It is currently Sat Jun 28, 2025 12:09 am
PostPosted: Wed May 27, 2020 2:29 pm
First name: Fred
Last Name: Overend
State: Lancashire
Country: United Kingdom
Hi all,
A friend asked if I could build him a Ukulele today - something I've never done or considered.
However, I quite like the idea of giving it a go so any advice on preferred bracing patterns, top thickness etc would be greatly appreciated.
Any common mistakes to look out for?
Fred.
https://overendsite.wordpress.com/2017/ ... -complete/
PostPosted: Thu May 28, 2020 3:33 am
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
What size, and what top wood?
Sopranos are usually just a couple of ladder braces, one above and below the sound hole, plus a very thin bridge patch.
Concerts and tenors are commonly fan braced. Baritones are baby classical guitars.
The biggest pitfall is over-building. With such a small soundboard, it's easy to make a uke which sound dull and lifeless. Sopranos are the hardest to make well, because they are so small. Generally, bracing is very light indeed - my ladder braces on a soprano might be only 4mm wide and a little over 6mm high, tapering to nothing as they meet the sides.
With hardwood tops like mahogany, I'd thickness to about 1.8mm and then work down from there with a cabinet scraper depending on the top stiffness. For all tops I'm looking for them to deflect maybe half an inch along the grain under light finger pressure. Cross-grain stiffness is good, but if it's very flexible cross grain then my braces will be higher.
Softwood tops I'll take to around 2.1 mm and then work down as above.
Good luck!
PostPosted: Thu May 28, 2020 9:21 am
Last Name: Miller
City: Wood Dale
State: Illinois
Graham McDonald recently published a comprehensive book on ukulele building. Available on Amazon for $25 .
These users thanked the author edstrummer for the post: Fred O (Thu May 28, 2020 3:32 pm)
PostPosted: Thu May 28, 2020 3:36 pm
First name: Fred
Last Name: Overend
State: Lancashire
Good luck!
Thanks for that, some really useful there info. It will probably be a Concert with spruce front but not discussed anything further just jet.
PostPosted: Thu May 28, 2020 9:30 pm
Last Name: Miller
City: Wood Dale
State: Illinois
My latest tenor uke is third I have built and best sounding. Spruce top paired with south american walnut. Fan braced with cherry bridge plate. Braces notched over plate. Think light, light, light!!!!
These users thanked the author edstrummer for the post: Fred O (Fri May 29, 2020 3:36 am)
PostPosted: Fri May 29, 2020 4:37 am
Last Name: Reed
City: Stowmarket
State: Suffolk
Country: UK
Light is indeed the word! I make everything as light as I dare, then pause until I feel braver and make it lighter still.
However, there is an alternative approach which some makers adopt for tenors and baritones, particularly if they are to be used for the fast melodic run style popularised by Jake Shimabukuro. This is to build back and sides very rigid, to increase sustain from the top (it parallels a similar school in guitar building).
Sopranos and concerts tend to be strummed more than picked, and for them too much sustain is a problem as it muddies the sound. Spruce tops can be a problem here, because they sustain well and emphasise the high frequencies, so the uke can end up very "jangly". You might want to discuss this with the player - if their plan is to work up the kind of complex strumming used by Roy Smeck, or among modern players by (say) Ukulele Uff (videos by both on YouTube), then a hardwood top might be a better choice.
PostPosted: Fri May 29, 2020 12:30 pm
First name: Fred
Last Name: Overend
State: Lancashire
Excellent stuff. So glad I asked now. It might be a while before we get going on this but I think I'll do two at once incorporating the opposing points you mention. Will be interesting and fun to do.
PostPosted: Mon Mar 29, 2021 5:36 pm
First name: Fred
Last Name: Overend
State: Lancashire
UPDATE.
It's been a while but I finally got going on this build. After looking at lots of alternatives I decided to try a 'V' bracing pattern.
Worked really well and quite pleased with my first attempt at a Uke.
A big thanks to those who offered advice on this one. It was very much appreciated.
PostPosted: Mon Mar 29, 2021 5:43 pm
Last Name: Miller
City: Wood Dale
State: Illinois
Cool brace pattern. I like it.
Ed M
These users thanked the author edstrummer for the post: Fred O (Mon Mar 29, 2021 6:01 pm)
PostPosted: Mon Mar 29, 2021 6:00 pm
First name: Fred
Last Name: Overend
State: Lancashire
Ed M
Thanks, I can't take any credit for the design, it was inspired by Hawaii's Fred Vento's bracing pattern. It is very similar to Taylor's V bracing system but Fred had developed his years before.
PostPosted: Wed Mar 31, 2021 9:04 am
First name: Brad
Last Name: Combs
Looks great!
These users thanked the author bcombs510 for the post: Fred O (Thu Apr 01, 2021 3:38 pm)
PostPosted: Tue Aug 24, 2021 10:32 am
First name: David
City: Napa
Zip/Postal Code: 94558
I would recommend purchasing a plan from either Hana Lima or Pegasus in Hawaii. Both Bob andMike are great to work with and have done so much for th eUkulele community.
These users thanked the author dofthesea for the post: unkabob (Mon Feb 14, 2022 3:52 pm)
PostPosted: Tue Aug 24, 2021 10:55 am
Last Name: Miller
City: Wood Dale
State: Illinois
I have used Hana Lima plans and they are very good but I think they have shut down. Miss them a lot.
PostPosted: Tue Aug 24, 2021 1:15 pm
First name: Brad
Last Name: Combs
Whoa, didn’t know that. The sales site seems up for kits and parts but a lot of stuff shows sold out.
