It is currently Wed Jul 30, 2025 12:01 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2
PostPosted: Wed Dec 16, 2020 12:42 pm
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
Dave,
About 17 minutes into this video - you can see what Greenfield does.
https://www.youtube.com/watch?v=sAeXskZHC2o
You'll need spring steel. I use a 0.008" thick spring steel slat for tight contours and a 0.020" thick slat for gentle curves like the tail block. You might need to cut to size - also make sure you round over the edges and corners as the slats can slice up your hands quite easily if you don't. I use the 3M stik-it paper.
This is one of those things that I don't think I would have come up with on my own but I find it phenomenally useful.
These users thanked the author Toonces for the post: ballbanjos (Wed Dec 16, 2020 3:50 pm)
PostPosted: Wed Dec 16, 2020 1:23 pm
I also use spring steel. What I have is blued and 0.010" thick, essentially the same. I find the steel needs a bit of preparation. I round the corners slightly and then use 220 and my ROS lightly to take the sharpness off of the edges of the steel. Also using 3M Stikit.
PostPosted: Wed Dec 16, 2020 6:13 pm
State: West Somerset
Country: UK
Sorry toonces but where is the video? Dave
PostPosted: Wed Dec 16, 2020 6:57 pm
Last Name: Ball
I'm not Toonces, but here it is: https://laughingsquid.com/luthier-michael-greenfield-shows-how-he-creates-magnificent-guitars-from-simple-slices-of-wood/
Nice documentary in general. Lots of good ideas here.
PostPosted: Wed Dec 16, 2020 10:46 pm
First name: Toonces
Last Name: the Cat
State: FL
Chris Ensor wrote:
Toonces wrote:
Just a quick note: this issue has been resolved by the drum manufacturer.
Good to know, Chris. Aside from the slight runout, the rest of the tool was very well done - if I recall correctly, I believe you gave me a refund on the spindle. I also have a couple other things from you that were perfectly machined and designed !!!
PostPosted: Wed Dec 16, 2020 10:55 pm
Chris Ensor wrote:
Toonces wrote:
I tend to be very OCD about tools -- stuff like runout really bothers me. I bought the Elevate pin sander but had a local machinist make me a new shaft that fit the rubber spindle sander drum much tighter.
How long ago was that? I got mine in May of this year.
PostPosted: Thu Dec 17, 2020 11:51 am
Country: UK
Thanks Dave, I had watched that video a few times but hadn't appreciated just what he was doing at that point.
Dave M
PostPosted: Thu Dec 17, 2020 3:21 pm
City: Escondido
Zip/Postal Code: 92029
I use a pneumatic rolling pin and count it as one of my most valuable tools. It makes leveling and soothing sides much, much easier. In fact, I wish I had more sleeves for it (reminder to self).
PostPosted: Thu Dec 17, 2020 10:10 pm
What grit are y’all rockin’?
80 too much?
 Post subject: Rolling Pin Sanders...
PostPosted: Thu Dec 17, 2020 11:04 pm
80 too much?
80’s what came with mine, but I got a few of the finer drums, too. Since the outer layer of my sides is thin to begin with, I’ll probably use a finer grit next time. I didn’t remove a ton of material, but just to be safe.
PostPosted: Thu Dec 17, 2020 11:50 pm
Lam sides?
PostPosted: Fri Dec 18, 2020 12:00 am
First name: Hans
Last Name: Mattes
City: Petaluma
Zip/Postal Code: 94952
I use my pneumatic roll sander with lam sides.
Flattening the sides isn't needed, but getting the bindings flush is. I've never been able to cut the binding channel so precisely that my sides and bindings were truly flush without sanding. So, with lam sides, I cut a slightly shallow channel, assuring that the binding is proud -- then a light touch of the roll sander and it's good.
PostPosted: Fri Dec 18, 2020 3:35 am
80 sounds too coarse. I think I used 150.
PostPosted: Fri Dec 18, 2020 12:03 pm
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
I/ve scraped an sanded for many years. I noticed folks mentioned different types of rolling pin sanders . electric , air powered drill powered etc. Can someone recommend a good one for leveling sides for ukes guitars etc. Also would want to know why you chose that model ??? thank you in advance
PostPosted: Fri Dec 18, 2020 1:04 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Pmaj7 wrote:
I would definitely not want to try that indoors unless I had the mother of dust collection apparatuses hooked up.
Pat raises a good point here. When I level sand the sides by hand, a lot of sanding dust accumulates on the sides and on the floor below the bench side vice that holds the guitar body. I have to vacuum it up several times per side. A rolling pin sander would put most of that into the air. How are those of you using them handling the sanding dust?
PostPosted: Fri Dec 18, 2020 1:14 pm
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
This exactly why I won't own one. Card scrapers for me are pretty quick. I hate any sawdust in my shop if I can help it.
Hutch
PostPosted: Fri Dec 18, 2020 1:53 pm
Last Name: Ball
J De Rocher wrote:
When I used mine, I used a floor stand dust collection gizmo like this:
Worked pretty well.
These users thanked the author ballbanjos for the post: Pmaj7 (Sat Dec 19, 2020 11:00 pm)
PostPosted: Fri Dec 18, 2020 2:39 pm
Has anyone tried an actual rolling pin? I have an old fashioned one whose handles are fixed rather than allowing the body to roll independently. There are three others gathering dust, so I could spirit one away without too much trouble.
In place of the spring steel some have suggested you can use Formica (HPL) scraps. It might even be a little easier to hang on to.
PostPosted: Fri Dec 18, 2020 6:19 pm
First name: Brad
Last Name: Combs
I use one of those Rockler hose holder deals screwed into the side of the troji.
It’s messy but manageable.
https://www.rockler.com/dust-right-4-spring-clips
https://www.rockler.com/mini-gulp-dust-hood
Brad
These users thanked the author bcombs510 for the post: Pmaj7 (Sat Dec 19, 2020 11:00 pm)
PostPosted: Sat Dec 19, 2020 10:27 pm
meddlingfool wrote:
Lam sides?
Exactly. The outer layer on one of the current guitars is .04”, so I’m being paranoid level careful! I usually like .06”.
PostPosted: Sat Dec 19, 2020 10:30 pm
J De Rocher wrote:
It was thankfully a fairly dense dust and tended to clump up in small piles. I stopped every few minutes to vacuum it up.
PostPosted: Sat Dec 19, 2020 11:06 pm
James Orr wrote:
meddlingfool wrote:
Lam sides?
One would think that with laminated sides you would avoid much of the unevenness, no?
PostPosted: Sun Dec 20, 2020 12:26 am
Pmaj7 wrote:
James Orr wrote:
meddlingfool wrote:
Lam sides?
One thing I do when laminating sides is laminate against smooth surfaces and leave the sides clamped in the mold for a week to allow the epoxy to more fully cure. This seems to help them stay flatter and retain there shape better. The other thing I do is laminate sequence matched sheets in fairly good registration so any "thin spots" from sanding have matching grain under them.
These users thanked the author Clay S. for the post: Pmaj7 (Sun Dec 20, 2020 10:39 am)
PostPosted: Sun Dec 20, 2020 1:01 am
Pmaj7 wrote:
James Orr wrote:
meddlingfool wrote:
Lam sides?
Yes, but they still require some clean up.
These users thanked the author James Orr for the post: Pmaj7 (Sun Dec 20, 2020 10:39 am)
