It is currently Tue Sep 16, 2025 2:05 pm
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jun 03, 2020 8:25 pm
First name: Bruce
Last Name: Sexauer
City: Petaluma
Zip/Postal Code: 94952
Country: Usa
The Madrone/Adi guitar now has the peone in which attach the sides to the top.
Bruce Sexauer, luthier
http://mojoluthier.com
PostPosted: Wed Jun 03, 2020 8:57 pm
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
Tnx Bruce, for the explanation of the upper winged brace . Sounds like a twofer., and your correct abt the adi top, , that is, trying to tone it down to get that flamenco sound . Have a bit of adi, it seems very stiff longtitudinaly, I have yet to use it. Are you going to make a sound sample ?? Thank you once again! .
PostPosted: Thu Jun 04, 2020 8:01 am
Nice looking work with the peones. When I have used them they have never looked so uniform and cleanly done.
PostPosted: Thu Jun 04, 2020 10:33 am
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
Being hand split, peone are never quite the same as each other, but being the same height helps. Spacing them the same also helps. It it possible the control the stiffness of the top to side connection somewhat by how closely the peone are spaced.
These users thanked the author Bruce Sexauer for the post: Clay S. (Thu Jun 04, 2020 12:48 pm)
PostPosted: Thu Jun 04, 2020 6:45 pm
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
The back will likely go on before the day is done. It is in the go-bar deck having "marriage strips" glued on.
PostPosted: Thu Jun 04, 2020 7:13 pm
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
Closed 'er up!
PostPosted: Fri Jun 05, 2020 10:09 am
Hi Bruce. I've seen some of your SS builds but this is the first nylon string.
I just noticed there's no bridge plate, is this typical for your NS instruments ??
Brent
PostPosted: Fri Jun 05, 2020 10:53 am
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
What would be the purpose of a bridge plate on a nylon stringed guitar?
These users thanked the author Bruce Sexauer for the post: bcombs510 (Fri Jun 05, 2020 1:25 pm)
PostPosted: Fri Jun 05, 2020 8:41 pm
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
Today I rough-carved the slots in the headstock and put on the first 2 quarters of the binding.
PostPosted: Sat Jun 06, 2020 6:55 pm
Sorry, mix-up in terminology. Many of the drawings I've seen for classical/flamenco instruments have a bridge pad. The fan braces are notched to fit over it.
Brent
PostPosted: Sat Jun 06, 2020 7:07 pm
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
Brent
By whatever name, I see no purpose, and I do see weight where I wouldn't like to have it. I use a full caul under the top that matches the bridge footprint, so there is no need there. Most classical makers spend a lot of effort getting the bridge weight exactly whatever, and then there are several grams of what-ever-it's-called added to the weight: Seems counter productive. The bridge is already the most powerful brace on the top, and surely mirroring it on the inside is unnecessary. If not, I'd like to hear about it.
Last edited by Bruce Sexauer on Sat Jun 06, 2020 10:40 pm, edited 1 time in total.
These users thanked the author Bruce Sexauer for the post: bcombs510 (Sat Jun 06, 2020 7:14 pm)
PostPosted: Sat Jun 06, 2020 7:20 pm
First name: Brad
Last Name: Combs
That’s interesting. I’ve wondered about the bridge plate for ukulele. I think I’ll skip it next one, see how it changes things. :)
Thanks for the tip.
Brad
PostPosted: Sat Jun 06, 2020 9:47 pm
Some makers use the bridge plate on nylon instruments to "balance the construction" similar to plywood, and some leave it out because they feel it - adds - stresses. Some of the best makers have used it , and some of the best makers have left it out. Romanillos said he has used it and said he has left it out. I guess he goes both ways. pizza
PostPosted: Sun Jun 07, 2020 1:16 pm
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
Today is my Daughter's Birthday Celebration, and I will take the day off . . . almost. The Madrone/Adi "Flamenco" is final sanding away from finish. Fresh pics:
PostPosted: Sun Jun 07, 2020 1:50 pm
I'm excited to see that under some finish! Looking good Bruce.
PostPosted: Mon Jun 08, 2020 4:35 pm
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
Here is the first coat of finish on the Madrone:
PostPosted: Mon Jun 08, 2020 5:02 pm
First name: Ken
Last Name: Nagy
City: Goodrich
Bruce, Are you using two carbon fiber rods on the neck? Do you use that on all guitars, or just the nylon strung ones?
Why be normal?
PostPosted: Mon Jun 08, 2020 6:26 pm
How did you create the dark lines between the back seams? They look too thin to be veneer, but too obvious to be unintentional.
PostPosted: Mon Jun 08, 2020 7:15 pm
First name: Kerry
Last Name: Werry
City: Coquitlam
State: British Columbia
Nice Idea, I did something sort of similar but went with woods that border the Pacific Ocean, Madrone (called Arbutus up here) and Koa for the top.. Turned out nice.
Kerry
J De Rocher wrote:
I'm looking forward to watching this. Having lived in the Northwest most of my life, madrone trees are one my favorites. I have two madrone back an side sets that also come from northern California. The tree was so big that the back plates are big enough to make two-piece backs. My plan is to build two steel string guitars using only West Coast woods, with the exception of the fretboard (unless I can find a suitable native wood for that).
What wood do you plan to use for the top?
My Website http://klw-strings.com
My Luthier's Blog...http://klwstrings.blogspot.com
PostPosted: Mon Jun 08, 2020 9:46 pm
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
I offer it as an option on SS, but it is standard on Nylon.
PostPosted: Mon Jun 08, 2020 9:47 pm
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
The lines are .012" black fiber.
These users thanked the author Bruce Sexauer for the post: Clay S. (Mon Jun 08, 2020 10:00 pm)
PostPosted: Mon Jun 08, 2020 9:48 pm
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
I did not realize Madrone and Arbutus are the same thing.
PostPosted: Tue Jun 09, 2020 9:51 am
First name: George
City: Seattle
Yup, the Pacific madrone is one of several arbutuses (arbuti ... arbutussaria ... arbutilicious?) or whatever the plural might be.
George :-)
PostPosted: Fri Jun 12, 2020 9:14 pm
First name: Bruce
Last Name: Sexauer
City: Petaluma
Country: Usa
I've got 6 coats of oil varnish on this guitar, and that's either one or two to go.
Probably bug you with some more pics in about a month, when I expect to string her.
PostPosted: Sat Jun 13, 2020 3:24 am
First name: Josh
Looks fantastic, Bruce.
