It is currently Sun Jul 27, 2025 2:28 pm
 Post subject: Slothead RAMPS
PostPosted: Tue Feb 02, 2021 6:33 pm
Ok. So another thread was about cutting the slots. Got that solved.
Now what about the ramps? I’ve been told use a dowel w sandpaper. Any better suggestions?
I’m looking for the round pointed ramps... not really flat and square.
 Post subject: Re: Slothead RAMPS
PostPosted: Tue Feb 02, 2021 7:41 pm
I have a large round tapered file, maybe 1/2" in diameter. It not hard to control and works well for round slots.
PostPosted: Tue Feb 02, 2021 7:54 pm
For round bottomed ramps you can rough them out with a gouge (I prefer incannel but outcannel will work) and finish them off with the sandpaper wrapped dowel. If you are good enough (I'm not) you can do the finished surface with the gouge alone.
These users thanked the author Clay S. for the post: bftobin (Sun Feb 07, 2021 1:43 pm)
PostPosted: Tue Feb 02, 2021 8:06 pm
Last Name: Ball
I've used a large tapered round file as Jim mentions, and it works well. But the incannel gouge route seems like a good way to go too.
Your slots look really nice though!
These users thanked the author ballbanjos for the post: SnowManSnow (Tue Feb 02, 2021 10:04 pm)
PostPosted: Tue Feb 02, 2021 8:17 pm
I agree with Dave - your slots look really nice - kind of a mix of the usual square ended and round ended. If you made the ramps similar (flat bottomed with small radiuses on the sides) that might look cool!
PostPosted: Tue Feb 02, 2021 10:04 pm
Via the luthier tools jig ha
PostPosted: Tue Feb 02, 2021 10:55 pm
This Grobet file has been very useful for ramps as well as a ton of other stuff. I use it a lot. Circular files and sandpaper on a dowel are used as well
https://www.amazon.com/Grobet-Swiss-Pat ... ag=mh0b-20
PostPosted: Wed Feb 03, 2021 4:51 am
Suggestion.
If using a rasp/file, a wrap of electrical insulating tape on the legs and middle of the slots can help prevent a bad day - only takes one wayward swipe.
P.S. love the slots, looks like a small guide bush and a small router bit. Neat!
These users thanked the author Colin North for the post: SnowManSnow (Wed Feb 03, 2021 7:14 am)
PostPosted: Wed Feb 03, 2021 7:14 am
Colin North wrote:
Suggestion.
Good idea!
PostPosted: Wed Feb 03, 2021 7:16 am
I watched a guy on YouTube do it w a dremmel tool last night... anyone try that?
PostPosted: Wed Feb 03, 2021 8:15 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I use a Dremmel also.
sanding drum -slow speed.
Mike Collins
PostPosted: Wed Feb 03, 2021 8:32 am
Nice looking slot head. I use a round rasp followed by sandpaper dowels.
PostPosted: Wed Feb 03, 2021 8:36 am
First name: Brad
Last Name: Combs
Has anyone tried the smallest round microplane? Those things eat material fast and are pretty easy to control.
These users thanked the author bcombs510 for the post: SnowManSnow (Thu Feb 04, 2021 10:52 pm)
PostPosted: Wed Feb 03, 2021 8:49 am
First name: Terry
I use a rat-tail rasp, followed by a dowel with sandpaper. The rasp seems (to me anyhow) to take material at a good rate that I can control, but don't feel like it takes forever. Mine's an Auriou with medium cut that I bought in my furniture making days. very nice tool that will last... and they are hand stitched, which makes them cut smoother without "washboarding" the surface. I don't know if this is the same cut as mine, but this is the first link I found:
https://www.leevalley.com/en-us/shop/to ... em=62W3001
PostPosted: Wed Feb 03, 2021 9:30 am
First name: Tom
Last Name: Armstrong
City: Portsmouth
Zip/Postal Code: 23701
+1 left handed Auriou 15 stitch followed by sanding.
PostPosted: Wed Feb 03, 2021 1:05 pm
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
Nice job on the slots. Are you sure strings 1 and 6 have a clear path?
PostPosted: Wed Feb 03, 2021 3:45 pm
No, :)
What are you seeing that may need attention?
I did use the luthier tool jig though
PostPosted: Wed Feb 03, 2021 3:49 pm
Last Name: Ball
I think once the ramps are in, everything will be golden.
PostPosted: Wed Feb 03, 2021 5:09 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
For the few slot heads I have done so far, I have not had a problem with the strings touching anything once the ramps are cut. They might touch the wood a little, but it doesn't cause a problem. I use a 15 degree angle; having that angle be a bit shallower might help avoid any touching. But, again, I have not had a problem with it.
A recommendation for when you string it up: Wind the E strings to the outside, and wind all the rest to the inside. And don't try to loop the excess string under the first winding, the way you would with a paddle head. That just increases the frustration and finger poking. Orient the hole to be perpendicular to the fingerboard.
Feed the string through the hole, leave a little slack, and pull it tight in both directions. It takes on a Z shape. Cut off the excess just a smidge beyond the Z, then wind it up. It holds on just fine, and it is much easier to take off when you change strings.
PostPosted: Thu Feb 04, 2021 12:29 am
First name: Patrick
Last Name: Wirta
City: Eagle
State: Idaho
Snowman nice work with the slots. Do you have the link where you cut the slots?
PostPosted: Thu Feb 04, 2021 9:55 am
First name: Alain
Last Name: Lambert
State: Quebec
No, :)
My mistake, I was thinking the headstock was finished as is, and the ramp question was for the next one. If you make ramps to this one, then you will be OK
PostPosted: Thu Feb 04, 2021 10:45 pm
No, :)
Ahhh cool. I’m always open for criticism so if you see something that sucks it’s ok ha
PostPosted: Thu Feb 04, 2021 10:52 pm
Always interesting how you can see things in pictures you don’t see in real life ha.
Still plenty of work to do here but getting there
Would be interesting to try? May be hard to hang on to once the angle gets steeper and it disappears into the slot:)
PostPosted: Thu Feb 04, 2021 11:16 pm
I didn’t record it for fear of recording a disaster ha. It is my first go at it though... so I’m fairly happy w the result
Users browsing this forum: Chris Pile, Michaeldc and 14 guests
