It is currently Fri Jul 18, 2025 2:47 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sun Apr 25, 2021 6:13 pm
I'm taking an informal poll on whether builders (1)prefer to tape off the bridge/fretboard area before applying finish to the top or (2) prefer to remove the finish under the bridge/fretboard area after applying finish.
What do you say?
Formerly know as Mandodiddle.
PostPosted: Sun Apr 25, 2021 6:16 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
Tape off bridge and fretboard area before finish.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Sun Apr 25, 2021 8:12 pm
Online
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
In doing it post finish I routed it off, now just do the tape it off method.
PostPosted: Sun Apr 25, 2021 8:22 pm
With French Polish I don't tape it off and instead scrape away the bridge footprint. With Nitro I tape. If I tape then I make the taped footprint smaller then the bridge so that the build up at the edges of the tape can be removed with scraping. So in any case scraping is involved but taping off saves a bit of time.
PostPosted: Sun Apr 25, 2021 8:31 pm
Tape....
PostPosted: Sun Apr 25, 2021 10:00 pm
I still rout/sand/scrape it off. Bolt on extension so that area is not an issue.
These users thanked the author Terence Kennedy for the post: Pmaj7 (Tue Apr 27, 2021 1:56 am)
PostPosted: Mon Apr 26, 2021 7:12 am
First name: Terry
I tape the fretboard area and route off the bridge area. Mostly because I don't make any decision about bridge placement until the guitar is finished and assembled.
PostPosted: Mon Apr 26, 2021 7:27 am
Online
First name: Brad
Last Name: Combs
I usually route after but I’m going to try frisket film on the next guitar that I build.
PostPosted: Mon Apr 26, 2021 7:51 am
I am French polishing with Royal Lac and I use Frisket to mask off the bridge area and the fretboard extension. I route the saddle slot after the bridge is attached. I don't find it particularly difficult to put the bridge in the correct spot before final neck attachment.
PostPosted: Mon Apr 26, 2021 9:04 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I have done both ways a bunch of times. I decided to settle on carefully taped. I have had an easier time especially in the corners.
PostPosted: Mon Apr 26, 2021 9:07 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I French polish (ately with Royal-Lac. I tape first.
Bryan Bear PMoMC
PostPosted: Mon Apr 26, 2021 9:12 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I still just finish everything, then mark and remove finish under the footprint of the bridge and fingerboard extension. I use a Foredom and StewMac router base for the bulk of it, so it goes pretty fast; then I finesse the edges with hand tools, and sand the bare wood smooth. I've thought about experimenting with masking, but I don't mind what I currently do.
PostPosted: Mon Apr 26, 2021 9:25 am
tape the extension but rout off the bridge tape makes getting a good flat and high shine difficult.
PostPosted: Mon Apr 26, 2021 9:41 am
First name: George
City: Seattle
+1 for frisket film.
George :-)
PostPosted: Mon Apr 26, 2021 11:45 am
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
Is frisket thinner than tape? What is the advantage of using frisket?
PostPosted: Mon Apr 26, 2021 11:50 am
Online
First name: Brad
Last Name: Combs
Frisket is ~.001″ where blue painters tape (often used). I think blue painters tape is like 5x that?
PostPosted: Mon Apr 26, 2021 12:47 pm
First name: Tim
Last Name: Allen
City: San Francisco
"With French Polish I don't tape it off and instead scrape away the bridge footprint." + 1
Seems pretty easy and quick.
Tim Allen
"Never hurry, never rest."
PostPosted: Mon Apr 26, 2021 4:22 pm
What jfmckenna said.
The varnish I'm using these days is very hard to remove cleanly, and having an area started makes it much easier.
PostPosted: Mon Apr 26, 2021 4:27 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I use frisket for fingerboard extension and scrape the shellac for the bridge
PostPosted: Mon Apr 26, 2021 4:32 pm
Last Name: Ball
I use frisket, but I mask off an area slightly smaller than the actual footprint of the bridge or fingerboard. Then I take it to the final line by scraping (probably going to try routing one of these days). But the frisket takes care of the bulk of finish removal so I only have minimal material to remove before gluing.
PostPosted: Mon Apr 26, 2021 6:09 pm
Last Name: Livermore
State: Minnesota
Here’s a couple approaches I use
One way is to tape off before finish. The pucker factor here comes from not knowing if its in the right place. So if I were to tape off, I would plan to rout the saddle slot after the bridge is glued down.
It is pretty easy to make a sled out of stiff plywood to rout a perfect slot EXACTLY where you want it.
Next: don’t tape it off. Scrape/ sand/ route? The finish off just a hair shy of the footprint of the bridge. Pucker factor here being, what if you screw up or slip and mess up the finish. So work carefully, and stay inside the footprint. Then bevel the edges on the bottom of the bridge so excellent wood to wood gluing surface is maintained across the entire bridge (except the 1/8” or so around the perimeter where you beveled the wood so it didn’t contact the finish.)
Hope this helps someone.
dave
PostPosted: Mon Apr 26, 2021 6:54 pm
Last Name: Ball
I mount the neck to the body (I generally use bolt on mortise/tenon joints, but it would work the same way with a dovetail), measure for where the bridge goes, drill index holes and mask from there. The final position will only be off by the thickness of the finish. Masking the majority of the bridge footprint makes it easier later on to just take the very edges off by scraping to get a good clean gluing surface.
PostPosted: Mon Apr 26, 2021 7:07 pm
City: Tyler
I think I’m the loner here. I use paste paint stripper after finishing. Virtually no scraping to do, other than the dried stripper.
PostPosted: Mon Apr 26, 2021 11:04 pm
The original StewMac VHS tape that came with their kits in the 90’s showed the gel paint stripper technique. I never tried it. Kind of scared me.
These users thanked the author Terence Kennedy for the post: Mark Mc (Mon Sep 12, 2022 7:19 am)
PostPosted: Tue Apr 27, 2021 6:07 am
Tape:)
Users browsing this forum: bobgramann, Ken Lewis, rbuddy and 13 guests
