It is currently Fri Aug 22, 2025 11:17 am
PostPosted: Tue Aug 11, 2020 11:04 pm
Online
First name: Brad
Last Name: Combs
Hello,
I’m staring up a new tenor build which will have two firsts for me. It will be the first time using a hardwood top other than mahogany and it will be the first time using an x-brace on a uke. Should be a fun couple weeks. I’ll post pics along the way.
I also made a new bending form and a new form for laminating lining. The bending form is reduced 0.075 from the size of the outside mold. This should approximate my 0.065 side and 0.010 thick steel slat as part of the bending sandwich.
The laminating form is reduced 0.250 to account for 0.180 worth of lining and the 0.065 side thickness (~0.005 :)). I’m hoping using this reduced form will let the lining fit better without as much need for clamping.
Brad
PostPosted: Wed Aug 12, 2020 5:16 pm
City: U.P.
Mighty pretty wood there. Look forward to see it under finish.
Brian R, Wood Mechanic
N8ZED
PostPosted: Fri Aug 28, 2020 8:42 pm
Online
First name: Brad
Last Name: Combs
An update on where I’m at with this build. The sides are bent and blocks are in. The lining is laminated and cut. The side reinforcement is glued in. The back braces are on and shaped. The rosette is in and the upper transverse is on.
Brad
PostPosted: Sat Aug 29, 2020 9:10 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Great looking set, especially the sides. I like your tail block radiusing jig too
Ed
These users thanked the author Ruby50 for the post: bcombs510 (Sat Aug 29, 2020 9:15 am)
PostPosted: Sat Aug 29, 2020 12:00 pm
Looks good Brad!
So, you did a full width lining sandwich and then cut it into strips on a bandsaw? If so, did you need to use a caul in the waist or bouts sagitta?
Does your block radiusing jig register somehow on a certain pivot distance from the disc?
These users thanked the author Pmaj7 for the post: bcombs510 (Sat Aug 29, 2020 1:48 pm)
PostPosted: Sat Aug 29, 2020 1:47 pm
Online
First name: Brad
Last Name: Combs
Pmaj7 wrote:
Looks good Brad!
Thanks, Pat!
For the lining I use spring clamps. I pretty much use Burton LeGeyt’s exact steps in his solid lining tutorial in the tutorial forum here except I use bias tape for the side reinforcement. For this Uke it’s not a tapered body so it makes it a bit easier.
In terms of needing a clamp at the waist, I’m starting to get that worked out. Initially I was bending the side and the linings sides all on the same bending form. It would work but I would have to torture the lining to get it clamped in place. Recently I’ve been making new molds for all the shapes I build and making them so they are reduced size. What I mean is, I used to make a bending form by taking the outside mold, tracing that shape onto a board and cutting it out to use as the template for making the bending mold. Of course doing that doesn’t account for the 0.075” or so side thickness. Also there is the thickness of the metal slat in the sandwich to add in as well. Mine are 0.020 thick. So what I did was made a bending form template as usual and then use a rabbeting bit to reduce it by 0.095 which gives me space to accommodate my normal side thickness of 0.075 and the 0.020 slat on the bottom of the bending sandwich. So that sorts the bending form for the side.
For the laminated lining, I did the same thing but reduced it down by 0.250” to account for the thickness of the side plus the thickness of the lining strips after laminating them. I use that form for bending the lining sides, I bend all three at the same time, and then use that same form when laminating them together.
It’s not 110% dialed in, but it’s very close and things nest together a lot better now that I’m doing it this way. I did the same for the molds for the last two Dred’s that I finished and they were also a lot easier to fit together. Hope that makes sense.
This is the clamp setup.
Close up of the waist and how things seat together.
Like I said, it’s still a little fiddly but manageable compared to before when I was using one mold.
In the future I want to spend time learning to bend on a pipe. I think I could tweak on the fly if I was using a pipe vs needing so many molds. Maybe not though. :)
Brad
These users thanked the author bcombs510 for the post: Pmaj7 (Wed Mar 10, 2021 4:46 pm)
PostPosted: Sat Aug 29, 2020 2:56 pm
Online
First name: Brad
Last Name: Combs
Forgot about the block radius jig question.
Yes, I just clamp a straight edge to the table on the sander. Then I have “sleds” for each body type. One end of the sled has the neck block shape, the other the tail block shape. You can see the bar clamped to the sander table which acts as a guide for the plate.
Brad
PostPosted: Sat Aug 29, 2020 6:41 pm
Online
First name: Brad
Last Name: Combs
Progress on the ziricote tenor Uke from today - The top is braced and the lining is installed. I decided to forego the finger braces in the end. Given the size of the body they won’t be needed.
Wakanda Forever!!
Brad
PostPosted: Fri Sep 04, 2020 1:07 am
Thanks Brad, but what I was asking about is how you made the linings. Did you make one wide lay up? I was wondering if you had any problems cutting it on a bandsaw. Like did you need to put a caul underneath it?
And for the radius in jig, I didn't see the bar in front of the abrasive. That's what I am making also. I thought maybe you did something like pivot the whole jig a certain distance back to give you that distance of a radius...
These users thanked the author Pmaj7 for the post: bcombs510 (Fri Sep 04, 2020 7:13 am)
PostPosted: Fri Sep 04, 2020 7:18 am
Online
First name: Brad
Last Name: Combs
Got it, no I just slice it up. The lining is paulownia which cuts so easily there is no resistance on the bandsaw so it slides through easily.
Got it. No, it’s just the front edge of the sled running against the bar. I do want to switch to 120 grit, there is more cleanup of the block than I like and introduces opportunities for me to mess it up. :)
These users thanked the author bcombs510 for the post (total 2): pkdz (Sun Oct 25, 2020 7:59 am) • Pmaj7 (Sat Sep 05, 2020 12:47 am)
PostPosted: Fri Sep 04, 2020 7:49 pm
Online
First name: Brad
Last Name: Combs
Progress from today. The box is closed and the bridge is started. The final bracing measurements are below. It’s ringing and flexing nicely so I went ahead and closed the box.
Brad
PostPosted: Sun Sep 06, 2020 7:50 pm
Online
First name: Brad
Last Name: Combs
Progress from today. The neck joint is roughed in. Will floss it and final fit after the binding is done.
A little stub ground to a point that I use to locate the hole in the neck block.
Brad
PostPosted: Mon Sep 07, 2020 8:14 pm
Online
First name: Brad
Last Name: Combs
A little progress today for Labor Day. The binding is on.
Brad
PostPosted: Tue Sep 08, 2020 12:05 am
Awesome ziricote top! Is that some sort of white gluing caul on the outside of the bindings under the green tape?
These users thanked the author Pmaj7 for the post: bcombs510 (Tue Sep 08, 2020 4:03 am)
PostPosted: Tue Sep 08, 2020 4:05 am
Online
First name: Brad
Last Name: Combs
Hey Pat,
It is strips of HDPE that are the same size and thickness as the binding. It’s not on top though. I do a two step process, purfling first then binding. The strips act as a proxy for the binding to hold the purfling in the channel while I get it tacked in. Then I untape the strips, remove, and put the actual binding in as a last step.
Brad
These users thanked the author bcombs510 for the post: Pmaj7 (Tue Sep 08, 2020 7:40 am)
PostPosted: Wed Sep 09, 2020 7:23 pm
Online
First name: Brad
Last Name: Combs
Progress from today... No progress. :)
But the protective shellac coat made it pretty.
Brad
These users thanked the author bcombs510 for the post: Pmaj7 (Mon Oct 05, 2020 4:48 am)
PostPosted: Sun Oct 04, 2020 8:52 pm
Last Name: Colbert
City: Anacortes
Beautiful!
Thanks for sharing the build!
M
These users thanked the author Michaeldc for the post: bcombs510 (Mon Oct 05, 2020 10:12 am)
PostPosted: Sun Oct 11, 2020 5:19 pm
Online
First name: Brad
Last Name: Combs
I injured my back on Labor Day and just getting back to being able to hobble around the shop a bit. Here is the progress on the latest.
I put the head plate on and trimmed the fretboard to shape.
For the fretboard I use a two step template. First step puts the shape on the end, the second puts the taper on.
Brad
PostPosted: Tue Oct 20, 2020 10:21 pm
Online
First name: Brad
Last Name: Combs
Frets are in and everything has been final sanded. Pore fill and spraying this weekend.
Brad
These users thanked the author bcombs510 for the post: Pmaj7 (Tue Oct 20, 2020 11:02 pm)
PostPosted: Tue Oct 20, 2020 11:03 pm
Sweet fretting rig!
These users thanked the author Pmaj7 for the post: bcombs510 (Wed Oct 21, 2020 3:59 pm)
PostPosted: Wed Dec 23, 2020 8:24 pm
Online
First name: Brad
Last Name: Combs
In the true spirit of warts and all... I’ll add some pics where I had a failed finish.
The finish bubbled up very much like solvent pop, but what I learned is that it’s air coming to the surface from the heat applied by the UV light. This happened because I attempted to skip pore fill which I now know is a no-no with the UV materials. :) I stewed on this for almost 3 weeks while working on other projects. It was barely noticeable after leveling but was indeed there. It’s a tricky balance that I’m learning about when to pull the plug and redo something and when it’s fine to let it sail. On this one I want the finish to be perfect so I pulled the plug.
Also made a bridge for it today on the CNC. I’m new to CNC and the uke bridge is one of the first things I drew up in the software. Recently I added an engraving pass at the very end to mark the centerline and the string hole locations. These will get sanded off after the bridge is installed.
Brad
These users thanked the author bcombs510 for the post: Pmaj7 (Thu Dec 24, 2020 1:02 am)
PostPosted: Thu Dec 24, 2020 1:02 am
Good thinking on the markings. Slick!
PostPosted: Mon Mar 08, 2021 7:18 pm
Online
First name: Brad
Last Name: Combs
Sheesh, I work so slowly. :)
Getting to the buffing stage is satisfying.
Brad
These users thanked the author bcombs510 for the post: Pmaj7 (Wed Mar 10, 2021 4:43 pm)
PostPosted: Wed Mar 10, 2021 12:08 pm
Online
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Wow! That's gorgeous.
These users thanked the author J De Rocher for the post: bcombs510 (Wed Mar 10, 2021 3:59 pm)
PostPosted: Sun Apr 25, 2021 2:44 pm
Online
First name: Brad
Last Name: Combs
Nearly done. I still need to do a final setup and spit shine.
Brad
These users thanked the author bcombs510 for the post: Pmaj7 (Sat May 15, 2021 12:34 am)
