It is currently Fri Jul 11, 2025 8:02 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
 Post subject: Re: Saddle compensation
PostPosted: Fri Jul 17, 2020 12:24 pm
First name: Brad
Last Name: Combs
Colin North wrote:
I just use the inclinometer app on my phone and bluetack. Free and to 0.1 degrees.
I tried to get cute and make a little tray with a bridge pin fixed on it and put the phone in the tray with some putty. Seems I'm always over-engineering. ;)
PostPosted: Fri Jul 17, 2020 1:56 pm
Oooh, fancy..!
PostPosted: Fri Jul 17, 2020 2:15 pm
+1 on the bubble level app for the phone. It works great.
I can't understand this do you happen to have a pic?
Oh wait... Rereading... So the bridge pin that is attaged to the tray replaces like the D-String pin and actually holds the string in?
Brilliant!
I'd still love to see a pic if ya got one.
PostPosted: Fri Jul 17, 2020 6:27 pm
First name: Josh
jfmckenna wrote:
Do you guys actually set up to a specific string set though? I've always figured an average is what we should be going for. If you set up someone perfectly for 11's what happens when they switch to 13's?
In my experience players are often pretty married to a certain string gauge, at least on a per-instrument basis. They might use different gauges but it’ll be 13s on their dread and 12s on an OM, 9s on their strat etc. I don’t know many who jump back and forth regularly on the same instrument. Many are also brand-loyal as far as strings go too.
So I do usually set up to a specific gauge (and brand) of string.
PostPosted: Sat Jul 18, 2020 12:51 pm
I stuck a laser pointer to the bridge, and measured how far the spot on the wall moved. Long lever....
PostPosted: Sun Jul 19, 2020 5:54 pm
State: West Somerset
Country: UK
Apologies to Dave the OP but the issue of bridge rotation measurement is interesting.
Colin and Alan’s ideas both sound like a big improvement on previous techniques.
But I wanted to stress how useful the test is, however you do it.
After all the decisions about top thickness and bracing height etc, this is a properly objective measure of the stiffness of the soundboard plus bracing after the instrument has been put together. It can tell you if you overbuilt (which i along with most beginners probably do) and help with improving the next ones.
PostPosted: Sun Jul 19, 2020 6:13 pm
But I wanted to stress how useful the test is, however you do it. 8
After all the decisions about top thickness and bracinging height etc, this is a properly objective measure of the stiffness of the sounboard
I use it as a check after I've finished a guitar.
In the Gore book he suggests this as a maximum rotation to guarantee survival of a braced top, so indicating maximum response of the soundboard.
I've now got enough of a handle on soundboard stiffness (Elong) and bracing heights/stiffness that I have hit this target on my last 3/4 builds.
I've also used this to shave braces on an overly stiff Taylor souindboard - bass notes just dreadfully dull, and could I help - found bridge rotaionj was 0.8 degrees!, thickensess sitka top ~3.2mm.
Owner was so pleased with the results, he was impressed enough to end up taking a guitar building course with me.
How to do it - strings at standard tuning, set inclinometer to zero bluetacked on the bridge, dump all tension, read rotation.
Just make sure to hold the body steady in some way, don't support it on the neck at all.
Hope that helps.
These users thanked the author Colin North for the post: Durero (Tue Aug 11, 2020 1:28 pm)
PostPosted: Sun Aug 09, 2020 10:32 pm
Last Name: Livermore
State: Minnesota
Thanks all for joining in the discussion.
It sounds like we all seem to have own methods and jigs the work for us.
Mine is a home made saddle matic. But I decided to improve it and make it more consistent, which is what prompted the OP.
I dug into the math and used the StewMac site, the Cumpianos and other texts and figure out an ‘standard’ from which to work. After 4 hours of tinkering and figuring I have settled on what I originally figured. About 2mm on the treble side and about 6mm on the bass.
So there you have it.
I’ll experiment with trimmin the nut end down on a future build and maybe revisit this post.
dl
PostPosted: Thu Aug 13, 2020 4:14 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Are you talking about the typical angle used for the slot? or the adjustment to the saddle once slot is cut?
PostPosted: Thu Aug 13, 2020 5:07 pm
My saddle angle is 4mm over 71mm...
Users browsing this forum: Harry Martin and 23 guests
