It is currently Thu Jul 24, 2025 5:03 pm
 Post subject: finishing rotisserie
PostPosted: Wed Mar 04, 2020 9:21 am
People have mentioned that they used a rotisserie set up when finishing with Enduro-var to minimize runs. Now that the weather is getting warmer I am thinking about spraying rather than brushing that finish. Does anyone have pictures of their rotisserie setup? Would something like a barbecue rotisserie motor work?
 Post subject: Re: finishing rotisserie
PostPosted: Wed Mar 04, 2020 11:14 am
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
I don't have any photos of my setup right now BUT you can approach this in a multitude of ways. You want the RPM to be very low - 15 to 20 RPM. You will also need the setup to be stable since it has to hold your guitar. The method of connecting needs to be quite secure as you don't want your work crashing to the ground !!!
Any way that you can dream up that will hold your instrument and spin it securely is all you need. My setup is elaborate and quite expensive - I spent a few hundred dollars building my rotisserie. I have a 3 phase conveyor motor off eBay and a VFD to control it. This then spins a hollow aluminum pipe above the motor. The pipe rotates on two pillow block bearings. It's all held together by a rectangular MDF box that is open on one face. I wanted to use a hollow pipe so that I could put my neck and body on "paint sticks" or "holders" like you use when spraying a finish. Now I can just insert the sticks into the hollow pipe, lock them down, and I'm done. I can do two parts at one time.
I'm planning on doing up a writeup of how I do my oil varnish finish work along with photos. I'm about to start finishing in a couple weeks and will post everything here on the OLF when I'm done.
These users thanked the author Toonces for the post (total 9): klooker (Thu Mar 12, 2020 5:02 am) • James Orr (Wed Mar 04, 2020 9:49 pm) • Mike_P (Wed Mar 04, 2020 6:22 pm) • JimWomack (Wed Mar 04, 2020 3:07 pm) • Clay S. (Wed Mar 04, 2020 2:40 pm) • kfish (Wed Mar 04, 2020 2:27 pm) • meddlingfool (Wed Mar 04, 2020 1:03 pm) • Doc (Wed Mar 04, 2020 11:42 am) • Michaeldc (Wed Mar 04, 2020 11:17 am)
Users browsing this forum: bobgramann, meddlingfool, SimonF and 11 guests
