It is currently Thu Sep 18, 2025 4:23 am
PostPosted: Sun Sep 22, 2019 12:32 pm
Since I started building I've used a simple 2' x 1 3/4' board clamped to my bench with screwed on blocks to elevate and lock (wedges) a guitar body when binding, sanding (including finish sanding) fitting neck to body, etc
I have another arrangement to sand sides of a body.
Wotcha using?
Thinking to make something "better" although this works fairly well.
PostPosted: Sun Sep 22, 2019 1:31 pm
I used a variety of clamping fixtures till I got a Troji. Worth the space it takes up in my small shop.Image
PostPosted: Sun Sep 22, 2019 1:36 pm
Finish sanding is done on a downdraft table.Image
PostPosted: Sun Sep 22, 2019 4:57 pm
Last Name: Sollod
Colin, I made this guitar vise attached to the end of my bench and it has worked well for me. You've probably seen these. It's two pipe clamps, two pieces of 1/4" plywood, rubber foam cushioning on the boards and pipe insulating foam pieces on the pipes. This is the only readily available photo...
www.swiftcreekguitars.com
PostPosted: Sun Sep 22, 2019 4:59 pm
yup! Works great.
These users thanked the author Terence Kennedy for the post: klooker (Sun Sep 22, 2019 5:29 pm)
PostPosted: Sun Sep 22, 2019 5:20 pm
Last Name: Sollod
Terence, That is a much better photo of the guitar vise AND a beautiful instrument...
PostPosted: Mon Sep 23, 2019 11:17 am
City: U.P.
I use this for working on the body, holds guitar while cutting binding channels or neck mortises, etc.
Permanent stationary "chairs" hold one end of the body. Adjustable "chairs" mounted to 1/2" Lexan on a piano hinge support the other end. The Lexan swings up and down with the hand screw to "level" the body however you want. Lots less fiddling around and works great.
Brian
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post (total 2): Durero (Tue Sep 24, 2019 3:08 pm) • Pmaj7 (Mon Sep 23, 2019 1:53 pm)
PostPosted: Mon Sep 23, 2019 11:38 am
Brian
Thanks Brian. That's the kind of holder I'm asking about.
Mine is similar but perhaps a little bit more crude.
I already have a "side of bench" clamping arrangement mostly for neck flossing, a neck or rather body morticing "box" and a carriage for routing binding ledges.
But I like the horizontal holder because I can firmly clamp a body in there and really pull on tape to glue bindings on, and various other tasks.
It can be rotated and/or clamped to the bench in various positions for gluing and scraping/levelling bindings, sanding (by hand or ROS) CA'ing purflings, cutting binding and purfling to length, etc.
PostPosted: Mon Sep 23, 2019 11:48 am
City: U.P.
Exactly Colin. You are looking for the same thing I was. The double thick MDF base is stiff enough and heavy enough to not need clamping except for maybe scraping the back. I can spin it however I want to access the area of work. The adhesive backed foam sheet on the chairs grip the body very well while protecting it. And 3 simple adjustments will hold about any body shape.
Brian
N8ZED
PostPosted: Mon Sep 23, 2019 12:24 pm
rbuddy wrote:
Exactly Colin. You are looking for the s...……………... to not need clamping except for maybe scraping the back. ………………….
Brian
You haven't seen me pulling on that fibreglass binding tape! laughing6-hehe
What's the arrangement with the brass bar screwed on thang?
PostPosted: Mon Sep 23, 2019 1:00 pm
City: U.P.
The brass is a piano hinge that is screwed to the MDF and into the edge of the 1/2" thick acrylic. So the bottom 2 body holding "chairs" can hinge up or down to "level" the body. The knob in the middle raises or lowers the Lexan and the attached 2 chairs.
This should help - (side view)
N8ZED
PostPosted: Mon Sep 23, 2019 1:03 pm
I see now. The upper "chairs" are quite high, and the lower section adjusts to level as required.
What are you using to line the chairs to protect the finish - looks very thin?
PostPosted: Mon Sep 23, 2019 1:46 pm
City: U.P.
The covering is just some 1/8" thick peel and stick foam rubber. You can get it in craft stores. When it wears out or comes off I just replace it. Most all corners and edges the guitar could contact are rounded off for additional protection against my fingers becoming all thumbs when it happens.
Having used it for several years I can't think of anything I'd change.
Brian
N8ZED
These users thanked the author rbuddy for the post: Colin North (Mon Sep 23, 2019 2:05 pm)
PostPosted: Mon Sep 23, 2019 2:14 pm
You've certainly given me some ideas.
I might think about adding some carpeting on the bottom in case fumble-fingers me drop a body on the brass bit/area, and non slip matting on the back.
PostPosted: Mon Sep 23, 2019 3:21 pm
I made this years ago and it has served me well. There is a piece of carpet on the bottom in the picture but I later replaced it with cork. I have a padded tapered block to slide under the head block area to stabilize the body when it is in the top up position.
These users thanked the author Terence Kennedy for the post: Colin North (Mon Sep 23, 2019 3:32 pm)
PostPosted: Mon Sep 23, 2019 9:47 pm
I'll be ordering LMI's vacuum work holder soon. Since I use vacuum for laminating sides and gluing bridges, it makes sense.
These users thanked the author James Orr for the post: Colin North (Tue Sep 24, 2019 3:30 pm)
PostPosted: Tue Sep 24, 2019 2:49 pm
State: West Somerset
Country: UK
Colin I can't locate the picture but I find the cradle I use to do the binding rebate, as per Trevor Gore and other such systems, really useful. It has a good grip on the body and when clamped to the bench allows binding/purfling to be strapped on with some real tension.
Dave m
These users thanked the author Dave m2 for the post: Colin North (Tue Sep 24, 2019 3:31 pm)
PostPosted: Tue Sep 24, 2019 3:29 pm
Dave m
Yes, I've got one of those as well, use it with a tower rig for binding, but it's small and light and glides on big telfon buttons so not so useful for clamping down, etc.
Just looking for a "better mousetrap" than the one I've go.
PostPosted: Wed Oct 02, 2019 12:50 am
It's spendy, but it's awesome.
https://www.festoolproducts.com/festool ... m-set.html
PostPosted: Wed Oct 02, 2019 2:51 am
Kelby wrote:
Got pics of yours being used "in anger"?
I'd be frightened to get it dirty..
PostPosted: Wed Oct 02, 2019 4:48 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I use one of those Stewmac guitar repair vise. They are sold in Taiwan as a wood carving vise but it's the same thing as the older version of Stewmac's guitar repair vise. However it's iffy for holding bodies. I have to be very careful where to clamp it or I risk damaging the body if I clamp it tight enough to hold it. If the guitar has a neck, I can clamp the neck down and work on the guitar without any issue or risk of dropping it.
Typhoon Guitars
PostPosted: Wed Oct 02, 2019 9:15 am
I'm still using my knees LOL. Some good ideas here. I love the troji but just don't have the room for one. I do have one of those Work Mate tables though and I understand some folks use those as a sort of troji... Something to look into.
PostPosted: Wed Oct 02, 2019 10:25 am
Guitar repair vise. Had one for years, totally unsuitable for what I need.
PostPosted: Wed Oct 02, 2019 10:46 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Colin--
For body holding, see my workbench in this thread:
viewtopic.php?f=10101&t=52256&hilit=workbench
I use the twin screw vise on the end of my workbench, in conjunction with some pretty strong foam against both jaws. The foam is the really hefty stuff that doesn't yield easily. I cut a curved shape (roughly 15' radius) in the inside faces. This basically works like a Troji, but I can also take the foam out and use the vise as intended. It is just the right width for fingerboards on edge, stuff like that.
These users thanked the author doncaparker for the post: Colin North (Wed Oct 02, 2019 11:48 am)
Users browsing this forum: Bing [Bot], Woodie G and 20 guests
