It is currently Sat Jul 19, 2025 2:32 pm
 Post subject: rosette
PostPosted: Wed Dec 23, 2020 9:23 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
A lot of early rosettes don't have a fretboard overlapping them so the inlaid rings have to meet with no gap. How is this done - a lot of experience? Laying the ring in and cutting its length against the first end? A lot of ukes have this too
Ed M
 Post subject: Re: rosette
PostPosted: Wed Dec 23, 2020 10:23 pm
I've done it the hard way by taking a lot of time to trim each piece a little at a time. Would love to hear of an easy way.
PostPosted: Wed Dec 23, 2020 10:52 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
It seems the Gibson way was to trim it roughly to length and hope for the best. Probably a bit faster :lol:
PostPosted: Wed Dec 23, 2020 10:58 pm
I've always wondered that too! I assume if it was plastic they could always melt it a little bit with acetone...
PostPosted: Wed Dec 23, 2020 10:59 pm
Last Name: Kincheloe
You could get pretty close by multiplying the diameter of the circle by pi :)
These users thanked the author DennisK for the post: Pmaj7 (Thu Dec 24, 2020 12:36 am)
PostPosted: Thu Dec 24, 2020 12:24 am
You can scarph the ends of each purfle at a different place. Since the lines are relatively thin, if you make them reasonably tight your eye won't be drawn to a particular place as it would if they were all butt joined at one spot. In some cases it may be easier to build it up around a form and then inlay the finished rosette in one piece.
These users thanked the author Clay S. for the post: Pmaj7 (Thu Dec 24, 2020 12:36 am)
PostPosted: Thu Dec 24, 2020 5:49 am
Last Name: Ball
That's how I've done it, doing each band as Steve said earlier--a little bit at a time.
PostPosted: Thu Dec 24, 2020 6:56 am
Last Name: Orr
I cut the end at about 25 degrees and then overlap them. This gives some wiggle room rather than trying to get a tight butt join
These users thanked the author Bob Orr for the post: Pmaj7 (Fri Dec 25, 2020 12:12 am)
PostPosted: Thu Dec 24, 2020 9:34 am
Yup scarf joint is the way to go for that. I've done it but anyone with good eyes can still see it.
These users thanked the author jfmckenna for the post: Dave m2 (Wed May 19, 2021 5:12 pm)
PostPosted: Thu Dec 24, 2020 3:26 pm
If it's grainy wood for the main ring, scarf joint. Scarf for the purfling too. I don't put them all in one place at 12:00, rather scatter them around. Makes them harder to find, heh heh.
These users thanked the author Pat Foster for the post (total 2): Michaeldc (Wed May 19, 2021 9:48 am) • Pmaj7 (Fri Dec 25, 2020 12:14 am)
PostPosted: Fri Dec 25, 2020 12:15 am
Originally, I was thinking side to side scarf joints. But now I'm thinking you all are talking about top to bottom scarfs?
PostPosted: Fri Dec 25, 2020 6:43 am
Top to bottom works best for me. I cut the channel so that the purflings and other parts are a bit proud. That allows a few thou of slop during install. I also stagger the scarfs in different places around the rosette.
These users thanked the author SteveSmith for the post: Pmaj7 (Fri Dec 25, 2020 11:01 am)
PostPosted: Fri Dec 25, 2020 8:58 am
this is a lot easier than one may think.
I use a scarfed joint
if you have a multi martin style cut an angle about 3 times the height. The overlay side you can use a tweezers to locate the length and cut the overlap to match the angle it lays on. Also stagger the rings so the joints are at different places
I use duco cement for all rosettes. allow proper cure time when you are using acetate plastic ( 6 hr ) before sanding
These users thanked the author bluescreek for the post: Pmaj7 (Fri Dec 25, 2020 11:02 am)
PostPosted: Fri Dec 25, 2020 9:08 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I used the top to bottom scarfs with when I did this. It was possible to line up the ends as they stack on top of each other.
These users thanked the author johnparchem for the post: Pmaj7 (Fri Dec 25, 2020 11:02 am)
PostPosted: Fri Dec 25, 2020 4:08 pm
Last Name: Dzatko
I was thinking of a jig like this. It would give you a nice scarf joint but unfortunately some math would be involved
PostPosted: Fri Dec 25, 2020 6:54 pm
Last Name: Minch
City: Chestertown
Boy this is a great forum. Lots of ideas. I have used a scarf when binding the inside of a soundhole and it makes sense to use it for the rosette too
Thanks all
Ed M
PostPosted: Sat Dec 26, 2020 10:51 am
It's difficult to get truly seamless joints in wood. I've tried various methods, scarf, mitre and the wallpaper joint. All of them are capable of being near perfect or somewhat visible. You see them on romantic guitars such as Lacotes and many, many others. A very common rosette during that period. I refer to them as a closed ring rosette.
These users thanked the author Michael.N. for the post (total 2): Michaeldc (Wed May 19, 2021 9:49 am) • windsurfer (Mon Dec 28, 2020 12:04 pm)
PostPosted: Sun Dec 27, 2020 11:35 am
https://www.youtube.com/watch?v=ma0AK0H8eIc&t=5s
here you go this is how I do it
PostPosted: Mon Dec 28, 2020 10:21 am
First name: Terry
+1
PostPosted: Wed Dec 30, 2020 8:26 am
https://www.youtube.com/watch?v=gXamzTHr8zA&t=3366s
here is a video I hope you enjoy on rosette installation
PostPosted: Wed May 19, 2021 9:33 am
First name: Charlton
Last Name: Wang
Pat, I have to ask...what is the wood that you're using for your purfling/rosette there? It looks great!
PostPosted: Wed May 19, 2021 9:43 am
Last Name: Wang
I found out in another thread that it's Amboyna Burl. Beautiful!
PostPosted: Wed May 19, 2021 3:45 pm
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Zip/Postal Code: 95492
John, thanks for the video. I’ve always wondered how to go about the offset rosettes. Now I get it and will incorporate one into a future build.
Brad Hall
Mystic Dawg Guitars
