It is currently Wed May 07, 2025 11:23 pm
 Post subject: Drop(ped) Top
PostPosted: Fri Jun 19, 2020 8:17 pm
First name: Mark
Last Name: Chinworth
City: Kirkwood
Zip/Postal Code: 63122
This is what happens when you drop your nearly finished guitar body onto a concrete workshop floor.
After two months of grumbling, and laying down padded carpeting, I have a basic plan: Replace the top.
Any other recommendations? Should I complete the new top before removing the old or vice-versa? I plan to harvest the rosette and reuse it for the new top. I doubt any bracing or the bridge plate can be saved.
Procedure outline:
1. Route off the binding and purfling with a bearing bit just a tad less depth than the top thickness.
This will leave behind the side purfling and some of the binding, but that will be taken off later.
2. Continue the route inward until I'm past the width of the kerfed lining.
3. Sharp razor to slice the tiny remaining fibers between the top and lining.
4. Put the body back into the mold and sand with radius dish to fresh lining wood.
5. Make new top.
6. Glue top to sides.
7. Flush route the top to the sides.
8. Route off remainder of old binding and side purfling.
9. Glue in new binding and purfling.
10. Clean up and sanding.
Anything else?
 Post subject: Re: Drop(ped) Top
PostPosted: Fri Jun 19, 2020 10:41 pm
Sorry this happened to you Mark but it sounds like you have a great plan to make it right. You will also not be sorry that you replaced the top. Your workmanship and planning is excellent and it's my guess that you will have a guitar to be proud of.
My only suggestion is while the top is off you will have a great opportunity to be absolutely sure that none of the other braces are loose. When a guitar gets dropped loose braces are pretty common.
PostPosted: Fri Jun 19, 2020 10:55 pm
Oh man! Sorry to hear. Great looking binding too. This too shall pass. Sounds liek you have your head on straight.
PostPosted: Fri Jun 19, 2020 10:59 pm
This might help...
http://grevenguitars.com/retopping-demo.html
PostPosted: Sat Jun 20, 2020 7:00 am
Looks like a nice top. Any chance you could make a smaller instrument with the undamaged part?
If you have some matching wood you could patch in the top or do a "cranked bevel" a la Mike Doolin.
http://acousticguitarconstructionforum. ... php?t=2988
PostPosted: Sat Jun 20, 2020 12:50 pm
Last Name: Beaver
City: Lake Forest
Been there, done that. Mine was on a refinish job. It bounced around some and managed to destroy the headstock, sides, and the back. I didn't take a picture, figured it would be better to forget....
Joe Beaver
Maker of Sawdust
PostPosted: Sat Jun 20, 2020 1:02 pm
meddlingfool wrote:
That's the method I use, works great.
Every time I have had to do this I have made a smaller guitar with the top. An 000 becomes an 00.
PostPosted: Mon Jun 22, 2020 5:50 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Quote:
Procedure outline:
5. Make new top.
Anything else?
11. Be careful not to drop it again
PostPosted: Mon Jun 22, 2020 8:50 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I'm sorry that happened Mark. It was looking really good too. I'm sure your recovery will be well executed.
Bryan Bear PMoMC
PostPosted: Mon Jun 22, 2020 9:57 am
I have used the procedure you describe a couple of times and have been able to reuse the rosette as well. Works well. I have not tried John Grevens technique but it would be nice not to have to replace the binding. I'm pretty sure I'm not as skilled as John :)
PostPosted: Mon Jun 22, 2020 12:38 pm
It truly is surprisingly easy to do.
PostPosted: Mon Jun 22, 2020 12:43 pm
Alright I'll have to give it a try, I have a candidate for it now.
