It is currently Sat Jul 19, 2025 8:26 am
PostPosted: Mon Mar 23, 2020 9:25 am
First name: Brad
Last Name: Combs
Hello,
I have a few solid bending molds that I made with MDF. Unfortunately I didn't cut the registration bar slot in each piece before gluing up. Has anyone figured out a fancy way to run the completed mold across a router or tablesaw or something in order to cut the slot?
This thing:
I could do it with a hand saw I suspect but I have 5 molds. :D
Edit: The molds I have are solid, not the bars between two plates.
Brad
PostPosted: Mon Mar 23, 2020 9:36 am
Do yours move on you? Mine are pretty heavy and don’t budge, so I get by with a simple pencil line that I can eyeball between the uprights.
You could also notch it out on the bandsaw.
These users thanked the author James Orr for the post: bcombs510 (Mon Mar 23, 2020 9:39 am)
PostPosted: Mon Mar 23, 2020 9:39 am
If you have a long straight bit you could draw a pencil line across where it goes then cut both sides using a miter gauge (clamping it to the miter gauge to hold alignment) and then cut out the middle with a hand saw.
These users thanked the author Clay S. for the post: bcombs510 (Mon Mar 23, 2020 9:39 am)
PostPosted: Mon Mar 23, 2020 9:42 am
First name: Brad
Last Name: Combs
Hey James,
If I don't pull down the upper and lower bout hold downs at the same time it wants to scoot backward (or forward) a bit. Note, I'm using John Halls universal waist caul which has some flex because of the way it is made.
Good idea on the bandsaw, that could be a safe way to do it.
PostPosted: Mon Mar 23, 2020 9:53 am
I just drill a hole and run a threaded bar and nut though it into the slot for the caul/threaded press.
These users thanked the author Colin North for the post (total 3): dpetrzelka (Mon Mar 23, 2020 4:15 pm) • Clay S. (Mon Mar 23, 2020 12:59 pm) • bcombs510 (Mon Mar 23, 2020 9:54 am)
PostPosted: Mon Mar 23, 2020 9:56 am
First name: Brad
Last Name: Combs
I like this. That way the waist area isn't compromised by the flat bar on the tight waisted uke's. I will likely go that way.
PostPosted: Mon Mar 23, 2020 9:57 am
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
You could maybe disregard the slot, drill a 3/8" hole through the mold and bending machine and use a long bolt to keep everything
put. That's how I built mine. Just a thought.
These users thanked the author Ken Lewis for the post: bcombs510 (Mon Mar 23, 2020 10:01 am)
PostPosted: Mon Mar 23, 2020 10:07 am
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Course, what Colin suggested might work too. :)
These users thanked the author Ken Lewis for the post: bcombs510 (Mon Mar 23, 2020 2:06 pm)
PostPosted: Mon Mar 23, 2020 11:20 am
Haha, I know how that feels. I use John's universal bender, too. I changed to some lighter springs before my latest guitar, and they made all the difference. They're still effective, but there's less man-handling involved. I'll measure them when I head out to the garage today. I picked them up at the local Ace, which has an awesome hardware section.
Update: the springs are 4 3/4” body length, 5/8” outer diameter, .065” wire.
These users thanked the author James Orr for the post (total 3): Pmaj7 (Tue Mar 24, 2020 11:50 pm) • TimAllen (Mon Mar 23, 2020 12:26 pm) • bcombs510 (Mon Mar 23, 2020 12:07 pm)
PostPosted: Mon Mar 23, 2020 12:46 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Drill press with long 1/4” bit to bore through the mould at end of slot, then cut the shoulders on the bandsaw. Did it that way on my first, and still doing it 8 or 9 moulds later.
These users thanked the author Tim Mullin for the post: bcombs510 (Mon Mar 23, 2020 2:06 pm)
PostPosted: Mon Mar 23, 2020 1:26 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
I just screwed a block on each side of the bottom of the mold, between the ends of the bender and it keys into the opening.
B
These users thanked the author Bri for the post: bcombs510 (Mon Mar 23, 2020 2:06 pm)
PostPosted: Mon Mar 23, 2020 2:05 pm
I just line mine up with a black sharpie line thru the slot and put a couple of dry wall screws thru the frame and into the side of the mold at the orange tape markers. That keeps it snug up against the side of the frame, and keeps it from moving back and forth. The opening in my screw press frame is about 1/2" wider than the solid bending forms. This makes it easier to get my heat blanket/wood sandwich in and moved into place. I snug it up against one side for the treble side, and slide it over to the other side for bending the bass side.
Ignore the little square window that I cut out. That is a modification so that my size 5, Terz mold will work.
These users thanked the author guitarjtb for the post (total 2): James Orr (Mon Mar 23, 2020 4:20 pm) • bcombs510 (Mon Mar 23, 2020 2:06 pm)
PostPosted: Wed Mar 25, 2020 8:58 pm
First name: Brad
Last Name: Combs
Simplest and effective. Thanks, Colin!
Plus I made a dedicated caul for the uke. Nice and tight in the waist!
Brad
PostPosted: Thu Mar 26, 2020 12:18 am
[:Y:]
