It is currently Tue Jul 22, 2025 9:04 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Thu Dec 22, 2022 11:30 pm
First name: Brad
Last Name: Combs
Sunburst test #3 - Jeff refers to this recipe as a traditional burst used by Gibson. This one uses pigment instead of stain for the dark color. This results in a more opaque border. I didn’t like it at first but after adding the 3rd coat with the reddish color I really started to like it. One more test recipe tomorrow, my own recipe, and then on to putting it on an instrument.
Brad
PostPosted: Fri Dec 23, 2022 8:47 pm
First name: Brad
Last Name: Combs
Clay S. wrote:
I would topcoat at least one of the test tops to see how it looks with the dye and shellac. Probably not necessary, but I would do it anyway.
Thanks again for suggesting this, Clay. I did take two all the way to the buffer today. It uncovered some things that I might not have thought about.
- I have to make sure the lock in coats are good quality, wet coats. I was a little nervous about putting the topcoats down and so was spraying very (a little too) light and dry. When I went to scuff the “iced tea” burst in order to spray topcoats I had some scratches go past the dark edge and exposed the lighter color. I’ll need to keep this in mind on a real instrument.
- Buffing just a top plate is an adventure. :D
All in all I’m pretty happy with all the tests and I’m pretty confident that I can do a sunburst on an instrument.
Brad
PostPosted: Fri Dec 23, 2022 9:53 pm
You're doing well Brad. Some excellent looking bursts!
These users thanked the author Darrel Friesen for the post: bcombs510 (Fri Dec 23, 2022 10:22 pm)
