It is currently Fri Sep 19, 2025 7:35 am
 Post subject: Stain with Supersoft II
PostPosted: Sat May 08, 2021 12:31 pm
Bending a back strap of Black limba on a hot iron at 230 deg C using a SS bending strap.
The wood was wet with SS II and on the side with the strap I was a bit taken a when I found a strong black stain.
It sanded out fortunately, but I've not seen this before.
Took a photo of the strap, forget to take one of the wood.... duh
This just wiped off the strap with a paper towel.
PostPosted: Sat May 08, 2021 6:09 pm
First name: Ken
Last Name: Nagy
City: Goodrich
You weren't going for ebonized limba?
I get little red dots on my stuff sometimes. Crazy. They sand out too.
Why be normal?
PostPosted: Sun May 09, 2021 7:08 pm
why so hot you only need 275F
PostPosted: Sun May 09, 2021 10:55 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Have you bent sides before when they were still wet with SS II?
PostPosted: Mon May 10, 2021 8:31 am
No, first time.
The side against the aluminium bending iron was unmarked. so I must have been a reaction between the stainless steel strap and the SS.
PostPosted: Mon May 10, 2021 10:57 am
First name: Jay
City: Bothell
State: Washington
I've noticed that pigments in wood can be mobilized by SS II when the SS II is still wet on the wood. Could the stain be pigment from a dark section of the black limba that migrated under heat?
I haven't tried bending sides when they were still wet with SS II. I let them dry first. So I don't know if that can be a problem or not. I do know that pigments were mobilized in all the colored woods I've used SS II on. When I spray bindings with SS II, color runs out of the wood onto the newspaper I lay the bindings on for spraying. When I spray sides, I leave them overnight between paper towels under a weight and I remove the paper towels in the morning. For colored woods, the paper towels are always colored from pigment that came out of the wood while it was still wet.
PostPosted: Mon May 10, 2021 11:08 am
As I said, no stain on the wood against the hot (aluminium) iron, only on the strap side.
I've also seen colour leached out of the wood - e.g. EIR, Zircote, etc.
PostPosted: Sun May 23, 2021 6:31 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Oxalic acid in a saturated solution (at least 5% oxalic acid by weight) for iron stain removal may save you some sanding time. Oak and other higher-tannin timbers are more prone to iron-staining, so your limba might fit into that category as well. Neutralize the oxalic acid with distilled water wipes or a distilled water/household ammonia or distilled water/baking soda wipe.
The oxalic acid treatment converts a visible form of the product of the ferric iron-tannic acid reaction to a colorless form. If I recall correctly, the Forest Products Laboratory has a paper on this topic, and covers a bit more of the chemistry.
- Beth Brower
Users browsing this forum: No registered users and 42 guests
