It is currently Mon Jul 28, 2025 4:44 pm
PostPosted: Thu May 28, 2020 6:55 pm
First name: Brad
Last Name: Combs
Hello,
I have the SM saddle routing jig and I want to fit the plex template to a plunge base for the DeWalt 611. The existing holes are just off from the alignment for the plunge base. I’d like to plug and redrill the holes.
Any tips on how I can do this? Can I simply use epoxy and will it hold if just putting a puddle of it in the hole while it’s sitting on wax paper or similar? Or will that just pop back out as soon as I go to drill it?
Ideas are appreciated.
Brad
PostPosted: Thu May 28, 2020 8:31 pm
Online
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
I'm doubtful about filling the holes in plexi. What if you rotated the alignment by 45 deg. and
drilled new ones??
These users thanked the author Ken Lewis for the post: bcombs510 (Thu May 28, 2020 8:45 pm)
PostPosted: Thu May 28, 2020 8:35 pm
Make it new....
These users thanked the author Chris Pile for the post: bcombs510 (Thu May 28, 2020 8:45 pm)
PostPosted: Thu May 28, 2020 9:26 pm
Last Name: Kincheloe
If you want to give it a shot, rough up the surface, wipe with alcohol or acetone to degrease, and mix some kind of powder (e.g. baking soda) with the epoxy to boost the strength. I've done that on 3D printed PLA and resulted in strong fixes. But plexiglass may be more resistant to adhesion.
These users thanked the author DennisK for the post: bcombs510 (Thu May 28, 2020 9:33 pm)
PostPosted: Fri May 29, 2020 12:25 am
You can use acetone to solvent weld plexiglass plugs into the existing plexiglass template. They also make special glues for it, but acetone works O.K. and is a component in most lacquer thinners (which may also work - test on scrap).
These users thanked the author Clay S. for the post: bcombs510 (Fri May 29, 2020 1:57 am)
PostPosted: Fri May 29, 2020 2:10 pm
First name: Brad
Last Name: Combs
Thanks for all the replies. Below is what I ended up with. I took a closer look at the plate from SM and the piece that slides in the channel was only attached with two pins. So I popped the pins out and glued it to the plate for the plunge base. I also drilled and tapped two 10-24 holes and screwed the plates together. Just in case. :) It’s ready to ride!
Here is the smaller plate that rides in the channel.
Center it up and glue it.
Added some screws.
In case anyone wants to upgrade. :)
Brad
These users thanked the author bcombs510 for the post: James Orr (Fri May 29, 2020 5:35 pm)
PostPosted: Fri May 29, 2020 5:36 pm
I have the same trimmer setup, the same jig, and the same desire to upgrade. Thanks, Brad!
These users thanked the author James Orr for the post: bcombs510 (Fri May 29, 2020 6:07 pm)
PostPosted: Fri May 29, 2020 6:09 pm
First name: Brad
Last Name: Combs
Cool, glad it’s useful. A note - think about the clamping you like to use and the ears of the plunge base and orient accordingly. If you like to use cam clamps position the base so that the ears won’t be blocked by the cam levers.
Hope that makes sense. :)
Edit: What I mean is glue the piece from the SM base so that the ears of your plunge base are out of the way of your clamp setup.
Brad
PostPosted: Sat May 30, 2020 2:09 am
Good call. I like the way you oriented it.
Users browsing this forum: Ken Lewis, Stuart Flavell and 16 guests
