It is currently Tue Jul 08, 2025 9:15 pm
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Back to work #2 body
PostPosted: Fri Jul 28, 2023 7:54 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Walnut or mahogany are my only choices. I think mahogany will look better against rosewood. Before I build another guitar, I'll have to invest in some wood for bindings and kerfed linings. I think the walnut kerfed linings look pretty good though. I finished gluing those in this morning so It's time to start the back. I'm waiting on delivery of the back strip and other things.
Hutch
These users thanked the author banjopicks for the post: CraigG (Sun Aug 06, 2023 3:33 pm)
PostPosted: Fri Jul 28, 2023 8:00 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I like maple for binding against rosewood. If you can cut and thickness wood with accuracy, you can use a 3 foot maple board from Menards.
PostPosted: Fri Jul 28, 2023 8:25 am
First name: Richard
City: Warwick
State: RI
I have maple but it's kind of boring, not much figure. I'll go see what they have at Lowes today. You never know. I have a nice thickness sander so making bindings is a breeze.
Hutch
PostPosted: Thu Aug 03, 2023 8:00 am
First name: Richard
City: Warwick
State: RI
Getting read to glue up the top and back. I have an old window that someone was throwing away and it's perfect for checking the seams. As hard as I try, I can never get them perfect off the plane so I stuck some 240 grit on the glass and got it perfect. I'll keep trying with the hand planes on future guitars.
Hutch
PostPosted: Thu Aug 03, 2023 9:38 am
I plane one half of the plate at a time. If you plane both, any inaccuracy in the cut is doubled in the finished joint.
PostPosted: Thu Aug 03, 2023 11:39 am
State: West Somerset
Country: UK
First those plane shavings look too thick. You need to just take whiskers off.
Barry a well known technique from general woodworking is to reverse one of the boards, ie have them face to face, then any slight angle in the planing is reversed on the other edge so they go together fine.
Cheers Dave
PostPosted: Thu Aug 03, 2023 11:47 am
Country: UK
https://brfinewoodworking.com/edge-join ... ng-method/
This is a good description of the technique. Dave
PostPosted: Fri Aug 04, 2023 6:13 am
First name: Richard
City: Warwick
State: RI
I came up with a new idea for clamping the top and back halves. I was going to make board to do this when I spotted the tablesaw. Bingo, this works great and zero extra fixtures cluttering the shop. I may save the shims.
Hutch
PostPosted: Sat Aug 05, 2023 7:27 am
First name: Richard
City: Warwick
State: RI
Somehow, yesterday's glue up of the top went awry so I cut it apart and re glued the way that worked in the past. No shims, just enough space between stops to make a tent and forced down and taped and weighted. I also got the joint perfect off the plane, a #3 instead of the 5 worked much better.
The back I did in sections taping the strip to one half and waiting 20 minutes and added th we other half. It was a bit of a pain gluing these potato chips but not to bad using tape and clamping the ends.
Hutch
PostPosted: Sat Aug 05, 2023 9:06 am
Cheers Dave
I have often wondered why we don't do this and intentionally angle the plane to make a scarphed lap joint to give the center seam a greater gluing surface.
PostPosted: Sat Aug 05, 2023 9:56 am
First name: Richard
City: Warwick
State: RI
Yeah they were much heavier than the wispy tissue paper ones I set #3 for. It made all the difference. I liked the feel of the small plane for this job.
Hutch
PostPosted: Sat Aug 05, 2023 10:28 am
Country: UK
Glad you managed to plane the edges. People who know about these things insist that freshly planed surfaces make a much stronger glue joint - like around 10 minutes or so. The roughness of sanded surface impedes the glueing.
In theory the longer the plane the easier it is to get a flat surface. However you've got the issues of how to hold it sideways on the shooting board and control it. I personally like my 5 1/2 but I have practised it quite a lot. I will drop down to a shorter one to correct minor problems.
Clay I guess to get a significant increase in glueing area would require a pretty severe angle and we would then get problems of the boards trying to slide past each other...
Cheers Dave
PostPosted: Sat Aug 05, 2023 11:05 am
First name: Richard
City: Warwick
State: RI
I didn't bother with shooting board. I put them in my vise. Because they don't need to be perfectly square, there's no need for the board. As long it's perfectly flat I'm good to go. I would like to find a good straight edge for testing that
One that won't break the bank.
Hutch
PostPosted: Sun Aug 06, 2023 6:11 am
First name: Richard
City: Warwick
State: RI
Second try at gluing this up. My first attempt failed and was easily snapped apart s9 I needed to come up with a way of keeping the boards flat and adding pressure. We'll see if this is any better tomorrow.
Kids, don't leave your records in the sun, or let your rosewood dry into a potato chip.
Hutch
PostPosted: Mon Aug 07, 2023 5:36 am
First name: Richard
City: Warwick
State: RI
I won this battle.
Onward with bracing and rosette. I'll start that tomorrow. I need to give my knee another day of recovery.
I need to mark my boards better, I got the wrong orientation on them. I don't think it will be too bad though.
Hutch
PostPosted: Tue Aug 08, 2023 8:43 am
First name: Richard
City: Warwick
State: RI
I didn't accomplish much this morning, I overslept. I did locate my circle cutters. The one on the left I found at a yard-sale. I don't know if it's better or worse than the one I built. Neither one has a fine adjustment on them. Anyway, the rosette install is somewhat in process now.
Hutch
PostPosted: Wed Aug 09, 2023 8:07 am
First name: Richard
City: Warwick
State: RI
I spent a lot of time setting up the jig on the left, I kind of like it. I also spend a ridiculous amount of time drawing circles this morning only to erase them to try again tomorrow. 1 and 1/2 hours later, not much done.
One lesson learned this morning is, when using calipers to scribe the circles, if the center mark is more than a pin prick, the lines will be off. I think tomorrow I won't even bother with lines and just start cutting on scrap and see where it takes me. I've done this before but can't remember the exact steps but I know it wasn't this difficult.
Hutch
PostPosted: Wed Aug 09, 2023 3:51 pm
Last Name: Parker
City: Charleston
Hutch--
Here is what I do to avoid the imprecision of pencil lines and scribed circles. If I know that my center pin is 1/4" in diameter, and if I know that my cutting bit is 1/8" in diameter, then if I use a dial caliper to measure the distance between the closest edges of those two round pieces of metal, and employ some math, then I have a very precise way to cut channels exactly where I want them to be. For instance: To cut a 1/8" wide channel with a 1/8" diameter bit, and have that channel be 1/8" away from the edge of the 4" diameter soundhole, I can compute my way to the precise setting for my circle cutting jig as follows. The inner edge of that channel is 2.125" from the center point, and the outer edge is 2.25" from the center point. The inner edge of that channel will be defined by the inside edge of the cutting bit. I subtract half of the diameter of the center pin (0.25" diameter center pin, so 0.125" subtracted) from the 2.125" figure I just mentioned. That is 2". I set the dial caliper for that measurement. I then adjust the circle cutting jig to where the center pin and cutting bit are exactly that amount away from each other, as determined by the dial caliper. As long as my math is correct (that's always the thing to worry about), the channel will be exactly where it is supposed to be. It is a good idea to put some "sanity check" lines on the top where the fingerboard extension will go, just to make sure your math is not off. But don't adjust the jig to the lines; use the math to set the jig. Anyway, that's how I do it. I hope that is helpful.
PostPosted: Wed Aug 09, 2023 7:34 pm
doncaparker wrote:
Hutch--
Here is what I do to avoid the imprecision of pencil lines and scribed circles. If I know that my center pin is 1/4" in diameter, and if I know that my cutting bit is 1/8" in diameter, then if I use a dial caliper to measure the distance ....
I do it the same way. Making fine adjustments is a snap with a Wells-Karol type jig - I highly recommend that everyone make one. A single turn on the 1/4-20 adjustment screw is 0.050" which makes it easy to dial in the exact width you need on your rosette channels.
PostPosted: Thu Aug 10, 2023 7:44 am
First name: Richard
City: Warwick
State: RI
Not having an adjuster is a huge PIA. Before the next one I'll make an adjuster for mine or I may have a CNC by then. Do you have a picture of your Well-Karol jig?
I got it done the hard way, tapping it into submission with a hammer. I just need to do a little clean up and glue it in tomorrow morning.
Hutch
PostPosted: Thu Aug 10, 2023 8:20 am
Here's one - http://wellsguitars.com/Available_Instruments/Luthier_Tools.html
PostPosted: Thu Aug 10, 2023 8:42 am
First name: Richard
City: Warwick
State: RI
Thanks. I think I can make one of those. I'd be very happy to toss the Dremel and use my Dewalt.
Hutch
PostPosted: Thu Aug 10, 2023 8:51 am
Sylvan's price ($125) is not too bad although they are pretty easy to make.
PostPosted: Thu Aug 10, 2023 9:10 am
First name: Richard
City: Warwick
State: RI
I agree the price is good but, if I can make it myself, that's more money left for materials for the next instrument.
Hutch
PostPosted: Thu Aug 10, 2023 9:24 am
First name: Brad
Last Name: Combs
Here is a thread where I showed pics of the one I made and a link to the video from Chris showing how to make it. His video (3 parts total I believe) takes you step by step.
viewtopic.php?t=55775
Users browsing this forum: eflottman, Glen H and 16 guests
