It is currently Fri Sep 19, 2025 10:02 pm
 Post subject: Less Wasteful Mold
PostPosted: Sun Feb 07, 2021 6:56 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
When making molds, it always bothers me when I wind up with those guitar shaped cutouts. It just feels so wasteful. I don't need bending forms (I bend by hand). I know I can cut them up and use them for cauls and what-not, but it still bugs me to use that much plywood. Before doing what I outline below, I was using almost half a sheet of plywood to make a regular sized mold: 8 pieces of ¾" plywood, each 24" long, 10" wide, all bandsawn and pattern-routed to the proper shape. This yields 8 guitar cutouts that I have to find uses for.
This time around, I decided to just cut 4 of the ¾" x 24" x 10" pieces, bandsaw and route them to size, and use those as the outside layers of the mold. For the inside layers, I used the guitar shaped cutouts, bandsawn into blocks, glued to the outside layers, then bandsawn and routed again to match the outside layers, then glued together to make the 4 layers per side. Like this:
This wound up only requiring a quarter sheet of plywood for one mold. Here is the final product:
There are a few small gaps on the inside layers, but they don't cause any problems.
I feel much better about making this mold with half as much plywood, and plan to do it this way from now on.
These users thanked the author doncaparker for the post (total 5): Durero (Mon Feb 08, 2021 11:53 am) • Pmaj7 (Mon Feb 08, 2021 12:50 am) • Bryan Bear (Sun Feb 07, 2021 8:49 pm) • bcombs510 (Sun Feb 07, 2021 7:59 pm) • Michaeldc (Sun Feb 07, 2021 7:22 pm)
 Post subject: Re: Less Wasteful Mold
PostPosted: Sun Feb 07, 2021 7:55 pm
Last Name: Ball
Cool--I keep a box full of baltic birch cutoffs that might be small, but too good to waste. Next time I'm mold making, I'll keep your idea in mind!
PostPosted: Sun Feb 07, 2021 8:42 pm
Clever!
PostPosted: Sun Feb 07, 2021 8:56 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I have a mold with top and bottom of 1/2" ply w/ construction grade 2X pieces glued in between. Lots of spaces between them. Works as good as my solid ones.
PostPosted: Sun Feb 07, 2021 9:02 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Great idea! Even though I've used a bunch of the cutout pieces from previous molds for cauls and jigs/fixtures, I still have a box full of them left over (I have a hard time throwing out scrap wood, just in case...). Now I have a use for a bunch of them. Thanks.
PostPosted: Sun Feb 07, 2021 9:51 pm
Hey Don,
I'll join the club! A lot of my molds started out from scrap - not as many small pieces, but I make up for it with "gaps". Even though we are working wood it's nice to save a few trees along the way. Yours still look first rate, mine would win the ugly dog award, but they still work.
PostPosted: Mon Feb 08, 2021 1:00 am
I have just used some 2x2 cedar scraps. works fine and lighter weight. Doesn't even need to be solid all the way around. I was experimenting with MDF on this but I think I would use plywood in the future. The MDF has more give than I want, although the second picture with MDF core is fine.ImageImage
PostPosted: Mon Feb 08, 2021 5:55 am
Can't imagine what happened to my previous post on this thread... Anyway, it's a good idea and one I heartily approve of. As a former tool & die maker, I can tell you while it seems like more work, sometimes it just makes sense and might even be necessary. A multipiece tool will work just as well as a single piece in most cases. And less waste is a good goal to have. I don't see how anyone could make a good argument against it. DRIVE ON!
PostPosted: Mon Feb 08, 2021 6:51 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Amateur her, having built 9. All of my molds have been out of 1/4 sheet of 3/4" plywood with 2X4 scraps from a construction dumpster as separators. I have not spent too much time making the center pieces exactly the right shape and the sides end up contacted the edges of the plywood only for most of it. I bend sides on a pipe and have great success in having them turn out flat on a completed rim. As has been said, I use the center cut-outs for jigs and fixtures, but this has me thinking about that.
PostPosted: Mon Feb 08, 2021 7:51 am
Last Name: Parker
City: Charleston
It was definitely more work than just cutting and routing 8 layers, and I normally try to do less work if I can, but in this instance, my desire to conserve material overrode my desire to conserve effort.
I found that bandsawing the cutouts into strips about 2.25” wide, and then from those strips bandsawing blocks with varying angles on the ends, worked pretty well. I wound up also needing some of the 24” x 8” board left over from cutting the 4 24” x 10” outside layers. But there were some useful scraps at the end, and it all came from a single 48” x 24” piece of plywood.
PostPosted: Mon Feb 08, 2021 9:47 am
First name: George
City: Seattle
That's a winner, for sure. Good thinking. [:Y:]
George :-)
PostPosted: Mon Feb 08, 2021 11:12 am
Excellent!
