It is currently Sun Jul 27, 2025 5:53 am
PostPosted: Sat Aug 15, 2020 4:42 pm
First name: Raul
Last Name: Ortiz
There's got to be a name for this, I know I'm not the first one to do it. But, I'm really happy that it looks like it's going to work.
I'm building with beautiful Ziricote that has some great sapwood that I love. It ran to the edge of the sides. I didn't want to loose the stunning pattern! So, I cut enough to make a binding, then cut the same amount from the non sapwood side and glued it where the sapwood was. This way, when I route out the binding channel, I can just put in my beautiful sapwood bindings that will match perfectly (hopefully) to the sides. I was afraid the glue would give when bending the sides, but it held!
I guess I didn't have to use binding from the opposite side, could have just been a cheap wood, but it worked.
Anyway, just wanted to share. Have a good one, my friends!ImageImage
Sent from my SM-G950U using Tapatalk
PostPosted: Sat Aug 15, 2020 5:23 pm
Last Name: Kincheloe
Hate to break it to you but it looks like you forgot to account for the thickness of the soundboard...
It is a good idea though.
These users thanked the author DennisK for the post: guitarradTJ (Sat Aug 15, 2020 5:35 pm)
PostPosted: Sat Aug 15, 2020 5:36 pm
First name: Raul
Last Name: Ortiz
Yep.....yep...... yep.....time to hit the cooler.
PostPosted: Sat Aug 15, 2020 5:43 pm
First name: Raul
Last Name: Ortiz
Looks like the sides are going to have an added "purfling" about the the same thickness as the top... My goodness, how do I miss that?
PostPosted: Sat Aug 15, 2020 6:12 pm
If you build with a rigid outside mold and radius sanding dish, you can just glue the linings down a little lower, plane some wood off, and sand the rest. Always easier to take some off than to put it back :)
These users thanked the author DennisK for the post: guitarradTJ (Sat Aug 15, 2020 6:28 pm)
PostPosted: Sat Aug 15, 2020 8:29 pm
I'm amazed that actually worked. You could always treat it as though the top has no binding and just round over the spruce edge. That would be truly unique.
These users thanked the author jfmckenna for the post: guitarradTJ (Sun Aug 16, 2020 10:38 am)
PostPosted: Sat Aug 15, 2020 8:42 pm
First name: Brad
Last Name: Combs
Yep, I did the same for a uke I’m working on. It’s basically binding and purfling height - thickness of soundboard is how much you want to laminate onto the side.
The goal is to preserve this:
Like Dennis said, you can always just take it lower in the radius dish but you’ll lose overall body depth for however much you take off.
I too love ziricote! :D
Brad
These users thanked the author bcombs510 for the post: guitarradTJ (Sun Aug 16, 2020 10:38 am)
PostPosted: Tue Aug 18, 2020 7:27 pm
First name: Raul
Last Name: Ortiz
Gramil, just what the doctor ordered!Image
PostPosted: Tue Aug 18, 2020 9:05 pm
Cool idea!
These users thanked the author meddlingfool for the post: guitarradTJ (Wed Aug 19, 2020 1:12 am)
PostPosted: Tue Aug 18, 2020 10:15 pm
I just glue in my lining taller. You also have to do the blocks taller, lest you end up gluing something on top of them to compensate. Not too bad on the soundboard side, but the back not so much. Damhikt!
(If I'm understanding that right. You don't want to lose a nice wood feature when you route it off for bindings?)
These users thanked the author Pmaj7 for the post: guitarradTJ (Wed Aug 19, 2020 10:40 am)
PostPosted: Wed Aug 19, 2020 10:53 am
First name: Raul
Last Name: Ortiz
Yep, that's exactly what I was trying to do! Fortunately I only had sapwood on the soundboard side, I left the back side normal. Those are also great solutions!
I ended up just taking 1.5 mm off of the sides, which is the thickness of my side purfling and half the thicknes of my top. I'll still see a bit of the dummy binding once I'm finished, but luckily I made it out of Ziricote.
So, my sides should look like this:
-Binding (with sapwood)
-1.5 mm purfling (3 strips)
- 1.5 mm of the dummy Ziricote binding
-Side of the guitar that matches the sapwood on the binding.
I should be binding in a couple of days, I'll post pics.
Thanks again for everyone's input!
These users thanked the author guitarradTJ for the post: Pmaj7 (Wed Aug 19, 2020 10:57 am)
Users browsing this forum: doncaparker and 16 guests
