It is currently Sun Jul 27, 2025 11:21 am
PostPosted: Wed Sep 15, 2021 8:05 am
Ive done many things in life, but I’m still pretty new to the router world;)
I’m not sure why I’m confused on this, but for some reason I think I am (see I’m confused about being confused too)
I’ve been using my router table to cut truss rod slots. But the router wants to pull the wood through the bit and off the table. This is clearly because I’m feeding it in the wrong direction (climb cut) right?
BUT everything I see says go from right to left if your looking down on the table. This is the direction I’m going!
Why is it still pulling?
Here is a piece of art hand drawn by me for your enjoyment that illustrates what I mean.
PostPosted: Wed Sep 15, 2021 8:06 am
Just a thought…. Maybe it’s the bit? There’s a down cut but in the router …
PostPosted: Wed Sep 15, 2021 8:19 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Too big of a bite probably. Do it in multiple passes.
Hutch
PostPosted: Wed Sep 15, 2021 8:23 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
My advice:
Cut only 1/8” of depth at a time. Use a featherboard to keep the neck snug against the fence. Use sharp, clean router bits.
PostPosted: Wed Sep 15, 2021 8:52 am
Last Name: Colbert
City: Anacortes
If the bit is running counterclockwise it should be pulling the work into the fence. I use an up-cut spiral (pulls waist out of the slot) bit and am able to get vey clean results in one pass. The one problem with making multiple passes is the bit center can shift slightly making for a sloppy fit. How big is the router you are using? A small laminate trimmer may not be stiff enough for the job.
Best M
PostPosted: Wed Sep 15, 2021 8:57 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
In a buried cut, there should not be any issue with lift or lateral forces (they are pretty balanced at reasonable feed speeds) unless the bit is dull or perhaps with a larger downcut bit (which will lift the work in a table). Once the main channel is milled, all the caveats concerning 'trapping' work between the fence apply...no backfeeding allowed.
What bit are you using, do you have dust collection pulling the chips/dust out of the channel, and what type of trussrod are you using?
- Beth Brower
PostPosted: Wed Sep 15, 2021 9:42 am
Hey thanks for all the hints
Bit: 1/4” whiteside spiral downcut
Dust collection is hooked to my big jet collector
Router: Bosch 2.25 Hp
PostPosted: Wed Sep 15, 2021 9:52 am
Not really a good application for a downcut bit. A normal uncut will pull the work into the table, helping control.
These users thanked the author Barry Daniels for the post: SnowManSnow (Wed Sep 15, 2021 10:06 am)
PostPosted: Wed Sep 15, 2021 10:05 am
Just a thought. I’m not sure what the current setting is (not there now) but should the router be on high speed. I’m assuming it should. Maybe it’s been accidentally turned down?
PostPosted: Wed Sep 15, 2021 10:22 am
Last Name: Parker
City: Charleston
Ditto. Plus, getting the chips and dust out of the channel is important, and a downcut bit is going to make that harder, not easier. Use an upcut bit or a straight bit for this application.
If you really want to use the downcut bit, I will repeat the advice about only taking 1/8" of depth at a time. Michael is right that the side walls can wind up a bit messy (depending on some factors), but getting the chips and dust out of the channel would be an overriding concern for me. With a downcut bit, stuff has trouble finding its way out of the channel.
These users thanked the author doncaparker for the post: SnowManSnow (Wed Sep 15, 2021 11:37 am)
PostPosted: Wed Sep 15, 2021 4:36 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
For a round-bottomed trussrod like the Martin 2-way, a 1/4" solid carbide core box bit gave us flawless milling and the round-bottomed slot reduced stress concentrations at the lower corners and end of the slot. We had no issue with full-depth passes, and could mill a wider slot by a combination of partial passes and plunge cuts aligned with the fence.
- Beth Brower
