian Rosewood bridge. Now to start French polishing!
Beautiful instruments, both of them! Tastefully appointed and a very clean look. I especially like how you've treated intersection of the purflings and heel cap, as well as the rosettes. It's too bad the Blackwood is so difficult on tools, but you make the effort look well worth the pain.
Instagram: @jfrenchluthier
PostPosted: Fri Mar 08, 2024 7:40 pm
First name: Brad
Last Name: Combs
Can’t wait to hear it, Jay!
I upgraded the story stick with a vacuum drill jig for bridge placement. The story stick is 24.75” + compensation and was supposed to be a prototype. It has worked so well I’m just going with it!
Here is the gasket on the bottom. It’s a sheet that comes from all star CNC. I covered the entire thing with gasket and made a little template to mark and cut away what isn’t needed.
Brad
These users thanked the author bcombs510 for the post (total 5): Durero (Sat Mar 09, 2024 2:00 pm) • Kbore (Sat Mar 09, 2024 10:02 am) • Pat Foster (Sat Mar 09, 2024 1:27 am) • Hesh (Fri Mar 08, 2024 10:18 pm) • Chris Pile (Fri Mar 08, 2024 9:04 pm)
PostPosted: Sat Mar 09, 2024 8:22 pm
That's some fancy and cool stuff Brad. I don't build enough to warrant changes from traditional clamping at this time but great to see how others are doing things.
These users thanked the author Darrel Friesen for the post: bcombs510 (Sun Mar 10, 2024 5:47 pm)
PostPosted: Sun Mar 10, 2024 5:41 pm
Last Name: Ball
I’ve been working on an Acoustasonic style offset acoustic electric. Got the top cut out and the sound hole and rosette done.
I also did my first try at laser cutting braces. Obviously a lot of cleanup and shaping to go, but it took less than a minute and I’m pleased with the results. I’ll be doing that again.
These users thanked the author ballbanjos for the post (total 5): Durero (Tue Mar 12, 2024 4:09 pm) • Kbore (Mon Mar 11, 2024 9:38 am) • Hesh (Mon Mar 11, 2024 4:29 am) • SteveSmith (Sun Mar 10, 2024 6:39 pm) • bcombs510 (Sun Mar 10, 2024 5:47 pm)
PostPosted: Sun Mar 10, 2024 6:02 pm
First name: Brad
Last Name: Combs
Nice Dave! I had to look up Acoustasonic, that’s a cool shape and the elongated soundhole compliments it nicely!
I made it to the buffer with the Khaya 00 I showed in the zoom meeting yesterday. I still have some more time at the buffer needed but I think the new spray technique is going to work out.
Brad
These users thanked the author bcombs510 for the post (total 2): Durero (Tue Mar 12, 2024 4:10 pm) • Kbore (Mon Mar 11, 2024 9:38 am)
PostPosted: Sun Mar 10, 2024 6:05 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Flew out to Copenhagen this weekend to help a friend resew some old rosewood he bought at an estate auction. As his shared workshop was quite busy on Friday we only had Saturday to get to work, hardly a bad thing as I greatly enjoyed a day of cycling, eating, and drinking my way around the city. We only managed 5 sets and likely have another few dozen to go; a good excuse to visit Denmark again this Autumn!
These users thanked the author oval soundhole for the post (total 5): Durero (Tue Mar 12, 2024 4:10 pm) • Hesh (Mon Mar 11, 2024 4:28 am) • Pat Foster (Sun Mar 10, 2024 7:02 pm) • SteveSmith (Sun Mar 10, 2024 6:40 pm) • bcombs510 (Sun Mar 10, 2024 6:17 pm)
PostPosted: Sun Mar 10, 2024 8:52 pm
That's some beautiful looking rosewood!
These users thanked the author Darrel Friesen for the post: Kbore (Mon Mar 11, 2024 9:36 am)
PostPosted: Mon Mar 11, 2024 8:21 pm
I love carving necks. Left enough meat to carve a Martin dart/diamond. John Hall's video was very helpful especially the long sanding stick as I progress to the carving, along with some good pics from online and the Stewmac plan.
These users thanked the author Darrel Friesen for the post (total 6): Hesh (Tue Mar 12, 2024 4:04 am) • Chris Pile (Mon Mar 11, 2024 11:09 pm) • Craig Wilson (Mon Mar 11, 2024 9:58 pm) • J De Rocher (Mon Mar 11, 2024 9:34 pm) • SteveSmith (Mon Mar 11, 2024 9:11 pm) • bcombs510 (Mon Mar 11, 2024 8:51 pm)
Users browsing this forum: Chris Ide and 31 guests
