It is currently Sun Jul 20, 2025 5:44 pm
 Post subject: Design Choice For Table
PostPosted: Fri Sep 01, 2023 1:08 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I'm making a combination drafting table / plan storage display. I have it almost done and figured out, but now I thought of this:
It is 32" deep, and 48" wide. A 1 1/8" or so wide frame glued on the top, to keep the plans in, and the plastic, hardboard on the top, It should work great.
But I started thinking. Always the start of trouble.
If I tilt it, so the front drops down about 5 inches, the plans will look better. Drafting would be easier. And I don't gain another "table" to catch stuff! If it is flat, the back of wide plans would be harder to see, and maybe harder to draw. But I gain a table to hold stuff.
The wedge on the wall would be a bit over 3" so I need to have different length screws. I'm going into 2" furring strips on a concrete wall, so I'd want to size each one.
i'm leaning toward tilt.
Why be normal?
PostPosted: Fri Sep 01, 2023 2:20 pm
I did some analog drafting for mechanical design in another life, and I was thnkful for tilt every time I used it. I suspect you'll regret the lack of tilt more than you'll regret the lack of the table. If it were me, I'd go for the tilt. But then, YMMV.
PostPosted: Fri Sep 01, 2023 2:29 pm
Online
City: U.P.
I think I'd make it adjustable from a flat table all the way to vertical. That way you have a multipurpose table/display you can put against the wall when not in use and adjust it to whatever angle is most comfortable for any purpose.
Brian R, Wood Mechanic
N8ZED
PostPosted: Fri Sep 01, 2023 3:42 pm
First name: Ken
Last Name: Nagy
City: Goodrich
Well it is a folding table.
https://www.rockler.com/rockler-rock-st ... l-brackets
I found my answer for sure looking at the instructions. (silly thing to do) They say the maximum size of the table is 40" x 26"! So it ISN'T a table. Angled at 9 degrees.
They rate it at 500 pounds at that size. I won't have anything like that on it; especially tilted.
Yeah, I was thinking tilt for the drafting especially.
Why be normal?
PostPosted: Fri Sep 01, 2023 5:01 pm
When I realized it didn't include the work surface, but was just a couple of adjustable brackets I think it would go from "buy" to "make". A pair of hinges, four bolts, a 2X2 or 2 and some drillable scrap metal could allow you to make brackets that could hold the size top you originally wanted.
PostPosted: Fri Sep 01, 2023 6:22 pm
First name: Ken
Last Name: Nagy
City: Goodrich
Clay,
The design of the mounts is very robust. I don't have any doubt at all that the drafting table/plan display/storage will work just fine. I'm not pounding on it, or mounting a router!
Why be normal?
PostPosted: Sat Sep 02, 2023 9:39 am
You are probably right , Ken.
I hadn't noticed the levers to release the adjustment mechanism until I took a second look. I have always been leery of slots rather than discrete detents or holes for repositioning the brackets - often they slip under load. I would be curious to know how those release levers work.
PostPosted: Sat Sep 02, 2023 10:52 am
Online
City: U.P.
Thanks for posting that link Ken.
I especially liked the customer photos of different ways to use the brackets with a table saw. I have extensions on mine I wish were "foldable" to reduce the footprint in my always too small shop.
That may just find a way into my workspace.
N8ZED
PostPosted: Tue Sep 05, 2023 8:11 am
First name: Ken
Last Name: Nagy
City: Goodrich
I finished the table / plan storage/display box up yesterday. The basement walls were partially finished around it when me moved in 30 years ago.The back third just has furring strips. We have had 3 times where the sump pump went, or power went out, on the rare times when the water level is high. Once in an ice storm before Christmas when it was out for almost a week. The basement is usually very dry for a basement. So the paneling is off on some of the bottom. That worked good, because it was easier to mount the tapered 2 X 4 to mount the supports on an angle.
I laid out the placement of the support on the bottom of the table, and drilled 4 small holes for the screws closest to the edge. They were too far in for any of my clamps to reach. So I started the screws in by hand, holding the table so it wouldn't roll off; and then tightened them with the drill. One of the hardest steps besides getting under it, and screwing in the dozen other screws.
It closes easily pulling back on the levers, and gently lifting up. It raises with a satisfying click on each support at exactly the same time.
I'm pretty happy with it. Maybe it needs a rail to keep pencils from falling off. The brass thumb nuts on the bolts in the middle, are easier to remove when the table is down. Then raise it, and get the rest off.
Why be normal?
These users thanked the author Ken Nagy for the post (total 3): Clay S. (Tue Sep 05, 2023 9:36 am) • bcombs510 (Tue Sep 05, 2023 8:22 am) • Chris Pile (Tue Sep 05, 2023 8:21 am)
PostPosted: Tue Sep 05, 2023 8:21 am
Looks to be all kinds of clever / useful.
PostPosted: Tue Sep 05, 2023 8:49 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I like that. I need to figure out where I have space to copy it.
Users browsing this forum: Facebook [Bot], rbuddy and 14 guests
