It is currently Tue Sep 16, 2025 9:03 pm
PostPosted: Wed Jan 12, 2022 7:07 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
This has been something I find really frustrating. What is the best way to make a concave carve. And to ensure that it transitions smoothly onto the "landing surface"?
PostPosted: Wed Jan 12, 2022 11:19 pm
First name: Hans
Last Name: Mattes
City: Petaluma
Zip/Postal Code: 94952
CNC
These users thanked the author Hans Mattes for the post: Conor_Searl (Thu Jan 13, 2022 12:13 pm)
PostPosted: Wed Jan 12, 2022 11:31 pm
https://www.woodline.com/collections/ro ... ovolo-bits
These users thanked the author Clay S. for the post: Conor_Searl (Thu Jan 13, 2022 12:13 pm)
PostPosted: Thu Jan 13, 2022 12:36 am
Clay - that's convex - not concave.
Conor, I've used ballnose router bits, rat tailed files, sandpaper over round shapes, and even scrapers. It's a lot of work, and looks great if you are patient and careful.
These users thanked the author Chris Pile for the post: Conor_Searl (Thu Jan 13, 2022 12:13 pm)
PostPosted: Thu Jan 13, 2022 1:01 am
Kutzall have a wide range of shapes and sizes.
Brent
PostPosted: Thu Jan 13, 2022 12:12 pm
First name: Conor
Last Name: Searl
City: Duncan
Hans Mattes wrote:
CNC
Haha, thank you, that's helpful. Barring access to tools that require a large-ish investment, what's the best way to make a concave carve? Or to put it another way, how did people do it efficiently before the advent of the CNC machine?
PostPosted: Thu Jan 13, 2022 12:16 pm
First name: Conor
Last Name: Searl
City: Duncan
Clay S. wrote:
https://www.woodline.com/collections/roundover-beading/products/plunging-roundover-ovolo-bits
Thanks, I thought about router bits, but I'm working with a finished body, and some different angles. While I could jig something up, doing it by hand seems simpler, and its a task that's come up several times lately and I've just not been happy with my methods.
PostPosted: Thu Jan 13, 2022 12:18 pm
First name: Conor
Last Name: Searl
City: Duncan
Thanks Chris, I've never used ball nose router bits, but I've been working my way through your other suggestions. I don't mind a lot of work, and I have the patience, just wondering if I can refine my methods.
PostPosted: Thu Jan 13, 2022 1:04 pm
First name: Freeman
Last Name: Keller
Conor, I am building a carved top archtop right now and have been using a little Ibex finger plane for all the inside of the top and the recurve. I did the trick of drilling contour lines as described in Bob Benedetto's book and use the little plane to connect the dots
My plane might be a little small for archtop guitars but I think it is perfect for a mandolin or maybe a violin.
These users thanked the author Freeman for the post: Conor_Searl (Thu Jan 13, 2022 1:35 pm)
PostPosted: Thu Jan 13, 2022 1:10 pm
Online
Last Name: Kincheloe
You're already almost all the way there. Get your chisel super sharp so you can take ultra-fine shavings and just do it.
As others have said, a router bit with the proper profile is the way to do it quickly and precisely. Before routers, I suspect people simply avoided such features, or accepted the imperfect surfaces of hand carving.
Another potential approach would be to craft the object as two pieces and then glue together. That way the round-over could be done with files, and the bottom of the pocket would be part of the planed surface of the other piece.
These users thanked the author DennisK for the post: Conor_Searl (Thu Jan 13, 2022 1:35 pm)
PostPosted: Thu Jan 13, 2022 3:48 pm
https://www.eagleamerica.com/product/vp ... r-bit-sets
one of those with the top bearing could be used with a pattern/template to pull that off...3/16" is the smallest radius though
PostPosted: Thu Jan 13, 2022 5:47 pm
First name: Conor
Last Name: Searl
City: Duncan
Mike_P wrote:
https://www.eagleamerica.com/product/vp13-2307/router-bit-sets
I want that inverted though. I don't like the rounded thing in this case, I'd rather the curve was concave. I feel like it willmake the transition flow better.
PostPosted: Thu Jan 13, 2022 7:01 pm
How did I forget about gouges? Used a lot on lathe work, but they would be fine for what you're doing, Conor. Many widths and radii available.
These users thanked the author Chris Pile for the post: Conor_Searl (Fri Jan 14, 2022 12:07 pm)
PostPosted: Thu Jan 13, 2022 7:08 pm
https://www.toolstoday.com/v-7995-160-70.html
something like that then...
These users thanked the author Mike_P for the post: Conor_Searl (Fri Jan 14, 2022 12:09 pm)
Users browsing this forum: DennisK, Terence Kennedy and 44 guests
