It is currently Fri Jul 18, 2025 8:07 pm
 Post subject: Reamer sharpening?
PostPosted: Fri Sep 25, 2020 12:14 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I was digging around in my garage automotive toolboxes and found a tapered reamer I bought who-knows-when. Thought I could get more use out of it in the lutherie shop, but I'd like to get it sharpened and restored to the sharpness it had when it was new. Is this done? If so, who does it? And what do I ask for? Economics aren't as much a factor as the satisfaction of rescuing a dormant tool,
Thanks, folks.
Peter Havriluk
 Post subject: Re: Reamer sharpening?
PostPosted: Fri Sep 25, 2020 2:59 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
try passing a stone over the inner surfaces of each of the "blades", much like you would sharpen a router bit. Keep the stone flat on flat of the blade.
Ed M
PostPosted: Fri Sep 25, 2020 4:50 am
Thanks, folks.
Is it a straight or a spiral reamer?
Straight you may be able to do it as Ed said, spiral - trickier.
PostPosted: Fri Sep 25, 2020 7:40 am
First name: peter
Last Name: havriluk
City: granby
State: ct
I'm no help...never sharpened a router bit, either!
Peter Havriluk
PostPosted: Fri Sep 25, 2020 8:04 am
Last Name: Minch
City: Chestertown
Here is a set of instructions for a reamer meant for more precision and for metal, but look at the drawing and tip #6
https://www.brownells.com/userdocs/learn/Inst-161.pdf
Ed M
PostPosted: Fri Sep 25, 2020 8:11 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Very helpful, thanks!
Peter Havriluk
PostPosted: Fri Sep 25, 2020 10:20 am
If there are any machine shops in the area, there will be a tool sharpening shop. Call them and ask around. It's really not a DIY job if you want best performance.
PostPosted: Fri Sep 25, 2020 10:26 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Thanks, Chris. I think my takeaway here is that these things can be sharpened. That sounds good to me; I didn't want to discard a tool that could otherwise do a job for me.
Peter Havriluk
PostPosted: Fri Sep 25, 2020 10:34 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Oh, well. Just got off the phone with my local friendly saw shop. . . Uneconomic by a lot.
Thanks, folks. Any work on the reamer will be DIY. That link will be handy.
Peter Havriluk
PostPosted: Fri Sep 25, 2020 12:06 pm
City: U.P.
You could check with these guys who advertise with such services.
https://boggstool.com/
I've been throwing old files and rasps in a box to send them when moved to do so but have not yet tried it.
I'd love to have old files and rasps restored.
They claim sharper than new.
Brian R, Wood Mechanic
N8ZED
PostPosted: Fri Sep 25, 2020 6:49 pm
Last Name: Minch
City: Chestertown
I have used Boggs - amazing. I know people who send them NEW files and they do come back better. You can fit an uncanny number of files in a Priority Mail envelope. I have also used Muriatic Acid to sharpen old ones - you have to watch and check every 20-30 minutes and use baking soda to neutralize, but they get MUCH sharper. Don't know if it would work on a reamer though
Ed M
These users thanked the author Ruby50 for the post: Pmaj7 (Sat Sep 26, 2020 1:02 am)
PostPosted: Sat Sep 26, 2020 7:17 am
I would hesitate to use muriatic acid on a reamer. Files have small teeth that nibble away at the work, the acid "sharpens" them by leaving them a bit snaggletoothed. Reamers are more knife like, and should produce a shearing cut. A small diamond hone might be the way to go.
http://eze-lap.com/products/diamond-hone-stone/
PostPosted: Sat Sep 26, 2020 8:38 am
Last Name: Howell
City: Atlanta
State: Ga
I used reamers for windsor chairs. Made one , bought a large 1" metalworking thats over kill for wood. Also bought a spoon taper bit that works great in soft wood.Last year I made one for bridge pegs from the shank of a spade bit. I found instructions somewhere.
The small one used to clean up small pipes is great for tuner holes dull or sharp.
I have learned a lot here and other luthier forums about metal working procedures that seem to apply to luthier work great..
Never thought of sharpening a file.
Bob Howell
PostPosted: Sun Sep 27, 2020 6:37 pm
If you haven't got a slip stone that fits between the cutting edges of the reamer you can always turn to abrasive paper, perhaps glue it to a thin veneer.
I have a few reamers and one of them really could do with sharpening.
PostPosted: Mon Sep 28, 2020 12:31 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
IMHO the only reason to sharpen an old reamer is because no one makes a duplicate to replace it.
All the above procedures will work especially if you are hand reaming, but you are not sharpening the reamer you are polishing it. For a one off it is fine but it will not last and if power driven will usually overheat. Even regrinds don't last as long as the original and I have had boxes of tools resharpened and custom made over the years.
If it's for a one off I have had better luck drawing a carbide scraper over the edge and throwing up a burr similar to what you would do to a card scraper. That will actually cut. Reamers, as Peter found out, are meant to be perishable tooling and not worth reconditioning.
