It is currently Fri Nov 29, 2024 4:12 am
 Post subject: SG with a bad neck set
PostPosted: Sat Dec 12, 2020 1:24 am
I've got an early '60s SG with the bridge all the way bottomed out and action is still high. Neck is straight. I've seen this on a new low-end Gibson, but is this on par for something made in the 60s?
Perhaps the bridge was replaced and is higher than the original? I've looked on the internet and it seems like this is an original looking bridge... Does the body distort over time?[
What can you do?Image
PostPosted: Sat Dec 12, 2020 7:10 am
necks move over time the neck will have to be reset to restore the proper geometry.
These users thanked the author bluescreek for the post: Pmaj7 (Sat Dec 12, 2020 12:20 pm)
PostPosted: Sat Dec 12, 2020 8:40 am
I have seen a few SG's and even an L6-S with curved bodies, but it's far more likely that a neck reset is the fix for this instrument. Shouldn't be real tough to do.
These users thanked the author Chris Pile for the post: Pmaj7 (Sat Dec 12, 2020 12:21 pm)
PostPosted: Sat Dec 12, 2020 10:32 am
That is on par for the 60s. It definitely needs a neck reset.
These users thanked the author DanKirkland for the post: Pmaj7 (Sat Dec 12, 2020 12:21 pm)
PostPosted: Sat Dec 12, 2020 12:24 pm
Okay, wow I had no idea people were resetting necks on this type of guitar. Thanks guys, now off to youtube! LOL
PostPosted: Sat Dec 12, 2020 1:03 pm
First name: Freeman
Last Name: Keller
Some SG's have the short tenon that has a reputation for problems. I'd say pull the neck p/u and take a look but I don't see one. And it looks like the bridge pup once was a dog eared P90 before the SD was installed. Don't know about the bridge - I think some of the low end SG's had wrap around ToM's like that.
I've had a couple of old Gibsons with neck tenon problems but I've always been able to avoid a reset. I would think that would be a nightmare.
PostPosted: Sat Dec 12, 2020 1:40 pm
That bridge has to be an old Leo Quan Badass.
PostPosted: Sat Dec 12, 2020 2:16 pm
Do you think there's a chance it could be taller than the original?
PostPosted: Sat Dec 12, 2020 3:53 pm
I believe they were taller than stock. I see there is still a gap under the bridge. If you can - carefully - trying tapping the inserts a little deeper into the body. Sometimes I would pull the studs and insert assembly, and grind off the lip on the insert so it will sit flush with the body, and then put it back in the body. Should gain you about 3/32 of height.
These users thanked the author Chris Pile for the post: Pmaj7 (Sat Dec 12, 2020 4:45 pm)
PostPosted: Sat Dec 12, 2020 4:45 pm
Thx, yes, I was thinking to grind the lip off or something. I will measure and see how much that will give me..
PostPosted: Sat Dec 12, 2020 4:58 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Also, maybe you could recommend that the client try a lower profile wraparound bridge before anybody does any surgery on the guitar. It might not help enough, but it is worth exploring before anything more permanent happens.
These users thanked the author doncaparker for the post: Pmaj7 (Sat Dec 12, 2020 5:13 pm)
PostPosted: Sat Dec 12, 2020 9:29 pm
I don't know what that might be....
PostPosted: Sat Dec 12, 2020 9:46 pm
looks like there's some room there to file down the saddles and lose some mm's
These users thanked the author Mike_P for the post: Pmaj7 (Wed Dec 23, 2020 3:21 am)
PostPosted: Sat Dec 12, 2020 10:56 pm
Last Name: Parker
City: Charleston
StewMac appears to carry some options. Again, no idea if they would work, but perhaps worth a try.
Users browsing this forum: Bing [Bot] and 41 guests
