It is currently Fri Sep 19, 2025 3:30 pm
 Post subject: Dishing Neck Cheeks
PostPosted: Sun Aug 01, 2021 3:47 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
There was a recent thread about dishing neck cheeks over on Acoustic Guitar Construction Forum. Here is my addition to that discussion. I thought some of you folks might like to try it too.
I've been using a dremel with rasp #199. Here's a pic with a piece of aluminum tubing over the shaft to prevent friction burns on the edge and keeping the cut shallow. The Taylor pic looks like a closeup of that type of rasp.
Here's a pic of a neck heel with the recess cut out leaving a narrow edge for flossing. It was cut out before fretboard attachment and heel cap glued on.
I'm liking butt joints more and more, so much easier to make the cheek recess with a router. :)
 Post subject: Re: Dishing Neck Cheeks
PostPosted: Sun Aug 01, 2021 5:07 pm
I'm liking butt joints more and more, so much easier to make the cheek recess with a router. :)[/quote]
Ding!
PostPosted: Sun Aug 01, 2021 5:46 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Ed, you're going to cause a whole bunch of heart attacks among the dovetail worshipers when they read your comment.
Peter Havriluk
PostPosted: Sun Aug 01, 2021 6:32 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I do a butt joint and have been doing this with a chisel. I cut the wall of the recess at a bit of an angle because it seems like having a right angle on such a narrow raised section could be a week point. I’m not really sure it matters, I could be making things more complicated for myself.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: Barry Daniels (Sun Aug 01, 2021 9:36 pm)
PostPosted: Sun Aug 01, 2021 8:39 pm
I also use a chisel, a 10mm gouge. It’s easy and quick.
PostPosted: Mon Aug 02, 2021 2:09 am
Scandalous!
PostPosted: Mon Aug 02, 2021 7:49 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
I do it with a chisel but the Dremel sounds appealing, that is until I lose control of it and ruin the neck somehow.
Hutch
PostPosted: Mon Aug 02, 2021 7:52 am
First name: Richard
City: Warwick
State: RI
That's interesting. I just use a flat chisel but a gouge may be better, I'll give it a go.
Hutch
PostPosted: Mon Aug 02, 2021 8:12 am
chisel is safer and more controllable with a sharp corner you create , that becomes a stress riser that can shear out when you tighten the bolt
PostPosted: Mon Aug 02, 2021 8:20 am
First name: Richard
City: Warwick
State: RI
_ _
John your saying this made with a Dremel ____| | is worse than this mad with a chisel ____/ | I think.
Hutch
PostPosted: Mon Aug 02, 2021 9:05 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That is exactly what I was trying to communicate earlier (and didn't word well). Steve's suggestion of a gouge has me thinking. A curved transition would be even better than an angled one.
Bryan Bear PMoMC
PostPosted: Mon Aug 02, 2021 9:23 am
I feel safer using a sharp chisel to relieve the heel instead of a Dremel. And the stress riser comment is very true.
PostPosted: Mon Aug 02, 2021 11:12 am
First name: Carl
City: Forest Ranch
I've done it this way for several years now on on about ten necks and have had no dremel control or edge break problems. Sure makes it easier to floss the neck fit.
PostPosted: Mon Aug 02, 2021 1:14 pm
Any problem would show up years down the road. Not saying it will, but it might be an issue. I just don't think leaving a thin, square edge like that is a good idea. It goes against all my training. The depth of the recess also looks excessive.
PostPosted: Mon Aug 02, 2021 3:02 pm
First name: Richard
City: Warwick
State: RI
You think the one on the right will endure?
Hutch
PostPosted: Mon Aug 02, 2021 3:14 pm
yes that sharp corner is a point of stress over time
PostPosted: Mon Aug 02, 2021 3:35 pm
Yes. But my cheek relief is less dramatic than in the right photo.
PostPosted: Tue Aug 03, 2021 5:46 am
I am also in the chisel camp.
Like Barry, I make the relief less pronounced so that as you "floss" the neck the bearing surface of the neck heel to body joint increases. In a perfect world flossing to final fit the neck wouldn't be needed and there would be solid bearing between the surfaces.
PostPosted: Tue Aug 17, 2021 11:14 am
I am tuning up a guitar I built 10 years ago and here is a photo of the shallow dishing I use. No stress risers here.
These users thanked the author Barry Daniels for the post: Bryan Bear (Tue Aug 17, 2021 1:41 pm)
PostPosted: Wed Aug 18, 2021 4:38 am
Nothing like an uber sharp chisel for us.
PostPosted: Wed Aug 18, 2021 7:21 am
I do a bolt on butt joint too and strive hard to make wood to wood contact across the whole face. The reason why I do that is kind of funny but it's because when I started doing this type of neck joint it was on classical guitars and if you think steel string players who think that a dovetail is the only joint for best tone then well, you have not met many classical guitar players who think that a Spanish heel is the only way to build a guitar ;) Anyway when I tell them, classical Spanish lovers or dovetail-o-philes, that I make sure its all wood to wood contact you can kind of see them look up and to the right and think about it for a while till it makes enough sense to be acceptable.
It's not that hard to floss out with cloth backed paper. Just use one bolt at a time and snug it down then floss it. Why not?
PostPosted: Wed Aug 18, 2021 8:11 am
First name: Richard
City: Warwick
State: RI
I like everything about this. I'm curious about the fretboard inserts you used and how they are installed.
Also, it appears that you used a shim under the fretboard. Is that what I'm seeing.
Hutch
PostPosted: Wed Aug 18, 2021 8:30 am
Glad you like it Richard. I wondered if anyone would catch that detail. The inserts are T-nuts that lay under a cast in-place, epoxy graphite plate to provide a bolt-on fingerboard extension. But there is no shim under the fingerboard. Another detail is something I just did. See the brass pins on the side of the tenon? One brass insert was starting to pull out so I did a cross pin of brass to lock them down.
