It is currently Mon Jul 28, 2025 5:19 pm
PostPosted: Thu Mar 26, 2020 4:45 am
Client has bought and is supplying his own fancy tuners for a commission, but I don't have then yet.
Trouble is we're in lockdown.
I'm looking for the headstock thickness to fit them.
I believe they are basically the same fitting dimensions as standard 510s, but can't find anything on the net for a headstock thickness range.
PostPosted: Thu Mar 26, 2020 6:15 am
First name: Victor
Last Name: Seal
City: Osseo
State: MI - Michigan
Zip/Postal Code: 49266
LMII has a blueprint of the 510 on the website.
PostPosted: Thu Mar 26, 2020 6:24 am
Thanks, got info from the Gotoh website for general dimensions (LMII site doesn't even show the threaded bushing)
I need a headstock thickness range.
PostPosted: Thu Mar 26, 2020 7:11 am
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Most of the Gotoh tuners for paddle heads have the same headstock thickness range, I think. The A20LX part in your description
is in reference to the button, so I would think it's similar to this one in link. They should be ok with headstocks from 10mm to at least
15mm.
https://www.woodtoworks.com/Gotoh-SGL51 ... _3797.html
These users thanked the author Ken Lewis for the post: Colin North (Thu Mar 26, 2020 3:15 pm)
PostPosted: Thu Mar 26, 2020 7:16 am
I make mine .60"
These users thanked the author Brad Goodman for the post: Colin North (Thu Mar 26, 2020 3:15 pm)
PostPosted: Thu Mar 26, 2020 9:00 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Colin: the info really is in the Gotoh pdf catalogue, but not that easy to decipher. The standard post is 20.2 mm from base to string hole. The collar is 12.2 mm long. That part number indicates a Grover-style engraved button. Must be pricey!
PostPosted: Thu Mar 26, 2020 9:15 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
The 510's I have can be used from about 13mm to 15mm (just over to 1/2" to almost 5/8"). You could use them on a thinner peghead but you would have to file or grind off some to the bushing because it bottoms out.
9/16" or 14.2mm seems to be the sweetspot.
Kevin Looker
I'm not a luthier.
These users thanked the author klooker for the post: Colin North (Thu Mar 26, 2020 3:16 pm)
PostPosted: Thu Mar 26, 2020 9:19 am
I use about 15mm
There’s some
Play there. Just no more than 15
These users thanked the author SnowManSnow for the post: Colin North (Thu Mar 26, 2020 3:16 pm)
PostPosted: Thu Mar 26, 2020 11:23 am
First name: Freeman
Last Name: Keller
I am in the process of putting some on a head that is exactly 1/2 inch thick (which was called out as the minimum in a spec sheet somewhere). That is marginally too thin, I'm probably going to have to use extra thick washers. I'm kicking myself for not actually having them in hand when I planed the head plate.
These users thanked the author Freeman for the post: Colin North (Thu Mar 26, 2020 3:16 pm)
PostPosted: Thu Mar 26, 2020 11:26 am
I use them on my archtops and also use 0.60.
PostPosted: Thu Mar 26, 2020 11:42 am
Thanks guys, sounds about the same as the Gotoh 381s I've been using.
Klooker, that's the same way I measure - screw the bush in, find the mid-point, maximum and minimum measurements
Thank you.
PostPosted: Thu Mar 26, 2020 12:20 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
As per Kevin's pics I checked a set of 510's I had on the shelf and they bottomed out at 12.5mm.
When I said 10mm for the minimum headstock thickness I was assuming the bushing would go all the way
home. 'Course it doesn't. Should'a been smart like Kevin and gone and measured.
PostPosted: Thu Mar 26, 2020 1:16 pm
No worries, I done gone spotted that.
Of course, I've never done anything like that! duh
PostPosted: Thu Mar 26, 2020 1:30 pm
I use 15mm as a target as well...
These users thanked the author meddlingfool for the post: Colin North (Thu Mar 26, 2020 3:15 pm)
PostPosted: Thu Mar 26, 2020 4:38 pm
Last Name: Beaver
City: Lake Forest
For 510's I use about 9/16" or 14.29mm, + or - about .75mm
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: Colin North (Thu Mar 26, 2020 5:02 pm)
PostPosted: Thu Mar 26, 2020 6:54 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
I was curious as to what this tuner looks like, time on my hands, so I went alookin'.
Aluminum engraved grover style button, as Tim pointed out.
https://g-gotoh.com/product/sgv510z/?lang=en
Button on page 48 in the 2020 cat. Nice.
https://g-gotoh.com/catalog-download/?lang=en
PostPosted: Thu Mar 26, 2020 8:20 pm
Bit whorehouse for me, but client bought them when he was a "little bit more than tipsy" so wanted to find a use for them. :)
PostPosted: Thu Mar 26, 2020 9:01 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
You'll have to build guitar to suit :)
PostPosted: Fri Mar 27, 2020 12:49 am
Last Name: Beaver
City: Lake Forest
If he wants to unload a few more you can always send them my way. I'm just here to help.
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: Colin North (Fri Mar 27, 2020 4:56 am)
PostPosted: Mon Mar 30, 2020 8:00 am
I think you'll find that they will bottom out at 1/2" (or slightly thicker, very slightly) so you might get buzzing from the washers. I just take the bushings to the belt sander and take off a few threads. I've got a pair of vise grips that have mark on them where I pinch the flat part and sand the threads until I just kiss the vise grips. Easy peasy.
