It is currently Sun Jul 27, 2025 7:56 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Thu Nov 18, 2021 6:11 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Conversion to a hanger-bolted or bolt/threaded insert butt join or stub-tenon joint seems like a plan. A 5/8" hardwood dowel reinforcing the heel addresses end-grain fastener withdrawal weaknesses, and leaving the lion's share of the remaining tenon might help with alignment prior to getting the fretboard on the neck. All low-tech, small shop techniques which can be accomplished with the tools likely already at hand.
- Beth Brower
PostPosted: Thu Nov 18, 2021 8:35 am
Another way to guard against inserts in end grain pulling out from overtightening is to inset the insert in the heel and use a small hole saw and Forstener bit to cut a long grain plug and matching recess. For easier alignment I would cut the recess first and use the center spur divot as a guide to drill the hole for the insert.
PostPosted: Thu Nov 18, 2021 8:54 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Well, a truly 'floating (I.e., unattached) would be as rational as a boat with holes cut in the bottom to let the water out.
Peter Havriluk
