It is currently Sat Jul 26, 2025 6:29 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2  Next
 Post subject: Recovering from errors
PostPosted: Tue Sep 29, 2020 9:21 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Sometimes they get to be too much. I'm taking a break and building some handplanes. Maybe some bench appliances and other stuff until I'm not so aggravated about the last error. Instant gratification zmthings so I can feel good about my woodworking again. Everyone is asking, you not building guitars? No just need a break.
Sent from my SM-A515U using Tapatalk
Hutch
PostPosted: Tue Sep 29, 2020 10:08 am
I’m still a noob so I feel it man. That said I’ve seen some VERY experienced builders make some pretty rough mistakes too.
With me I find that my mistakes are of 2 types
1- inadequate skill to achieve my desired result
Or
2- poor measurement and or execution
Both of these can be improved upon. One thing I’m working on is my neck building / carving.
I have 4-5 2nds neck blanks that were cheap, and I’m simply working through my process and giving a few skills and problem areas.
I’d encourage you to take a break but don’t give up. :) clean the shop, build some jigs or new molds .... then identify the areas that need work and find ways to concentrate on that one thing. If you are screwing up because of needing a particular tool that will make like simpler consider just getting what you need to progress.
You got this!
PostPosted: Tue Sep 29, 2020 10:14 am
First name: Richard
City: Warwick
State: RI
Thanks, yes I'm taking the time to think about how to make the fix without making it worse which is where I'm at. I'm still hav6fun in the workshop and that's all that matters. Image
Hutch
PostPosted: Tue Sep 29, 2020 10:23 am
Curious as to what error you’ve managed to achieve?:)
PostPosted: Tue Sep 29, 2020 10:36 am
First name: Richard
City: Warwick
State: RI
I'm not ready to talk about it.
Hutch
PostPosted: Tue Sep 29, 2020 10:54 am
First name: Ken
Last Name: Nagy
City: Goodrich
Nice plane. I made a convex bottom plane to rough out a cello. It sort of worked, but self destructed! I made a different one to carve out my arch-top, and it works great. Lei-Neilson scrub plane blade. I need to get an arch-top belly, or a cello back and sides, I have a cello belly, and a couple pieces for arch-top backs. It is fun to make and fun to use, but it is too big for violins or violas. Makes a ton of chips. I'm not a gouge guy.
I'm doing my third varnish on a violin I made a couple years ago. Can't get it right. So far I haven't wrecked it.
Why be normal?
PostPosted: Tue Sep 29, 2020 11:20 am
Know how you feel.
Got a build ongoing, at the finishing stage, and it's not been smooth going.
One major one was problems with the binding and purflings, and had to rout them off and start again. gaah
Got to the neck carving and had yet an another "accident" (carelessness basically)
Realized that the treble shoulder of the neck was "lumpy" - felt quite good in the hand but it was going to show badly under finish - I was pore filling with epoxy at the time. [headinwall]
So took some time out, and went for a nice country walk today, took my time to think about it.
Realized I'd not really been paying enough attention to what I was doing, so I have "improved" my neck carving support jig to give better access to the shoulders of the neck by dropping 45 degrees to the side each way and still be firmly held in a vice.
Looks like it's worked out well, and it will be a help in future, but I was well sickened at first.
These users thanked the author Colin North for the post (total 2): bcombs510 (Tue Sep 29, 2020 1:22 pm) • Michael Lloyd (Tue Sep 29, 2020 12:18 pm)
PostPosted: Tue Sep 29, 2020 11:24 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
A few months ago, I made a pretty bad mistake, and it caused me to have to replace the back on the guitar after I had closed the box, but before the binding had been installed.
The moment after it happened, I threw an honest-to-goodness violent tantrum and beat a poplar board against the cast iron legs of my workbench. It didn't harm the bench legs, but it tore the crap out of the poplar board.
That got the anger out of my system. I then moved on to replace the back.
I think that it is important to use every guitar at the early stages as a learning experience, something that is necessarily going to be imperfect; maybe even deeply flawed. Then I can learn from those mistakes and make the next one better than that last flawed piece of work. Improvement can only occur with continued work, continued flow. If you shut down, the work never gets better. Ever.
So, I recommend getting back on the horse. But I also highly recommend a good destructive tantrum in the moment that won't cause harm to you, your family, or any stuff you care about. It did wonders for me. Not unlike a good cry can help some folks get past their feelings. You need an outlet for the anger.
PostPosted: Tue Sep 29, 2020 11:54 am
First name: Marcus
Last Name: Bailie
City: Kirkland
I've chucked workpieces across the shop in a fit of rage. I try not to do that anymore as it obviously makes for more work to repair, so now I just try to walk away immediately to cool off. I do like the idea of having a poplar board handy, tho! laughing6-hehe laughing6-hehe
I took a 7 year break, mostly to raise my children, but also because I was finding guitar building as a novice very very frustrating. It takes time to learn how to make your guitars great, and to spend seemingly countless hours building something to just have it turn out garbage is pretty defeating.
I will be finishing up a guitar that has had multiple catastrophic mistakes happen on it, when i string it up i will know if it was worth it or not...
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Tue Sep 29, 2020 12:30 pm
In the "old days" when I made a bad mistake ,I would give up and wreck the piece or just saw it up ion the band saw....
Now when I make a mistake, I am calm...….ooooooooommmmmmmmm and I walk away and think how to fix it. It make take an hour or a few days, but I usually come up with a way to fix it and honestly more times than not it works out to be "better" than my original design.
The last example I can think of was when my router collet wasn't tight enough and the bit slipped while routing the binding ledge.
The solution was to add side purfling which in this case looked better than having no side purfling since it was a "fancy" guitar.
These users thanked the author Brad Goodman for the post: bcombs510 (Tue Sep 29, 2020 1:19 pm)
PostPosted: Tue Sep 29, 2020 3:56 pm
It's always good to have two or three projects going at the same time.When you screw up on one you can move on to another. That gives you time to weigh your options and decide what you want to do. I have come back to a project hours, days, and even years later.
If this was something I did for a living it might be more stressful, but it's not. I like to try out new ideas, some of which are bound to fail. That's part of learning
PostPosted: Tue Sep 29, 2020 4:04 pm
Last Name: Ball
I've pretty much done like banjopicks--I keep several projects going at the same time, but only two instruments (one with finish curing waiting to buff out and another being built). My other projects have been either jigs/tools or stuff around the house. If I'm feeling unlucky with instrument building, I'll either work on a jig I've been messing with that might not require the same level of fine handwork, or I'll get back to fixing stuff at the house. But I try to be like Brad--when I mess something up, I get out of the shop, take a walk, get a fresh outlook on things and then figure out what I did and what it will take to fix it. Except for those times that I cut and burn....(very infrequent any more thank goodness)
PostPosted: Tue Sep 29, 2020 4:13 pm
I have the very same thing with a loose collet, cut way below the binding line on the lower bout. Lucky my wife stopped me throwing it across the garden, left it for a week.
Came up with the same idea as you and side purlin was used and ended up looking good and like it was planned.
Loads of other stuff has gone wrong and no doubt more to come
Sent from my SM-A715F using Tapatalk
PostPosted: Tue Sep 29, 2020 4:29 pm
I routed the top off of a recent guitar. There was nothing really wrong with the top, but I decided the quality of it was not up to the quality of the back and sides, I should not have chosen it for that guitar.
This may sound stupid, but my work has risen to a level that I feel a responsibility not to make choices that degrade the guitar, to "not accept" a lower quality piece of wood or let a cosmetic error "pass".
I have also found that larger and larger pickguards really help!
PostPosted: Tue Sep 29, 2020 4:43 pm
Here’s the guitar I was talking about.
Originally I planned on having no side purfling which in hindsight looked too plain, so I think it came out really nice with the six line purfling .
Looking at this guitar just reminded me that I had another error that was a lot of work to fix-I can't remember why, but the binding didn't come out perfectly even in thickness so I had to rout it off including the top purfling and start all over again.
These users thanked the author Brad Goodman for the post: cablepuller1 (Wed Sep 30, 2020 4:14 pm)
PostPosted: Tue Sep 29, 2020 4:50 pm
First name: Richard
City: Warwick
State: RI
Nice save!
Hutch
PostPosted: Tue Sep 29, 2020 6:33 pm
Last Name: Ball
Very nice save! Did you re-do the tail graft too? You shouldn't have confessed--no one but you would have ever known. But thanks just the same.
PostPosted: Tue Sep 29, 2020 6:46 pm
When it comes to slipping collets one thing to check for is that the router bit hasn't bottomed out in the spindle. The collet pulls the router bit down as it is tightened. If the shank of the bit bottoms out on the spindle the collet will seem to tighten against the bit but will not fully seat against the sides of the spindle shaft. When the bit is run against the work the collet will loosen and the bit will slip.
I try to tighten the collet until it barely grips the bit, pull the bit up a little, then fully tighten the collet. It's not the only reason bits slip, but it is one reason.
These users thanked the author Clay S. for the post: cablepuller1 (Sat Oct 03, 2020 3:32 am)
PostPosted: Tue Sep 29, 2020 6:55 pm
First name: Brad
Last Name: Combs
Fascinating. I have done this since I was a kid. My dad showed me the same thing, bottom the bit out and raise it up just a bit before tightening. I never questioned it and do it to this day with any kind of bit. I never knew the why until just now. :)
PostPosted: Tue Sep 29, 2020 8:36 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I have so many of them, I couldn't think of a good example. [headinwall]
These users thanked the author CarlD for the post: Colin North (Wed Sep 30, 2020 1:22 am)
PostPosted: Wed Sep 30, 2020 7:58 am
City: Tyler
I recover from mistakes by accepting them. I’ve concluded that I’m going to have them. Usually, when the instrument is finished, they aren’t a big deal. I’m the only one that notices them and they only bug me. Remember the mistake on the next build.
Oh, and I should add, mine don’t get sold!
PostPosted: Wed Sep 30, 2020 8:43 am
I hadn't put the tail graft in yet.
PostPosted: Wed Sep 30, 2020 6:35 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I never make the same mistake twice. With such a wide variety of new mistakes to make, that wouldn't be any fun.
I used to work on wooden boats, and a mistake there can cost some real coin, so you learn to make do. A craftsman never blames his tools, and that's why I borrow them whenever I can
Ed M
PostPosted: Thu Oct 01, 2020 6:00 pm
First name: Hans
Last Name: Mattes
City: Petaluma
Zip/Postal Code: 94952
I've built around 20 6-string acoustic instruments (mostly guitars). The more recent ones have fewer errors than the earlier ones. I consider that progress.
Some of the most useful, if unexpected, skills I've acquired are in the domain of disguising errors, either to make them less evident or to make them into features.
I'm inevitably embarrassed to inspect a mid-dollar Asian-built guitar and note the quality of execution. That embarrassment generally diminishes when I play the instrument.
PostPosted: Thu Oct 01, 2020 6:39 pm
I agree, there's real value in mistakes. They help you refine your building process if you stop to think about why the occurred.
My building processes are pretty good these days :)
cron
