It is currently Thu May 08, 2025 2:44 am
 Post subject: Dust inside the box!
PostPosted: Mon May 18, 2020 12:11 pm
Hi
What the best way for cleaning inside the box, fitting a LR bags system so want the cleats and stuff to stick okay.
TiaImage
Sent from my SM-A715F using Tapatalk
 Post subject: Re: Dust inside the box!
PostPosted: Mon May 18, 2020 12:21 pm
I am not sure what you are doing, but never vacuum in the box.
These users thanked the author wbergman for the post: cablepuller1 (Mon May 18, 2020 1:36 pm)
PostPosted: Mon May 18, 2020 12:55 pm
I use a vac every time as I don’t have a blower.
These users thanked the author meddlingfool for the post: cablepuller1 (Mon May 18, 2020 1:36 pm)
PostPosted: Mon May 18, 2020 1:19 pm
I use a vac all the time, just be real careful not to close off the sound hole or it can go real bad in a hurry and collapse the box. No different than working with any other power tool that can cause damage if misused. Often I will take a 3' or 4' piece of small diameter hose, maybe 1/2" or 3/4" ID, slide it a few feet into the regular vacuum hose and you can vacuum with that. It's safer and will get into smaller spaces if needed.
If there is goop that needs to be cleaned off then naptha is my first choice.
These users thanked the author SteveSmith for the post: cablepuller1 (Mon May 18, 2020 1:36 pm)
PostPosted: Mon May 18, 2020 2:00 pm
Last Name: Kincheloe
Toothbrush to loosen it up, then vacuum.
These users thanked the author DennisK for the post: cablepuller1 (Mon May 18, 2020 2:00 pm)
PostPosted: Mon May 18, 2020 2:15 pm
Last Name: Beaver
City: Lake Forest
I blow it out. It will take a while for all the dust to exit out the soundhole.
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: cablepuller1 (Tue May 19, 2020 2:36 am)
PostPosted: Mon May 18, 2020 2:58 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I always vacuum out the inside of the box using a small nozzle attachment. No problems.
These users thanked the author J De Rocher for the post: cablepuller1 (Tue May 19, 2020 2:36 am)
PostPosted: Mon May 18, 2020 3:06 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
For really dusty old boxes there is a tip that Frank Ford describes. Use some rice as an abrasive to clean out adherent dust and grime. Read it here (but note the disclaimer about the paper label):
http://www.frets.com/FretsPages/Luthier ... clean.html
These users thanked the author Mark Mc for the post: cablepuller1 (Tue May 19, 2020 2:36 am)
PostPosted: Mon May 18, 2020 4:13 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
I stick the air blower inside and the vac at the edge of the sound hole. Gentle on the trigger.
B
These users thanked the author Bri for the post: cablepuller1 (Tue May 19, 2020 2:36 am)
PostPosted: Mon May 18, 2020 4:15 pm
If you use rice (which works very well) have a vacuum cleaner handy to vacuum the rice out. I've used rice to clean up violins where a vacuum won't fit. Shaking that last grain of rice out through the ff holes can be rather frustrating. [headinwall]
These users thanked the author Clay S. for the post (total 2): Michael Lloyd (Tue Jun 16, 2020 7:23 pm) • cablepuller1 (Tue May 19, 2020 2:37 am)
PostPosted: Mon May 18, 2020 5:53 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
The rice idea is cool!
I blow through end pin hole, small vac tube in sound hole. I clean areas that will have sticky things attached (wire holders, soundhole volume, battery velcro) with Acetone.
These users thanked the author Mike OMelia for the post: cablepuller1 (Tue May 19, 2020 2:37 am)
PostPosted: Mon May 18, 2020 9:06 pm
I tried rice once, but it left the inside of the guitar covered with fine white powder and smelling like rice.
PostPosted: Tue May 19, 2020 9:38 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Easy - just a call away
These users thanked the author Ruby50 for the post: Pat Foster (Tue May 19, 2020 10:01 am)
PostPosted: Tue May 19, 2020 10:03 am
Blowing or vacuum, either way can go south. I know of once instance where a finisher blew the top off a guitar.
These users thanked the author Pat Foster for the post (total 2): cablepuller1 (Sun May 31, 2020 1:02 am) • Bri (Tue May 19, 2020 10:40 am)
PostPosted: Fri Jun 12, 2020 3:17 pm
The shop vac is too dangerous around the sound hole. I use a blow dryer on the no-heat setting. On old guitars with a build up of dust, thick and stuck in the corners, I reach in with a shop rag and drag it around to loosen it up before blowing, and hold my breath so I don't breathe in that nasty stuff.
If all you are doing is gluing something and not doing a general clean up, just rub the rag on the spot you need. I can reach most every corner of the guitar thru the hole with my hand and a shop rag. Skinny arms I guess.
PostPosted: Fri Jun 12, 2020 3:38 pm
Dust is not the problem. It's the dust bunnies, dead insects, and leftovers from small mammals.
PostPosted: Fri Jun 12, 2020 4:20 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Don't forget the roaches. The dropped ones. bliss
PostPosted: Sun Jun 14, 2020 11:34 am
A friend of mine got done working on a fiddle and called the customer to come get it. The guy asked if he'd replaced the tone ball; the dust bunny that absorbs all the objectionable high frequencies. 'Sure' he said, and then spent the next half hour while the guy drove by collecting dust balls from old fiddles. One can see a market for that: wool and linen tone balls for traditionalists, polyester for 'modern' music, and crystal tone balls for 'New Age'. We all know about the rattlesnake rattles the Texas players use to add 'snap' to the tone....
PostPosted: Sun Jun 14, 2020 1:42 pm
I use a vacuum with a thin flexable hose that fits all around the inside of the box. I never gave it a thought that it would implode O.o
Users browsing this forum: No registered users and 58 guests
