It is currently Sun Jul 20, 2025 4:56 pm
PostPosted: Sun Aug 08, 2021 7:56 pm
Online
First name: Brad
Last Name: Combs
Hi folks,
Is it always required to pre-bend when doing laminated sides and / or laminating solid lining? I use paulownia for solid linings and I’m planning to try laminated sides. What is the typical thickness for the veneers for laminated sides?
I have an idea of trying to vacuum form the lining and sides all at the same time without pre-bending. I would need to use a vacuum form reduced from the outside mold profile to accommodate.
Brad
PostPosted: Mon Aug 09, 2021 12:34 am
I have laminated sides without pre bending using 4 layers of veneer .020" thick and wetting it out with West System epoxy. Thicker veneers may require some pre bending. I haven't used vacuum, just a block form and clamps.
Users browsing this forum: rbuddy and 23 guests
cron
