It is currently Fri Aug 22, 2025 11:21 am
PostPosted: Fri Nov 20, 2020 8:22 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
This one is going be heading off to Colorado after it has had a chance to settle in for final tweaks. In terms of the woods used, it's a twin of the prototype I built last spring. Sitka spruce top; claro walnut back, sides, headplate, and rosette ring; khaya neck; Indian rosewood fingerboard, bridge, and binding. The scale length is 20". The body is similar in size that of a baritone ukulele. The lower bout is 10 1/2" across.
I lightened up the bracing a bit on this one compared to the prototype. I tapered the lower x-brace arms more and scalloped their ends further back from the rims. Also reduced the height of the tonebar a bit. It sounds a bit louder. I like how it sounds. At least as good as the first one. I'll see how much it changes over the next few days.
The most significant change I made was to use standard guitar fretwire (LMI FW74) instead of smaller mandolin fretwire. The taller height of the wire improved the playability enough that I plan to refret the prototype.
These users thanked the author J De Rocher for the post (total 2): Durero (Wed Mar 17, 2021 3:52 pm) • Michaeldc (Tue Dec 01, 2020 8:05 am)
PostPosted: Fri Nov 20, 2020 8:23 pm
First name: Jay
City: Bothell
State: Washington
Two more:
These users thanked the author J De Rocher for the post (total 2): Michaeldc (Tue Dec 01, 2020 8:05 am) • Pmaj7 (Sat Nov 21, 2020 11:13 am)
PostPosted: Sat Nov 21, 2020 12:26 am
Yeah, man.
These users thanked the author Chris Pile for the post: J De Rocher (Sat Nov 21, 2020 1:11 am)
PostPosted: Sat Nov 21, 2020 10:44 am
First name: Brad
Last Name: Combs
Seriously a beauty! Do you have a sound clip of either one? This is the instrument Sarah Jarosz plays?
These users thanked the author bcombs510 for the post: J De Rocher (Sat Nov 21, 2020 3:08 pm)
PostPosted: Sat Nov 21, 2020 10:53 am
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Zip/Postal Code: 95492
Superb workmanship and design. I too would like to hear a sound clip.
Brad Hall
Mystic Dawg Guitars
These users thanked the author BradHall for the post: J De Rocher (Sat Nov 21, 2020 3:09 pm)
PostPosted: Sat Nov 21, 2020 1:00 pm
Sarah is quite the multi-instrumentalist.
PostPosted: Sat Nov 21, 2020 1:19 pm
First name: Jay
City: Bothell
State: Washington
Sarah Jarosz does play an octave mandolin (among other instruments), but hers has an archtop guitar type body.
These users thanked the author J De Rocher for the post: bcombs510 (Mon Nov 23, 2020 8:19 pm)
PostPosted: Sat Nov 21, 2020 3:03 pm
First name: Jay
City: Bothell
State: Washington
Here are a couple short videos of how the prototype sounds. I recorded them using my iphone so take that into account. In the second video playing single note stuff, you can hear bit of string buzz that was caused by using the short mandolin fretwire I used on that one. The short height of that fretwire means that if you place your finger any distance away from the back of the fret, the string bottoms out on the fretboard right away and you don't get enough downward string pressure on the fret to prevent some buzz when picking with a thick pick. The higher fretwire I used on the new octave mando solved that problem.
https://youtu.be/8XDbUfs_JC8
https://youtu.be/K6fdX6FO4Eg
PostPosted: Sat Nov 21, 2020 4:05 pm
Very nice.
These users thanked the author Chris Pile for the post: bcombs510 (Mon Nov 23, 2020 8:19 pm)
PostPosted: Sun Nov 22, 2020 9:22 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Nicely done
Ed M
These users thanked the author Ruby50 for the post (total 2): bcombs510 (Mon Nov 23, 2020 8:19 pm) • J De Rocher (Sun Nov 22, 2020 7:39 pm)
PostPosted: Wed Feb 10, 2021 4:27 pm
Beautiful instrument! I did something similar awhile back, but used a tailpiece bridge. The down force was way more than I expected, and the top didn't hold up well. I want to repeat the build soon, but make it like you did, with regular pinned bridge. Thanks for sharing your experience and the pics and clips!
Ken Mitchell
Durham, NC
These users thanked the author Ken Mitchell for the post: J De Rocher (Wed Feb 10, 2021 8:20 pm)
PostPosted: Wed Feb 10, 2021 6:04 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Beautifully made! Nice work!
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: J De Rocher (Wed Feb 10, 2021 8:20 pm)
PostPosted: Wed Feb 10, 2021 8:25 pm
First name: Jay
City: Bothell
State: Washington
Just in case you didn't run across it, there's a previous thread on the prototype I built for this instrument early last year that has a lot more detail if you're interested.
https://www.luthiersforum.com/forum/viewtopic.php?f=10128&t=53129
PostPosted: Wed Mar 17, 2021 1:57 pm
First name: Big
Last Name: Jim
I really like that bridge design idea !
These users thanked the author WudWerkr for the post: J De Rocher (Thu Mar 18, 2021 11:46 am)
