It is currently Mon Jul 28, 2025 5:43 am
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2  Next
PostPosted: Sat Nov 28, 2020 2:42 pm
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
I put one side on the back and was quickly wishing I'd done a better job..
It's time for one of those fancy ass router jigs. Looking for plans and best drawer slides or something better.
Hutch
PostPosted: Sat Nov 28, 2020 3:31 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Rick Micheletti has some plans on his luthiers cool tools website. John Hall sells one like it on blues creek guitars.
I built a tower type based on a description by Lillian on anzlf.com, http://www.anzlf.com/viewtopic.php?f=1& ... it=binding. Here's a pic.
Uses parts from 8020.net.
PostPosted: Sat Nov 28, 2020 4:22 pm
I bought the Fleishman binding machine setup from John Hall. Best money ever spent.
https://bluescreekguitars.com/product/f ... d-bit-set/
That setup with the cradle is invaluable to me in my building. The ability to isolate the instrument from the bench top prevents lots of accidents from happening like top dents etc... The setup is incredibly safe too as it's nearly impossible to completely lose all control when using it. I use the cradle on the benchtop when gluing in the binding too since it makes it so much easier to have it just a hair higher.
For an idea of how much time and annoyance this thing saves me. I can cut the ledges for 1 ply binding in about 10 minutes with a climb cut using masking tape to prevent blowout/chips on the edges. If you want a purfling line cut just add another 10 minutes or so to measure/tape/change out bearings etc... It's really the best tool I own and I'm very pleased with it.
PostPosted: Sat Nov 28, 2020 4:40 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I have tried a number of different designs, and my favorite so far is the LMI binding machine.
It shares some characteristics with the Fleishman machine:
1. It relies on rabetting bits with bearings of different sizes to get the right horizontal cutting depth. I strongly prefer this over the designs that have a vertical stop, or a set of barbell-like bearings, used in conjunction with a regular router bit. That barbell design relies on the user being able to keep the stop completely tangent to the cut at all times, and that is not easy for me to do.
2. It forces the router bit to stay 90 degrees vertical to the workbench, and allows the height to vary.
3 It puts the guitar in a cradle for presenting the guitar to the router (which is attached to the tower).
One advantage the LMI tower has over the Fleishman design is that the LMI tower has a very nifty screw-on donut that can be adjusted very finely for vertical depth of cut.
It is not cheap, but I'm a happy user of the LMI binding machine.
PostPosted: Sat Nov 28, 2020 4:49 pm
First name: Richard
City: Warwick
State: RI
They all look fairly easy to build and for me, building is the best option. After I fix this mess and before I do another.
Hutch
PostPosted: Sat Nov 28, 2020 5:00 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
I've had Fleishman style machines, shopmade ones, and several others over the years. I currently use the LMI one. The adjustable donut is really slick. Makes for extremely fine depth adjustments. It's one of the few true innovations to come along in years IMO. On the other hand, the sled they sell sucks. Sometimes they try to trick things out so much that the tool is a total hassle to use. I use the old fashioned cradle that you can find anywhere. Easy to make. John Hall at Blues Creek has them too
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
PostPosted: Sat Nov 28, 2020 5:08 pm
Last Name: Ball
I started off with one of the Blues Creek binding cutters/body carriers, and it worked well straight out of the box. But, I made some changes. I've used the Stew Mac and LMI stepped bearing binding cutters, and they were OK, but I had always used downcut spiral end mills with an adjustable "finger" for depth control when cutting binding channels on fingerboards, pegheads and the like. I like the fact that it's infinitely adjustable--you can sneak into a final fit easier than you can with the bearings, plus there's never the need to add just a little masking tape to the bearing to get the right depth of cut etc. Also, 1/4" endmills are a lot cheaper to replace than the rabbet/bearing type cutters, and produce a very high quality channel.
So here's what I ended up with. The router moves in and out from the ball bearing guide with an adjustment knob that can barely be seen to the back of the router. You can see the 1/4 end mill barely sticking down (purfling cut). The tower type frame keeps the whole thing square to the body. I also added a spring to counter the weight of the router a bit.
These users thanked the author ballbanjos for the post: DanKirkland (Sat Nov 28, 2020 5:10 pm)
PostPosted: Sat Nov 28, 2020 6:26 pm
Here’s mine. Just HD drawer sliders and scrap wood.
I use the ledge attachment on the jig itself so that I can just drop in a new router for each cut.
One router for excess cut which cuts a .060 ledge just sort of .250 high, then my main binding cut at .070 x .250, then a top purfling router and a back purfling router. I usually use the same size purflings but if I want to do something different I just change out the bearings.
The carriage bolt keeps the bit square.
I found the donuts allowed too much a variation, so I have little tapered blocks that come right up the the edge of the bit glued to the router base.
Aside from the fiddliness of getting the box aligned square in the cradle, it’s basically an idiot proof and efficient system which is very suitable for me...
PostPosted: Sat Nov 28, 2020 6:54 pm
I built this one based on another jig I had seen before and it works like a charm. If you want to purchase the real deal then look it up at Canadian Luthier Supply. It's a great jig, simple to use and doesn't take up space in a small shop. But basically you mount the jig in a vice, I have a dedicated router for it otherwise mount it to your router too, and then holding the guitar in your hands you just rotated it around following the climb cut patterns of course.
PostPosted: Sat Nov 28, 2020 7:17 pm
First name: Freeman
Last Name: Keller
I just bought the StewMac rig when I started doing carved topped guitars and never looked back.
PostPosted: Sat Nov 28, 2020 7:39 pm
Last Name: Ball
I like the arrow reminder on the jig--for as many years as I've used routers, I sometimes still have to ask myself which way the bit is turning. Sometimes, I still get it wrong. Call me slow...
PostPosted: Sat Nov 28, 2020 8:20 pm
If I had an updated version of the pic I also taped to it the climbing cut strokes to take first too. Yeah reminders are good. Take the 'thinking' out of it and it operates more smoothly.
PostPosted: Sat Nov 28, 2020 8:55 pm
Last Name: Kincheloe
Yeah, I can usually figure it out with some effort, but I am prone to overthinking things. It always frustrates me when people say something turns clockwise without specifying which end of the axis you're looking from. Normally a router bit would be considered to turn clockwise, but clearly that arrow is counterclockwise. Or in the case of a circular object, saying "turn it to the right" without specifying what point on the circle should move to the right... for example on a car steering wheel, a right turn can be accomplished by moving the bottom of the wheel to the left.
PostPosted: Sun Nov 29, 2020 5:32 am
I use a shop made tower using ball bearing drawer slides and recycled bits'n pieces with a shop made cradle, Bosch Colt and SM bearing cutters.
Uses a counterbalance to reduce laminate trimmer weight to around 3/4 lb on the body.
Tower is held in a central end vise, cradle sits on plastic feet and slides around on a $1.50 offcut of melamine from DIY shop.
Inexpensive and works really well, use a climbing cut all the way.
PostPosted: Sun Nov 29, 2020 8:36 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I also use the Blues Creek Fleishman rig. I replaced the original trim router with the Rigid, which is much easier to micro-adjust from the front-located adjustment thumb wheel. I also did some minor shimming to bring the cutter surface perfectly perpendicular to the bench. I greatly prefer a setup where the guitar is stationary and I move and control the router. Too many years in cabinetmaking, I guess. Anyway, the rig works wonderfully when carefully set up and test cuts are made to get the right bearing. I also seal the top, sides, and back with shellac which helps to get a clean cut. I climb cut the entire circumference and then make a clean-up cut the other way.
It will probably be alright.
PostPosted: Sun Nov 29, 2020 10:12 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I build just over 1 guitar a year, having finished #9 in 8 years. For my first I bought this hand held version of Dave's, and also Chris Ensor's. If I recall, it was from Steve Kovacik (sp?), and it was $35. It has worked flawlessly and I have never made a mistake with it. I have installed wide purflings such as pearl without a problem. The thin, flexible masonite takes the place of a donut. On the downside, it is a little tedious to adjust - it uses a 1/4" bit and you move the fence and change the router depth to match your binding. And I have to make a practice run to get the action down - you have to push down and in along the base - not difficult, but you have to be aware.
If I ever change, it will be to make one like Dave's version of this simple jig, but this is ideal for the number of instruments I build
Ed M
PostPosted: Sun Nov 29, 2020 10:42 am
I'm contemplating using a dovetail bit the next time I cut binding ledges. I sometimes find myself relieving the inside corner of the binding to get a better fit. If the bottom of the rout is undercut by the dovetail bit I think it might also make it easier to fine tune (with a file) those small depth discrepancies I sometimes get with a straight bit. The router would have to be firmly on the work before the bit contacted the body, and likewise the bit would have to be moved away before the router was lifted off of it. Otherwise oops_sign
I think I will practice on scrap first [:Y:]
PostPosted: Sun Nov 29, 2020 12:31 pm
City: Escondido
Zip/Postal Code: 92029
For those who have the LMI version, could you describe the “micro adjust rub collar”. The website is very light on details. What is it adjusting? The depth or height of the channel. How does it work?
Thanks.
PostPosted: Sun Nov 29, 2020 12:58 pm
First name: Brad
Last Name: Combs
Thanks.
There is a little lever that flips back and as you unscrew / screw the donut there are detents that the lever clicks into. Each click goes up/down .003”. So you can dial in the depth without having to fiddle with the router base. I use the DW611 which already makes it easy to get close (compared to the colt) and then dial it in with the donut.
Here’s a pic, hope it helps.
Brad
PostPosted: Sun Nov 29, 2020 12:59 pm
First name: Brad
Last Name: Combs
P.S. I need to vac under there. :D
PostPosted: Sun Nov 29, 2020 2:13 pm
City: Escondido
Ok. I see. It is a height adjustment, not a depth adjustment. Slick, but my Rigid laminate trimmer seems to do that well enough. I thought it was an ingenious way to dial in depth between bearings. I know I can use hacks like masking tape, but I thought they had come up with some slick solution.
These users thanked the author rlrhett for the post: bcombs510 (Sun Nov 29, 2020 3:38 pm)
PostPosted: Sun Nov 29, 2020 2:24 pm
Last Name: Parker
City: Charleston
In order to avoid confusion, I think of the LMI screw-on donut as a vertical depth of cut adjustment mechanism. After all, we are concerned about the depth of the cut in two dimensions.
I like the bearings approach, because I feel I get more consistent horizontal depth of cut that way (as opposed to the adjustable guide approach). But the downside with the bearings approach is that, while the vertical depth of cut is infinitely adjustable, the horizontal depth of cut depends on what bearings you can buy, and how much tape you want to mess with, in between bearing sizes.
I just accept that shortcoming and deal with it.
PostPosted: Sun Nov 29, 2020 3:43 pm
I just thickness my bindings and purflings to match a bearing...I don’t need .073 or .078 bindings......070 is fine.
PostPosted: Sun Nov 29, 2020 3:44 pm
I relieve the inside corner of the bindings as standard practice.
Using a dovetail bit sounds like trouble...
PostPosted: Sun Nov 29, 2020 3:54 pm
City: U.P.
On the other end of the binding ledge cutter spectrum. I made a two of these. Since I love making anything with my hands that takes some skill and light "engineering", I enjoyed making them as much as using them. Almost as much fun as making instruments. My bro-in-law and I both really like them.
Since most woodworking tools work with non ferrous metal, it was a wood shop project. Most all the parts swivel on bearings so it works with minimal resistance. A spring connects the router end to a hook in the ceiling so weight of the articulating arm is almost neutral. The router swivels on the end of the arm.
It was a really fun project.
The picture was taken after first assembly and it didn't take any tweaking afterward except improvements in the anti gravity spring thing.
Brian
Brian R, Wood Mechanic
N8ZED
