It is currently Fri Sep 19, 2025 12:12 am
 Post subject: masking
PostPosted: Thu Jan 30, 2020 10:26 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I want to try shellac, top only, on my current build (bolt on neck) and WB lacquer every where else. Which should I do first & how do I mask things
Mike McNerney
 Post subject: Re: masking
PostPosted: Fri Jan 31, 2020 7:57 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I would run the WB first to avoid the water or glycols from softening the shellac.
Here is a quick tutorial on masking off guitars to finish them. https://howardguitars.blogspot.com/2015 ... ces-i.html
Brian
These users thanked the author B. Howard for the post (total 2): Michaeldc (Fri Jan 31, 2020 8:16 am) • Luthier1975 (Fri Jan 31, 2020 8:11 am)
PostPosted: Fri Jan 31, 2020 11:41 am
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
Would a wash coat or two of shellac on the top be a good idea? It would reduce the chance of tearing out fibres when removing the masking. And if any of the WB product seeped under the masking it might prevent any staining/discolouring of the top. The wash coat would be sanded or scraped away before final finishing.
