It is currently Sun Apr 20, 2025 8:36 pm
 Post subject: Band Saw Recommendations
PostPosted: Sat Jun 18, 2022 10:44 am
First name: David
City: Napa
Zip/Postal Code: 94558
Hello all,
I'm looking for band saw recommendations. I'd like to be able to do a little resawing when necessary. Maybe in the $2,000 range, but not a requirement.
PostPosted: Sat Jun 18, 2022 4:08 pm
If you’re looking for something with a smaller footprint, the Laguna 14SUV is pretty nice. I resaw with it frequently and it does a great job, if paired with the Resaw King blade. The downside is that the blade is 250$ and is basically the only blade available that will effectively run on its for resaw. Other blades can’t handle the 14”wheels without fatiguing. Rikon makes a similar saw, but the Laguna has ceramic guide blocks.
If size is not an issue I would certainly look for a bigger one…
These users thanked the author meddlingfool for the post: dofthesea (Sun Sep 18, 2022 10:10 pm)
PostPosted: Sat Jun 18, 2022 4:33 pm
Last Name: Ball
I have an 18 inch JET that I've used for years--I put Laguna ceramic guide blocks on mine--the stock guides were pretty bad. I'm quite happy with it. It resaws fine--I use a 3/4 inch Infinity Rip blade. I don't do a lot of resawing though.
Edit--I'll add that for me, moving from a 14" saw to an 18" saw was more about throat depth than it was resaw capacity. Banjo pegheads are cut perpendicular to the fingerboard surface, not the peghead face. I needed more throat depth to cut some of these without running the shaft of the neck into the other side of the saw while cutting pegheads. A couple of buddies of mine have the high end Laguna 14" saws, and they're really nice. If I didn't need the extra throat depth, and if they had been available at the time, they would have probably been my choice.
These users thanked the author ballbanjos for the post: dofthesea (Sun Sep 18, 2022 10:10 pm)
PostPosted: Sat Jun 18, 2022 4:52 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I bought one of these used, and I like it:
https://www.woodcraft.com/products/jet- ... LEQAvD_BwE
It’s a Jet 14” bandsaw with extra features, like a riser block and bearing blade guides, already on there, so you don’t have to add them. It does fine for anything I do that is guitar related. I resaw neck blanks with it, but I don’t try to resaw tops or backs. Maybe it could handle those, but I haven’t tried. It’s a decent quality bandsaw. There are better ones out there, but they cost more.
These users thanked the author doncaparker for the post: dofthesea (Sun Sep 18, 2022 10:11 pm)
PostPosted: Sun Jun 19, 2022 8:20 am
First name: Tom
Last Name: Armstrong
City: Portsmouth
Zip/Postal Code: 23701
I have a first generation Rikon 18”. It didn’t receive good reviews due to its tensioning mechanism but after 15+ years I’ve had no issue with that. Not sure of their customer service today but when I bought the saw it was not starting without making a humming noise like it was straining to start. I contacted their CS who transferred me to an engineer. He listened to it start (over the phone) and diagnosed it as a bad capacitor. Within three days they sent me an entirely new motor. I bought and changed the capacitor and the new motor still sits in my shop unused.
I have resawn many a side and back set using a Lenox Woodmaster 3/4” blade. Cuts like a champ even after all these years.
These users thanked the author Gasawdust for the post: dofthesea (Sun Sep 18, 2022 10:11 pm)
PostPosted: Sun Jun 19, 2022 10:04 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
+1 on the Rikon 18” with the Lenox Woodmaster blade. I’ve had one for a long time. It’s adequate for resawing. Now, I might spend twice as much as I did then for a better saw, but I don’t know what it would be. I kept a 12” saw for the finer stuff so I don’t have to change blades for different tasks.
Before I bought the Rikon, I was using a Delta clone (Buffalo) with a riser block. It wasn't up to serious resawing—the frame flexed and it couldn’t handle carbide blades.
These users thanked the author bobgramann for the post: dofthesea (Sun Sep 18, 2022 10:11 pm)
PostPosted: Tue Jun 21, 2022 1:03 pm
First name: Grant
I use a 17" 2hp Grizzly with a 3/4" Timberwolf blade for resawing and it does a fantastic job. The default blade guides on the saw arent great, specifically the top guide for the back of the blade. It could just be that the one on my saw is worn from the previous owner too. Either way, its a fairly easy fix with some good third party replacement options available.
PostPosted: Tue Jun 21, 2022 6:32 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Rikon!
period
Mike Collins
PostPosted: Tue Jun 21, 2022 7:03 pm
First name: John "jd"
City: Santa Barbara
In my experience Timberwolves blades are short lived junk. Once the start to warm up they lose their set and then they really get hot and fail. On my saw Lennox dimaster blades last many times longer and give cleaner cuts
PostPosted: Wed Jun 22, 2022 9:45 am
If you have a comfort with some level of tinkering I'd look at older machines. $2,000 could get you quite a nice larger vintage bandsaw that would outperform a newer one if tuned up nicely.
Burton
Brookline, MA.
These users thanked the author Burton LeGeyt for the post: dofthesea (Sun Sep 18, 2022 10:11 pm)
PostPosted: Thu Jun 23, 2022 12:17 pm
Check out the Harvey bandsaws. They get great reviews on the woodworking groups. The 14" Ambassador is 3 HP, almost 400 lbs and under 2k. I'd buy one over a Laguna.
https://www.harveywoodworking.com/colle ... dkEALw_wcB
PostPosted: Thu Jun 23, 2022 1:31 pm
TBH, that Harvey looks like a rebadged Laguna. Same saw…
PostPosted: Thu Jun 23, 2022 7:08 pm
Harvey built a large amount of Pacific rim tools to various levels of quality including many Laguna models. It's what you spec. The best Harvey's are as good as the best Italian Laguna's by all accounts.
PostPosted: Sat Jun 25, 2022 4:01 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Question for OP: How important is a resawing capability? Saws mentioned are beautiful machines, weigh a ton and cost a fortune. If resawing is a someday possibility, I suggest leaving it to the future and buying a saw that will do everything but resawing nicely. Less than $500 all day. I did just that and my Rikon's very useful for everything but resawing. Besides if resawing does become needed, the saw may well stay set up for resawing, leaving the non-resaw available for what it does (everything but resawing).
A thought. And you have it tomorrow.
Peter Havriluk
These users thanked the author phavriluk for the post: rbuddy (Sat Jun 25, 2022 5:11 pm)
PostPosted: Sat Jun 25, 2022 6:34 pm
First name: David
City: Napa
I really need to be able to resew. I have a ton of billets that I've been storing.
PostPosted: Sat Jun 25, 2022 7:26 pm
City: U.P.
This was a good thread from a year ago ——- viewtopic.php?f=10101&t=54606&p=716915&hilit=Bandsaw+recommendations#p716915
Covered a lot of ground.
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: dofthesea (Sun Sep 18, 2022 10:12 pm)
Users browsing this forum: Chris Ide and 29 guests
