It is currently Wed May 07, 2025 2:22 pm
PostPosted: Thu Sep 24, 2020 5:30 pm
I am trying to duplicate John Greven's grain filling technique with System 3 Silvertip Epoxy.
Can anyone tell me if they are using the fast or slow set?
Formerly know as Mandodiddle.
PostPosted: Thu Sep 24, 2020 5:35 pm
City: Tyler
I use the slow and it works fine for me. Overnight. But I’m in no hurry, usually.
PostPosted: Thu Sep 24, 2020 6:06 pm
Last Name: Colbert
City: Anacortes
I use the fast. Plenty of open time and can recoat in 6hrs. Also: Silvertip doesn’t need to be sanded between coats as long as you recoat within 72hrs.
Pretty sure John used the fast...
PostPosted: Thu Sep 24, 2020 6:57 pm
disclaimer: I know squat about this subject as it relates to grain filling
but...
from many years of experience using epoxy as a glue I can confidently say the fast cure stuff is no where near as long lasting as the slow cure...by that I mean the fast cure stuff fails after a time whereas I've never had a joint fail using the "old school" 24+ hr curing time versions
PostPosted: Fri Sep 25, 2020 3:12 pm
I use slow cure. I find it works better in the end and I always have more than one thing on the go, so time is not an issue.
Brent
PostPosted: Fri Sep 25, 2020 4:05 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I haven't had any issues with the fast cure, but I have limited experience so far. I love the product, overall.
These users thanked the author doncaparker for the post: Michaeldc (Fri Sep 25, 2020 6:33 pm)
PostPosted: Mon Sep 28, 2020 1:27 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
In John Greven's presentation to the Seattle Luthiers Group, he said he used the fast hardener.
but...
I'm wondering if failure in a joint and failure as a micro-thin unstressed layer under a finish would be the same or different things.
These users thanked the author J De Rocher for the post: Michaeldc (Mon Sep 28, 2020 1:41 pm)
PostPosted: Mon Sep 28, 2020 8:30 pm
J De Rocher wrote:
but...
a question who's answer I wonder about, hence my taking the time to post about my experiences with fast vs. slow epoxy...I guess my "worries" revolve around the concept of delamination from either the substrate (wood) or the finish, or both I guess with the wood side going first and that affecting the finish... idunno or perhaps something unsightly like a whitish effect occurring where the epoxy starts to break up yet is still holding, again idunno
experience has taught me to avoid using fast cure in all cases that something is going to be under load and needs to stay put, and that of course is not the case with grain filling...what I have observed when I've had to deal with failed epoxy uses is that the failures basically shatter the epoxy, which leads me to use the term "brittle" when referring to the stuff, and that brittleness is what makes me pause and reflect.
Users browsing this forum: Bing [Bot], Ken Lewis and 52 guests
